Question about Frigidaire FMV156DC Microwave Oven
Microwave door handle
I need to replace the handle on a Frigidaire FMV156DC microwave.  Does anyone know how to seperate the back of the door so I can screw the handle into the front.  Thanks!
  • 6 more comments
  • Anonymous Mar 11, 2008
    Yes, I'll have to replace mine too. New condo here, it lasted 6 months and just recently, the whole bottom section broke off. I wonder if it can't handle the heat from the oven below it... odd, since it's designed to be mounted over a stove, hence the built in light and exhaust!
  • Kymry Jul 26, 2008
    My handle broke off my Frigidaire microwave FMV156DB also! I have been trying to find a replacement on line but can't even find a place to order a new handle. Does anyone know where to order one? This microwave was only a year old when it broke off so maybe it is the heat from the stove that weakens it since others have the same problem? Help!!!
  • Anonymous Dec 08, 2008
    I have the same issue with mine. I hope I can find a handle to replace it.
  • Anonymous Jan 19, 2009
    ya there is a plastic gasket then there is the steel frame around it......when you remove the plastic it exposes the lower screw but the upper screw is left covered by a peice of metal
  • Anonymous Mar 12, 2009
    Just wanted to say this was the perfect answer to my problem. The only issue I had was the cost from the manufacturer for the replacement part. It was over a hundred dollars for just a plastic handle.
  • zxatl2003
    zxatl2003 Nov 20, 2012
    I have had 4 microwaves and they have all been different models and makes..... It finally dawned on me it was the heat from the oven that stressed the plastic handle with a metal screw in it and made it NOT hold up. It is obviously a design error for something built to be put over heat like that.... I think the industry should pick up the tab. BAD DESIGN AND MANUFACTURERS DEFECT,``````
  • Anonymous Mar 15, 2014
    I need an Installation guide for replacing the door to my Microwave Oven
  • Anonymous Mar 20, 2014
    i need instructions on how to replace my microwave door handle on model mhe14xmq-0.
  • Frigidaire Master
  • 9,098 Answers
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 25, 2008
Cannot open door or frigidaire microwave
Good Afternoon Friend,
I understand that you are unable to open the door on your Frigidaire microwave, model# FMV156DC. Due to this being a microwave, I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance and should be able to get the door open without any damage to the appliance, or harm to you or your home. Hope this is helpful.
-Best Regards-
WP
Jun 11, 2014 | Frigidaire FMV156DC Microwave Oven
Frigidaire FMV156DC 950 Microwave sometimes stops heating
This sounds like a common primary interlock switch. Need to check and or replace both door switches. DISCHARGE high voltage components first with no power applied prior to touching anything in the unit. Failure to discharge High Voltage Components can result in death
Aug 13, 2012 | Frigidaire FMV156DC Microwave Oven
I don't know how to replace the charcoal filter on my Frigidaire FMV157GC microwave. There's also food between the grate and the glass on the microwave door. Help !
This is billed as the Use & Care Manual for the Frigidaire FMV156DC Microwave Oven:
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Springfield/316495004en.pdf
Not sure it is the correct one but you will find instruction for cleaning the exhaust filters on page 19.
Below is the Use & Care Manual for a model direct from the Frigidaire site:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316495057en.pdf
This is more helpful as on page 20 it includes illustrated instructions for removing the charcoal filter to change the oven light. Disconnect from power, remove the ventilation grate at the top to access the charcoal filter, slide back and lift to remove. With the grate removed carry out any required cleaning.
Mar 20, 2011 | Frigidaire FMV156DC Microwave Oven
How to replace door for frigidaire fmv156dc
If you remove the vent above the door, a couple of phillip screws hold it on top, it slide off to the left, open the door and pull up on door, look at hinge and remove off of tabs
Sep 03, 2010 | Frigidaire FMV156DC Microwave Oven
Broken handle on over the range microwave
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. If the model number you have this question listed under is correct, the part number for a replacement handle is 5304440323.
If you have any questions, please post back with your complete model number (if different than the one listed) and let me know. I hope this helps you.
Apr 12, 2010 | Frigidaire FMV156DC Microwave Oven
FRONT GLASS DOOR HAS CRACKS
Sounds to me like the door needs to be replaced.
Jul 29, 2009 | Frigidaire FMV156DC Microwave Oven
Frigidaire Professional series microwave won't heat
The most likely problem is the magnetron. Check your warranty in owners manual, I believe you have five year warranty on magnetron.
Mar 15, 2009 | Frigidaire FMV156DC Microwave Oven
Broken handle
Almost all microwave ovens manufacturers locate the handle mounting screws behind the inner black plastic frame known as the 'choke'. If done very carefully, the choke can be removed with a putty knife without breaking it. My suggestion would be to order a handle and a choke. HOWEVER ordering a complete door will be less aggravation and not a lot more money. The handle and choke will cost around $120.00 whereas a complete door goes for around $130.00. Check out www.searspartsdirect.com for more detail.
Feb 03, 2009 | Frigidaire FMV156DC Microwave Oven
Frigidaire FMV156DC Microwave Oven Logo
866 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
