Question about Dishwashers
I have a GE mokel PDW 7300 dishwasher. I recently
I have a GE mokel PDW 7300 dishwasher. I recently replaced the garbage disposal, into which the dishwasher drains. Now the dishwasher is not pumping out all the water after running it. Thanks,
  • 10,865 Answers
Hello. Disconnect the dishwasher drain hose from the disposal and look into the disposal tube where you will see a plastic plug that you will need to knock out with a screwdriver and a hammer. Regards, J.
PS kindly rate my answer. Thank you. Joe
Posted on Feb 07, 2010
Testimonial: "Expert advise, saved me a service call. A very easy fix. Thanks much."
Dishwasher not emptying out water
If you recently replaced your garbage disposal make sure the "knock out" plug was punched out to allow drain water into the disposal. The guy who replaced my disposal forgot to do it and my dishwasher would not empty. It's an easy fix. Just remove the drain hose from the dishwasher that attachs to your garbage disposal. Look inside with a flashlight and you will see if it is still there.
If it is, take a hammer and screw driver or punch and knock it out. TURN OFF POWER to your disposal and you can retrieve the "knock out" plug (piece of plastic about the size of a dime). Replace your drain hose to the disposal and try your dishwasher again. Worked for me! Good luck.
Oct 05, 2014 | Dishwashers
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
Frigidaire dishwasher has standing water that did not drain
Frigidaire dishwashers have two pumps. one for wash and one for drain. But if your
dishwasher is connected to a garbage disposal and the disposal is not working then the
dishwasher will not drain. Otherwise the drain pump on the dishwasher has failed
OR the line itself is plugged (sometimes the port on the disposal gets gunked up and
will not allow draining). If you have replaced the disposal recently
the "knockout" may still be in the garbage disposal port.
One last thought, if you have
a small tomato paste can sized item next to the faucet that seems to serve no
purpose, this is called an "air gap". They can also get gunked up as well and prevent
draining of the dishwasher. They are inexpensive to replace or can be cleaned.
Hope this is helpful.
Apr 12, 2011 | Dishwashers
My GE will not drain at all, I do not hear the drain cycle. We did recently replace a disposal, can this cause the diswaher not to drain. If so, how do we check this and fix it?
Sorry to read about your problem, I hope this helps you out.
i will assume you hookek the dishwasher to the garbage disposal... their is a knock out plug you have to remove from the disposal..you will have to remove the disposal, take a screw driver and put it into the place the hose hooks up to, and remove the plug.. hit with hammer. if you put your finger in the hole you will see its blocked
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | GE Dishwashers
My gld6500l dishwasher worked fine, then my husband replaced a broken garbage disposal. The next day I ran my dishwasher and it now will not drain. Coincidence, or could the two be related?
Yes probably a connection. The dishwasher drain connects to the the Garbage disposal . If the line is kinked then the dishwasher will not drain. Plus the dishwasher has to have a plug knocked out where the drain line goes into the garbage disposal. I am sure this is your problem.
Jun 02, 2010 | GE 24 in. GLD6500L Built-in Dishwasher
Replaced disposal and now dishwasher isnt draining
It sounds like you've done everything fine. I would disconnect the dishwasher drain line from the disposal, have a bucket ready and see if it will drain. It's possible that there is a plug or something else left in the disposal opening that is blocking the water. If the dishwasher won't drain with the hose off of the disposal, there is a problem with the dishwasher that has nothing to do with your disposal installation. Hope this helps and good luck!
Mar 12, 2010 | Dishwashers
I've got a GE dishwasher, a GSD2800. It's giving a C4 code and it just won't drain the water. I turned the breaker to it on and off, shut off the water supply and tried to cycle it but no luck. I can...
If this is a new install where there was no dishwasher before. Or if your garbage disposal has been replaced. Then the plug in the garbage disposal inlet for the dishwasher drain may still be in place. You will have to disconnect the dishwasher drain and see if the inlet is clear. If not the garbage disposal will have to be removed, the plug punched out and then reinstalled. Good Luck!
Jul 24, 2009 | General Electric GSD2400NWW Built-in...
My quiet partner 4 will no longer drain, I recently replaced my garbage disposal & the problem began after that.
There is a plug you have to remove on the garbage disposal where you hook up the washer drain hose.
Check the instructions with the disposal.
You'll have to deinstall the garbage disposal, remove this plug and reinstall.
May 05, 2009 | Dishwashers
GE profile Dishwasher less then 1 yr old
There is a drain hole in the side (probably) of the garbage disposal which must be manually "punched out" in order to attach the hose from the dishwasher to the garbage disposal and thereby allow for draining. Think of this as the dishwasher piggy-backing on the existing drain system for the sink/garbage disposal. I am certain this will solve your problem.
Sep 28, 2007 | GE 24 in. Profile PDW7800 Built-in...
Dishwashers Logo
141 people viewed this question
Top Dishwashers Experts
