Question about Honeywell Programmable Thermostat Heater
Honeywell thermostat I somehow locked my thermostat and cannot change any of the temp settings. Anyone have any suggestions to get the lock symbol off?
  • Thumbleleana Feb 22, 2008
    Thanks forgot to put that down. Lux1500 Pa. No 5.673.850 Have been looking at their site and have not found instructions to download.
    Master:
  • 518 Answers
If you lost the manua, you can go to their site and download it.
Hard to help more without a model number. Sorry.
Geno
Posted on Feb 22, 2008
Why does my Honeywell thermostat state temporarily set at 68 degrees? A few days later, it will be set at 62 degrees without anyone touching the thermostat?
It's a programmable thermostat. When you change the temperature, it will say temporary until the next programmed schedule starts or a set amount of time. You will have to program the thermostat to the correct temp settings you wish to have, or you can push "HOLD" after changing the temp to make it stay at that set point. Hope this helps!
Nov 19, 2016 | Heating & Cooling
I couldn't figure out how to amend my last question, so here is one more piece of information. I just put batteries back in and reset the time/date. The Temp Up and Temp Down buttons WORK FINE
your thermostat may be locked go to honeywell web site punch in thermostat model # and look for set up pushing two button at the same time gets you in but you will need instuctions for set up
Jan 31, 2015 | Honeywell RTH230B 5-2 Day Programmable...
Time and vacation symbol flash-all buttons non responsive - how do I fix
Hello there,
Are you SURE the floor temp sensor is wired correctly Page 8 of the Manual ???? It should be across 1 and 2 . if it was on the number 2 and 3 connections, this would simulate a 'remote switch' check the wiring of the floor sensor carefully in the back of the unit.
Something odd about the 'Vacation'mode' setting. You said it has no remote switch but only this 'remote switch' can disable it. by going open circuit. which sounds suspiciously like something is across pins 2 and 3
Time flashing is 'Temporary override'
Read page 16 AND 17 (flashing as you say) of the user manual
https://customer.honeywell.com/en-US/pages/product.aspx?cat=HonECC%20Catalog&pid=TH115-AF-GA/U
Click literature and download.
Sep 22, 2014 | Honeywell Aube TH115-AF-GA 7-Day...
Change factory set date on thermostat
This is just general information for most thermostats. Press the set button until the date comes up. Press the up or down temp. buttons to where you want it. Press the run button to lock it in. I hope this helps.
Nov 11, 2013 | Honeywell Programmable Thermostat Heater
Honeywell thermostat is locked in the off position
sounds like keypad is programmed in lock position read manual for set up to activate keypad again.
Nov 25, 2012 | Honeywell Programmable Thermostat Heater
My rth230b temperature up and down control buttons are now not operable, ie they do not move any function up or down. whether it is a clock reset, or changing the temperature.
Verify your battery is good. Make sure it is in manual and not program by using the mode select button. Verify its set to heat. The first push will show the set temp. Push twice or more to change the temp. With that all said if it is still locked out you might have a short. If its been less than a year you can call the support number on your installer sheet and check for warranty info. I didn't see one in the instructions but to be safe make sure there is not a lock out feature too.
Feb 26, 2011 | Honeywell Programmable Thermostat Heater
Just installed a honeywell thermostat, but I can't get the clock to set or the temperature to change on it. How do I get the clock to set?
May be your thermosta setting under locked. By seeing your thermostat manual release lock and then you can satrt changing temp setting or clock setting.
Dec 02, 2010 | Honeywell CT500 Digital Heat / Cool Manual...
Can you lock in the tempture in the wall thermostat
I don't know....
To fix your problem you can put a lockable plastic cover over the thermostat.
Dec 15, 2008 | Honeywell Programmable Thermostat Heater
Honeywell programmable thermostat
It sounds like you might have the same problem that we have. I read the manual and it says that thermostat has a special lock to prevent tampering. It could be locked. If you override it only last a while and goes back to its original settings. The manual says you need to contact the person who installed it. In our case the person who was in charge when when we had it installed is no longer with the company. We don't know who installed it.
Jul 29, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
305 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
