I cant get signal or channels on Olevia LCD 427-S12
  • 4 more comments
  • mdavis192 Feb 07, 2010
    I am using Comcast digital cable box and coaxial cable
    I cant get signal or channels in Olevia 427-S12. I am using comcast digital cable box and coaxial cable to connect to TV.
    I have tried all inputs, im using coaxial cable from the digital cable box. TV was working fine until I tried to change the picture setting to wide screen. Accidentally cleared the channel list. now I cant get a signal or channels to auto search
    I tried it on set - tv - auto channel search cabl or Air still nothing what is my next step
    Should I have the source on Tuner. I noticed that it has no channels in the box below. While if I put it on composite it says no signal, s-video says no signal, HDMI says no signal, VGA sya no signal.
    Cant get signal or channel Olevia 427-S12. im using comcast digital cable box and coaxial cable. I have tried to use rca jacks still nothing. the tv want search for channel
  • 11,896 Answers
If everything is connected right, then you can go to main menu, find the tuner option. Set to AIR if you are using antenna and switch to CATV if you are using cable.
Then find the "autoprogram" option. Select this and let it run completely through. It will add all available channels and delete the ones you don't have.
If done correctly all you channels will be programmed into your tv.
If everything is done correctly and you still don't have any signal, then the tuner card may be faulty.
Posted on Feb 07, 2010
  • 8,197 Answers
Are you sure that you have the TV on the right input to where you have the signal coming in. I would try all inputs to see if you get signal or channels.
  • 2 more comments
  • Jyackle5
    Jyackle5 Feb 07, 2010
    Go to your menu and do a chanel scan also mare sure that you have it set to cable or air. Make sure the Tv is on channel 3.
  • Jyackle5
    Sounds like the input board went out on you. Have you tried to use rca jacks to see if you get anything that way.
  • Jyackle5
    You can try that.
  • Jyackle5
    Just looked in the manual and the tv needs to be on the tuner setting to receive the signal from the coaxial cable. If you do not get signal there try to use the rca jacks on the back of the tv to see if you get anything.
  • 3,230 Answers
Well can you explain your situation a little more?
How long have you owned the TV?
What is being used to supply the signal to the TV?
Thanks
Olevia 232 s12 Accidentally hit factory reset. now no channels in list. how do I get my channels back?
You'll need to reprogram the channels.
Typically this is found under the settings in some sort of auto program section of the menu.
On most newer televisions, the setting is found under a 'Channel' section.
Just select auto program and your source, whether it be an antenna or a cable source.
When the auto program is completed, you'll have your channels back.
Mar 05, 2011 | Olevia Televison & Video
I have a olevia 427-s12 which has power and backlight but no sound and no picture.
It can be that the 12vdc is not working, the sound amplifier and the T-CON board (for picture) use 12vdc, so check thw power supply section first, worst case will be the main board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Oct 27, 2010 | Syntax Olevia 327V 27 in. LCD Television
Haier tv says no signal
My tv olevia lcd 427-S12 no signal
Mar 06, 2010 | Haier HLH32ATBB 32 in. LCD HDTV
Trying to set up my Olevia 232-S12 television to my Comcast cable. I don't have my manual. It's the most simple set up but I don't have the manual to let the televison know what source to use or I am doing...
I was able to allow whatever cable it is my apartment provides by using the tuner to auto-search channels. I did this without the remote in case anyone is missing theirs (I found mine). By selecting the tuner from your source options, I (?) think (?) it says 1:1 on the tuner, being the start of the channels, just in case you or whomever may be over-looking the source - tuner - option. From there do an auto search for channels. The more you have the longer it takes. Not more than 10 or so minutes,it's no big deal. This should work, it did for me.
Jan 25, 2010 | Olevia LT32HVM 32 in. LCD Television
No signal when cable is plugged in
check your input make sure it is set to catv (cable)
Oct 20, 2009 | Syntax Olevia 432V 32 in. LCD Television
No tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Jun 19, 2009 | Syntax Olevia 226T 26 in. LCD Television
Olevia 427-s12 wont come on
unplug it u got the warrenty still on it
Jun 04, 2009 | Samsung FPT5084 50 in. Plasma HDTV
No channels
Are you using a set-top converter box?
Jun 30, 2008 | Olevia LT32HVE 32 in. LCD Television
Olevia syntaxbrillian flat screen tv model527-S12
go through the setup and have the TV auto programm again. This should fix the problem.
Dec 06, 2007 | Televison & Video
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
