Question about Canon PowerShot SD950 IS Digital Camera
My Canon SD950 IS camera will take about 30 seconds to take a flash picture. You have to hold down the shutter button for a long time. The flash indicator flashes on the display for quite a while and then the picture is finally taken. This seems to have happened after the battery was run down to nothing. After that, this flash problem appeared. I have got another battery but this still happens. I have reset to default settings as well . Still has problem. What is wrong?
5 Suggested Answers
SOURCE: Canon SD 950 SD950 Lens
i have one.
cfb102@psu.edu
Posted on May 31, 2008
t00nz
  • 4738 Answers
SOURCE: Purple band
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Oct 18, 2008
BillB-SA
  • 2761 Answers
SOURCE: Pressing shutter switches the camera off (40D)
Before you send the camera in for repairs, try this free fix. The problem that you described is frequently battery related. Make sure that your batteries are the correct type for the camera, and that they are fresh/fully charged. If the batteries are OK, the problem may be due to corrosion on the contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, wipe the ends of the batteries, and replace them in the camera. This cleaning process works about 90% of the time, and I hope that it cures your problem.
Posted on Sep 11, 2009
t00nz
  • 4738 Answers
SOURCE: My Canon A720is seems to lock up at times. It will
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try:
Posted on Dec 25, 2010
I cannot take the second picture. After I take one and hold down the shutter button for the second, it will not focus or take the picture
If I remember correctly, for that camera, you need to turn the dial to the Sport setting, it's the icon that looks like a man running. That is the only setting that will take continuous pictures as long as the shutter button is held down.
Nov 20, 2014 | Canon EOS Rebel XS 35mm SLR Camera
Canon EOS 400D Flash Problem
yes..that's a twitchy button all right..can you inspect it to see if there's any accumulated dirt/grease can cause it to actually 'stick'
Mar 29, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
How to use self timer Canon 2000 IS
I'm assuming you mean the IXY 2000 IS.
Press cursor-down (marked with a one-handed clock) to bring up the shutter release menu, then use cursor-up/down to select the desired self-timer mode. Start the self-timer by pressing the shutter release button as usual.
The IXY 2000 IS is called the SD950 IS in some parts of the world. You may download the SD950 IS manual from here. The self-timer instructions begin on page 73.
Mar 11, 2013 | Samsung DigiMax Cameras
On the easyshare m575 what does the self timer/burst feature do?
Self-timer
(10-second delay) it will have a 10 on it
Time to get yourself into the picture. Place camera on a tripod or flat surface.
Self-timer
(2-second delay) it will have a 2 on it
Allows for a steady, auto-shutter release on a tripod.
Self-timer
(2 pictures) it has a 2X on it
Capture 2 shots (one picture taken after 10 seconds and another picture taken 8 seconds later).
First Burst
Flash forced off.it has like 2 folders in front of the camera
Camera takes up to 8 pictures (2 per second) while the Shutter button is held. The first 8 are saved. (Capture an expected event e.g., baseball swing)
Last Burst
Flash forced off. it has 2 folders behind the camera
Camera takes up to 30 pictures (2 per second up to 15 seconds) while the Shutter button is held. When the shutter button is released, only the last 8 pictures are saved. (Capture an event when the precise timing is uncertain e.g., a child blowing out birthday candles.)
Mar 03, 2011 | Kodak Cameras
How do you take a picture using the timer/
With the camera on, press the symbol on your function wheel that looks like a picture of a clock. Use your arrow buttons to select the time you want, I think it goes up to 30 seconds.
When you press the shutter button, the camera will wait the selected amount of time and allow you time to get into the picture. It will then take the picture the way you would have as if you were pressing the shutter button.
Hope this helps, Janet!
Jan 01, 2011 | Canon PowerShot SD1000 Digital Camera
Can't take picture. "F" is flashing
Flashing "F--" means the camera is not recognizing the lens or a non CPU lens is attached. Try manual mode. Taake battery out of camera, remove lends and clean electrical contacts on lens and camera body with moistened swab, Put back together. Remove battery with camera "ON" and hold down shutter button for about 30 seconds. Put battery back in and turn on. Then Press hardware reset button on camera bottom.
Dec 18, 2010 | Nikon D70 Digital Camera
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Jun 17, 2010 | Kodak Advantix C400AF APS Point and Shoot...
Canon PowerShot SD950 IS lense won't retract
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Dec 12, 2009 | Canon PowerShot SD950 IS Digital Camera
Wont take a picture unless I turn off the flash
http://camerarepair.blogspot.com/2008/05/simple-fixes-for-cameras-that-wont-take.html
Jun 15, 2009 | Canon PowerShot A710 IS Digital Camera
Blurry pictures
THisi s for every shutter time? I had the same problem, unless I go to the "S" setting and adjust the shutter time down. Unfortunatley I am having a flash problem, so I need a lot of ambient light. Adjust the shutter speed to less than 1/30 of a second and it should help. Also, I apply very little pressure to the shutter button and wait for the green light on the left hand side of the LCD screen. This tells you that the camera has focused. Then fully depress the shutter button to take the picture.
Jan 30, 2009 | DXG Technology DXG-608 Digital Camera
Canon PowerShot SD950 IS Digital Camera Logo
47 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
