Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Error code C-3851 Tried the following Hold down [Utility/Counter] while turning the main switch on. Press [Reset] on the touch screen, and turn main sw. off/on. But no luck.
3 Suggested Answers
sir fixalot
  • 146 Answers
SOURCE: service error code c3451
I emailed you the instructions. You should have no problems.
Posted on Sep 17, 2008
at the side where there is the network port look for the reset switch.
press it and the machine will start to reboot again.
when the screen shows the Minolta logo, press 3 and and you will get a screen that will prompt you for a password.
enter 0000 and press end.
touch the reset icon on the screen and the machine will start to reboot again.
this will reset the fuser temperature error.
Posted on Mar 28, 2012
Miolta c300 c3851
Fuser Error. Could be fuser or bad power.
May need firmware and/or software switch setting in service mode.
Change software setting. Service Mode System 2 Software Switch Setting
switch no: 50
bit assignment: 00000001
hex assignment: 01
May 21, 2014 | Konica Minolta bizhub C250 All-In-One...
Error C3102
The Fuser is not turning... follow these steps
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key. Keep holding it till the T reset appears
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, wait 10 seconds and turn the machine back on, this should reset the service code and with any luck the machine will run!
May 03, 2014 | Konica Minolta Bizhub C451 Copy-print-scan
Konica minolta bizhub c350 c-0500 display
Fuser warm up failure. Most likely this will require a service person to repair but here is the reset procedure you can try yourself. If it does not reset then you will need a service technician.
Turn off the main power switch located on the right side of the copier, NOT the one on the edge of the operation panel. Press and HOLD the utility/counter button on the control panel. While holding this button down continuosly turn on the main power switch. Continue holding the utility counter button until the screen changes to a blank screen with just a box that says "trouble reset". Now release the utility/counter button and touch the trouble reset box. Now turn off the main power switch for a few seconds then turn the machine back on. The code should be gone but if a problem remians then the code will come back within 30 seconds.
Good Luck and Thank You for using Fixya.
Dec 01, 2010 | Konica Minolta DiALTA Di200 Copier
Error c3851 appears on screen
Try the following Hold down [Utility/Counter] while turning the main switch on. Press [Reset] on the touch screen, and turn main sw. off/on
or
download the user manual for more detail HERE
Good Luck,
plz do rate the solution if it helps
Nov 28, 2010 | Konica Minolta bizhub C250 All-In-One...
C 3821
Hi geosegr,
Can you confirm the code is C-3821.
Because it's not one that I recognise.
There are only two C-38xx codes, they are C-3851 and C-3852.
Both of these codes relate to the fusing section.
If it were me, I'd have a look in the fuser area to make sure there is no paper stuck. Then you'll need to reset the code. To do this,
Turn OFF the Main Power Switch.
Turn Main Power Switch ON while pressing the Utility/Counter key.
After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If the fault code reappears, you'll need to get an engineer to look at it.
Hope this helps
Jan 28, 2010 | Konica Minolta bizhub C250 All-In-One...
Error c3451
this is a fuser temperature too low error code could be the thermistor or heat lamp is not comming on to reset the error code turn the main switch off the main switch is located on the left side opf the machine towards the rear and while holding the utility/counter button down turn the switch on hold the utility /counter button down until trouble reset appears on the touchscreen then release theutility button and touch the trouble reset button then turn the main switch back off and wait at least 10 seconds then turn it back on if the error code comes back have the fuser unit replaced
Nov 09, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Biz Hub c250 gives error code 3452
C3452: Pressure Heater Trouble.
Try to reset it like this:
Shut down from the main power switch (the one behind the front cover).
Keep pressed the Utility/Counter button.
Power on while the button is kept pushed.
Release the 'Utility/Counter' button only when you see the 'Trouble Reset' button on the touch screen.
Touch the 'Trouble Reset' button, a small ok should pop up underneath.
Power off, wait for a few seconds and then power on.
Jul 13, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
The printer has stopped functioning all together.
C3851: Abnormal Low Temp. (Heater)
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Mar 31, 2009 | Konica Minolta bizhub C250 All-In-One...
Service error code c3451
Sep 12, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
BizHubC253 error code c3821
This error also occurs after a paper jam or a steep power change. If error continues after doors were properly closed and the printer was turned off and on again, it'd be necessary to reset the printer and release it from trouble status.
Turn off the main switch (1/0 botton) but keep the control panel on. Wait 10 seconds. Press and hold Utility Counter botton on the Control Panel while turning on the main switch. Hold it until a white screen with a black dot over the upper rigth corner appears, then release it. Wait for a "trouble reset" botton on the control panel and then manually click on it. You'll see an arrow pointing to an "OK". Now turn off again the main switch, wait 10 seconds, and turn it on. Error must be gone.
May 03, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
392 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
