Question about Toshiba Satellite A75-S229 Notebook
Computer turns on and boots up , however, the
Computer turns on and boots up , however, the LCD screen is extremely dark, is there a fix for this or the screen needs to be replaced
  • 540 Answers
No the screen is fine the back light is not working you have replace the back light of the screen to resolve the issue.But before that please try the FN+F6 or F7 keys to control the brightness.
Posted on Feb 09, 2010
Computer turns on and boots up , however, the screen is dark
Try going into the control panel and select power options see if there is way to adjust the display brightness or try holding down the "Fn" key and use F7 to increase the brightness
Feb 07, 2010 | Toshiba Satellite A75-S229 Notebook
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
My dads toshiba A20-S207 has a dark monitor. Can very faintly see the windows xp logo at the beginning of boot up, so it looks like it is booting up, but the monitor stays dark. Can u help?
common LCD dark.dim screen problem, u can google keywords get more information.
either LCD inverter failure or CCFL backlight lamp failure, ask for a pro get it fixed.
by using a flashlight could you see the image on the LCD?
Dec 06, 2009 | Toshiba Satellite A20-S207 Notebook
My Emac will boot up but it will not light up.What can I do?
Look closely at the screen, can you still see the icons in the background?
If you can and it seems extremely dark. then your problem is likely an lcd inverter board. This isn't a terribly expensive part but getting it replaced might not be cheap labor wise. An lcd inverter is what powers the backlight for the screen.
Oct 22, 2009 | Apple eMac G4 M9425LL/A Desktop
My gateway computer screen is dark it flashes extremly light sometimes but mostly dark how do i fix it ?
most likely your invertor, which controls the power distributed to your lcd. probably bad have a tech swap one out for you, its located right under your lcd.
Oct 16, 2009 | Gateway 450ROG Notebook
Once the PC is booted up the monito screen goes dark
try another monitor to isolate if it is the monitor, if it is the LCD, the back light may be going out
Jul 07, 2009 | Computers & Internet
Screen IS black, BUT EVERYTHING ELSE IS OK
there is a invertor in LCD. it makes your lcd bright white shine. if it doesnt work you can have dark view. i mean something going on the lcd but you cant see clearly. take to tecnic service your computer.
i hope it works.
May 27, 2009 | Dell Inspiron 1501 Notebook
The LCD does goes dark after power on
you mean few second the monitor goes in black. then its come. if it happen, it is ok
Jan 21, 2009 | Sony VAIO® VGC-LS37E PC Desktop
Dark screen
you may need either a new lcd, or a motherboard, or both..lcd is usually the first issue to resolve..does it work , by chance with an external monitor?
check your computer warranty here 4 FREE
Feb 29, 2008 | Sony VAIO PCG-K23 Notebook
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Toshiba Satellite A75-S229 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
