Question about GCC Technologies Elite 21N Laser Printer
GCC 21n Fuser Error
On my GCC 21n printer, I get a message "fuser error." What can I do to fix it?
Error message of: 50.2 Fuser error
Fuser isn't heating up to the correct temperature.
Power off and let the fuser cool off. Remove it and reseat it.
If error still there replace the fuser.
If that doesn't fix the problem, replace the low voltage power supply(LVPS)
Jan 25, 2011 | HP LaserJet color laser printer
925 service fuser error
A 925 Fuser Error indicates that the wrong fuser lamp or the incorrect fuser assembly is installed.
  1. If this error appears shortly after the fuser unit in the printer is replaced, put the old fuser unit back in.
    If the error message goes away with the old fuser unit, please check that the new fuser unit is the correct one for this printer model.
  2. If the printer has not recently had its fuser replaced, plug the printer directly into a wall outlet. Surge protectors and power strips can sometimes regulate the voltage to a fault for the printer. If the printer is already on a wall outlet, plugging the printer into a different outlet may solve the problem. Keep in mind that there is no need to have the printer connected to a computer during testing for a fuser error as any pages to test the functionality of the printer can be processed internally.
  3. If you have tried the printer on other wall outlets and the 925 Fuser Error still appears, the printer will require service to clear the message.
Jan 12, 2010 | IBM Infoprint 1352 Laser Printer
Fuser error on my ibm infoprint color 1464
The error is Fuser cam position not found. Have you tried reseating the fuser? Does the fuser make any loud sounds? Based on the error message, it could either be the fuser, or the system board.
Apr 08, 2009 | IBM Infoprint 1116 Laser Printer
Fuser 50.1 error on HP 3500 printer
From HP Website:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
Mar 23, 2009 | HP Color LaserJet 3500 Printer
HP Laserjet Printer 4700 Fuser Error
Try unplugging the printer for 30 mins. You may still have a defective fuser.
Mar 12, 2009 | HP LaserJet 4700 Printer
Fuser Error 50.1 Fuser is hot. What is a fuser?
error 50 means your fuser assembly has gone bad or its not getting power to be functional. you need to replace the fuser unit.
Aug 17, 2008 | HP Color LaserJet 2600n Printer
Lexmark E342n Laser Printer Fuser Error
920 Fuser Error
Indicates that the fuser is below temperature when printing
Do a Fuser Service Check
Jun 26, 2008 | Lexmark E342n Laser Printer
Hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell Mpundu@technet.co.zm
Apr 21, 2008 | HP LaserJet 4350 Printer
Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Oct 22, 2007 | Xerox Phaser 6100/BD Laser Printer
GCC Technologies Elite 21N Laser Printer Logo
65 people viewed this question
Top GCC Technologies Office Equipment & Supplies Experts
k24674
Are you a GCC Technologies Office Equipment and Supply Expert? Answer questions, earn points and help others
