Question about Remington Microflex R-845 Electric Shaver
Shaver not turning on
Remington R845 ........kinda old ..when turned on gives no responce
  • Remington Master
  • 1,621 Answers
Most likely, the rechargeable batteries need replaced. This model does not run directly from the cord. You can change them yourself if you can do some light soldering.
To replace them, you will need to remove screws on the back to take off the back cover. You can then remove the old batteries.
Batteries can be purchased at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
Posted on Feb 07, 2010
1969 Remington ladies electric razor model Cl how to use it
Women's Shaver Parts' Parts and Accessories ' Remington ...
www.remingtonproducts.com/.../womens/shaverpart...
Remington ProductsRemington women's hair removal replacement parts. Electric shaver parts, wet dry shaver blades, shaver heads and cutters, shaver cords, ... I have a Remington Smooth & Solky Plus Wet/Dry Rechargable Shaver (Model: WDF-5000) and am ...
Women's Electric Shavers - Remington Products
www.remingtonproducts.com/womens/.../wetdrysha...
Remington ProductsRemington Women's Hair Removal Wet Dry Shavers ... Wet/Dry Shavers. Smooth and Silky 4 Blade System Rechargeable Shaver With Almond Oil; $39.99.
Jan 07, 2016 | Remington Health & Beauty
Are there more than two screws holding the front and back together on a Remington R845 shaver?
There are only 2 screws holding the razor together. There is 1 on the back next to the cord plug-in and 1 in the middle of the back (on mine it was hidden under the battery recycling sticker). Once both are removed the back slides off away from the shaving heads.
Feb 24, 2011 | Remington Microflex R-845 Electric Shaver
The shaving screen pops up when I turn on the shaver .
If the shaver heads pops up, this is because you have not cleaned it properly. This is common on this model type. You will need to thoroughly clean the top of the shaver body. Remove the cutters so that you can access it properly. You may need to use a toothpick or similar object to loosen and remove the build-up in the crevices. Then brush it all out with an old toothbrush or similar.
Clean it thoroughly and it will fix your problem
If you require a new screen for your shaver, you will find at shaveroutlet.com. See link below http://shaveroutlet.com/shaver-replacement-parts/remington-sp-390-foil-and-cutter-set.html
Nov 24, 2010 | Remington F5790
The screen covering the blades keeps popping up after I turn on the shaver
WILL NOT GHARGE RIGHT...VERY WEAK MODEL R845
Rechargeable batteries can become weakened over time by light use and light charging. Try running the shaver totally flat and then charge the shaver over night. If this gives you back your batteries back their charge then in future run the shaver until flat each time before charging.
Jun 11, 2010 | Remington Microflex R-845 Electric Shaver
It won't charge. it lights up but does not turn on Remington Microflex R-845 shaver Does it need a new battery? if so, where do I get one?
It probably needs new batteries. You will find the batteries at shaveroutlet.com. See link below. You will need to order two batteries.
Replacement instructions:
Remove the two screws on the back to remove the back cover. Unsolder the wires connected to the batteries and solder in the new batteries the same way you take out the old ones
Mar 26, 2010 | Remington Microflex R-845 Electric Shaver
Remington Microflex R-845 Electric Shaver Logo
253 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
