Question about Garden
Can't start Husk 257 saw - Garden
  • lindsay836
    lindsay836 May 11, 2010
    Please tell me what you have tried, and I will walk you through getting stated.
    President:
  • 2,220 Answers
Before doing anything, remove, clean, and reinstall the air filter.
Remove, clean, and reinstall the muffler and spark arrestor.
Drain and refill the fuel tank with fresh 50:1 fuel mix. If there is ANY doubt the mix might be older than 1.5 months; replace it with a fresh mix.
It needs:
1. spark
2. air/fuel mix
3. compression
to run. Which 1 is missing?
Repair/test for above:
1. Replace the plug (very inexpensive and may save the cost of a coil). Test for spark (inspect the plug when you remove it – wet? The engine is flooded, the most common starting problem)
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
2. Spark good, plug not wet: (if it does not start or reason is found upon completion of 2 reply below with ALL results and we will continue. Brevity is not correct with internet help. I cannot easily ask questions or see what you have or are doing.)
Remove the air filter, open the choke, add a teaspoon of fuel directly into the carburetor throat and reinstall the air cleaner.
  • Ignition on/off to on
  • Set compression release – optional step even if saw is equipped with a compression release
  • Pull (close) choke, set fast idle (done when choke closed on some saws); push (open) choke, pull starter until it starts. (Pull at least 6 times NO CHOKE).
Did it try to start? This is indicative of a fuel delivery problem. Check the fuel filter on the free end of a hose in fuel tank (manufacturer recommends an annual replacement). Check all fuel delivery lines especially at fittings and bends for cracks and holes. It can also be an air leak, inspect for a loose or defective carburetor manifold or loose carburetor. If those are good then the likely cause is internal parts of the carburetor are dirty or have failed. A good local saw shop can do diagnostic pressure tests that often save time.
Because this is MOST common cause of hard starting: (read your OM closely it is very similar)
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
3. Good spark, good fuel, not flooded.
I am not going to discuss cylinder inspection until you reply the above was not successful.
This is a fine saw. It uses the same frame as the 262, one of Husky's best. The operator's manual is complete and detailed. I wish current models were as good. Please reply with any result, I hope to hear from you.
Your manuals OM and IPL can be found here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Posted on Feb 09, 2010
How can you freeze corn still in husk ?
I remove the outer layers of the husk leaving the bright green husk, then cut the ends off and place 4-6 in a large freezer bag and seal. This works great and when you thaw it and cook them later, they are just like gargen fresh. The silk comes off easier after they have been frozen.
Sep 05, 2014 | Kitchen Appliances - Others
My husqvarna 141 will not start??
Very unlikley to be an air lock, more likley to be a massive air leak, check the rubber induction tbe behind the carb mount it may have split, if not then a possible blown crank seal.
Feb 13, 2013 | Husqvarna 36 41 50 51 55 136 141 154 254...
Husqvarna 257 will not start. Might fire briefly, then nothing.
This is quite an old saw, so i would be changing the fuel filter in the tank, and also the fuel hose.
May 08, 2011 | Husqvarna Chain Saw 20" Bar
I have an old husk,chain saw, about 25 years oldand need a sprocket, how can i find whatn model it is, many thanks
Hi, you need to post a picture somewhere if i can see it, i will soon tell you what it is, or give me a very good discription of it, top cover colour, top cover fixing, muffler shape and position, filler caps position, rear handle material, anti vibration system, air filter type and orientation, one or two bar bolts,vertical or horizontal cylinder.
Mar 12, 2011 | Husqvarna Forest & Garden No.967012396 345...
Husky 51. Saw gets great spark. seems to be getting plenty of gas too. Fires out of the hole but when i tighten down the sparkplug it wont fire
I have a husk 350, someone owed me money this is what i got. fired only with gas in the carb, would not run at all just start and off. would not fire at all without doing that. I took the carb apart 3 times no luck. Well I I said I am going to take this thing apart and see how its made and then toss it. As I was taking it apart I notices that the head bolts were little lose. I tightened them down put it back together, and that was the problem. Now it starts first lick. Sometimes the head bolts vibrate lose. have found this problem in weed eaters too.
Jul 07, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Homelite ut10560 chainsaw good compression, good spark but won't start, not even a hint of turning over, whats wrong
check your fuel lines for cracks carb screen (if it has one) or jets might be clogged , also, I have a husk 350, fired only with gas in the carb, would not run at all just start and off. would not fire at all without doing that. the head bolts were little lose. I tightened them down put it back together, and that was the problem.
Jul 07, 2010 | Homelite ZR10926 16" Chain Saw
Husk 141 will start if i spray stater fluid in it but wwill only run for a few seconds. Will not start at all with out starter fluid.
Be really REALLY careful using go fast juice in small engines, you can lock them up and snap a crank in a heart beat
Remove the fuel line from the carb and blow back into the tank.
90+% of small engines not running are from plugged or pinched fuel lines. If it has been pinched replace it.
Clean the tank out and refill with good clean gas mix you should be good to go
Mar 07, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
182 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
