Question about RTO PasLode 900420 Impulse Framing Nailer
Need to replace nail tension spring part no 76
  • David Ford
    David Ford May 11, 2010
    for what brand and model number, let me know and I will try and help.
Problem solved time and patience required
Posted on Feb 08, 2010
How do I re fit the spring that keeps the tension on the nails
If there is a scroll spring inside and its kinked then its must be replaced, usually there is a collet in the frame where the scroll spring is on on the picture maybe right under the technical information sticker.
that collet must be must be beaten out with a punch
Apr 30, 2016 | Air Tools & Compressors
Ism coil roofing nailer will not hold nails in striking chamber after they advance
The feeder area of the nailer incorporates small levers on both sides of the nails. On the body side, the spring loaded feeder retracts and pulls forward the first nail. On the latch side small spring loaded arm/s hold the nails in place once they are pulled forward. Open the latch and push on both the feeder and the retanier for firm spring tension. On some nailers, due to wear, the grippers on the feeder tend to wear off allowing the nail to slip out of place. On other nailers, the feeder arm/shaft tends to wear and alows the feeder to move out of alignment (check if the actual feeder arm can move from side to side). The feeder shaft should move forward and back with no side to side movement. Finally, some coil nails are welded together with too stiff of wire. After the first nail is driven, the second nail will have one or two strands of wire pointing out not allowing the nails to move into position. After first shot, the two wires should be cut off or bent down out of the way. Good luck.
Nov 02, 2012 | Air Tools & Compressors
DOESN'T FEED,IT MIGHT MISS SHOOT A TIME OR TWO THEN GET A NAIL THEN NOT FEED.I'M SHOOTING A 1.5"TECO NAIL. ANOTHER GUN DOESN'T SHOOT EVERY TIME LIKE THE DEPRESSOR ISN'T LETTING THE...
Usually miss feed happens when the driver does not return to top position not allowing the nails to feed into position. Easy to check, point nose of nailer up then down again to see if the driver is loose in the cylinder. If loose, the driver will be in the down position when the side door is opened. If driver is down, replace driver oring. If driver oring is good, look for spring tension on feeder and check feeder spring on the door side. If piston oring good and feeders have good spring tension, suspect lower bumper cracked(remove head and piston to check bumper).
On gun with depressor (safty foot) not actuating trigger, look for worn trigger (trigger inner lever could be worn) or loose or worn firing pin in the trigger valve above the trigger(valve # tva6). Replace as needed. To check for proper gun action, remove the nails, remove the 3mm roll pin holding trigger and dry fire the gun by depressing the tigger pin. Good luck
Sep 21, 2011 | Stanley Bostitch Coil Framing Nailer
Nailer will shoot a nail, but will not foward the next nail. Gun is new maybe 15 lbs of nails or so.
If the nail will not advance, easy test will determine problem. Open door and remove the nails. Lightly tap the nose of the gun against coiled rubber hose or soft wood with door open. If the driver falls to bottom, the piston oring needs to be replaced. The driver should stay at top of cylinder. Next pull back the feeder to rear position and check for tension. The feeder should spring back towards you when you push. Finally, the check paws on the door should return to extended positon when you push on them. Replace springs as needed. Connect air to gun and rapidly bump fire the gun against rubber. The feeder should move back and forward just as quickly as the driver moves. Good luck
Aug 25, 2011 | Hitachi NV45AB2 78Inch to 134Inch Roofing...
My hitachi nv45ab2 roofing coil nailer misfires and only shoots every third nail
Hitachi coil roofing nailer will skip nails if the piston oring is worn, the feed spring is weak or lower bumper is cracked. Easy to check. Remove nails and air supply. With side door open point nose of gun up then down again. If the piston moves up and down in the cylinder, replace the piston oring. If piston does not move and is in the up position, check the feed spring for tension. With air supply removed and door open, slide feeder back and press on feeder from door side to check tension. It should spring back to position against rails.If is feels loose, replace spring and retainer pin if the pin is worn. If piston oring is good, and the feeder has good spring tension, suspect lower bumper and the plastic part below the bumper called the "sheet". Remove head and pull the cylinder to examine lower bumper. Parts are available at www.toolpartsdirect.com. Good luck with your repair
Aug 09, 2011 | Hitachi NV45AB2 Roofing Coil Nailer
Tool skips
Aug 04, 2011 | Hitachi NV45AB2 78Inch to 134Inch Roofing...
I have pulled my impulse nailer apart so I can replace the nail tension spring in the handle and am unsure how to remove the clip that keeps the tension
it is a push on nut and to remove you would probably damage the nut along with the button that it is pressed on, if you can cut the push on nut you would at least save part of tool. after replacing spring I used a socket and GENTLY tapped the push on back into place to secure it.
Feb 21, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Run but will not cut
Are you sure you have Andis A5 or did you mean Oster A5 Clipper, if this clipper is A5 Clipper, You need to check the Lever for wear, The front of the Lever show wear on both side, Like white color and is not squad this Lever is worn. Need to replace. This Lever moves the blade side to side fully. if the Lever is worn the blade will not move fully side to side and the cutter blade the smaller blade will stay in the middle with hardly no travel to side to side and will not cut the hair even if you purchase new blades. Also I would like to mention if the Oster Locking Hinge is worn out and don't have the require tension to hold the blade in place the blade will not cut. How do you test the Oster Hinge on a Oster A5 Clipper,
(1) first close the hinge, in close potion with your finger nail try to open the Hinge, if the hinge slightly open or opens loose the Hinge is worn. if the Hinge is good it will not open or move and your nail may just brake your nail.
Many of my customers run into this type of problem, and the problem can be solve easily by checking these parts first.
One more item I would mention here if replace the A5 Hinge make sure you get the A5 Hinge not the Oster 76 Hinge they are driferrent, The A5 Hinge has on the back two wire's sticking out that fit on the Oster Latch for the A5 Hinge, the Oster 76 Hinge would not have these wire's on the back. I recommend replacing the Latch when you replace the Hinge. I hope this helps any body that have a A5 Oster clipper or A Oster 76 Clipper.
I have over 20 years in the repair business of Sharpening & Clipper repair. Mannys Sharpening 323 263-4697
b61c252.jpgOster Hinge
Jun 10, 2009 | Andis Outliner II Hair Trimmer
Feeding nails
Your nailer shares design features with Milwaukee and Ridgid. All three brands experience the same issue. Lets go thru a series of simple tests to determine the problem. First and most simple test, manually load the nails and fire the gun untill miss-fire. Upon mis-fire disconnect air, open latch and check if the driver is all the way up into the cylinder or is partially down blocking next nail. If driver is down blocking next nail, replace the driver oring and retest. If driver is up all the way, remove nails, reconnect airline, leave latch open and fire gun against rubber (old tire or coiled up waterhose/airhose) this time holding the gun down and keeping the trigger depressed. In this position, the driver will remain down and feeder will remain retracted. With feeder retracted and screwdriver in hand carefully check the spring tension on the feeder (should be rather firm tension on spring and the feeder must retract with good force). If no tension or weak, replace feed spring. When you finally release the trigger, the driver will retract and the feeder should return with good force. If feeder does not return with force, replace orings and spring behind feed piston. If all tests are ok, remove head, check lower bumper in gun for cracks or missing pieces. Replace as necessary. Lube all orings with silicone lube available at Lowes in the plumbing department. (Danco brand) Good luck on your repair and email your questions.
May 06, 2009 | Porter Cable Cable RN175AR Reconditioned...
1999 serpatine belt
Hi,the serpentine belt is tensioned automatically by means of a spring loaded tensioner,this is released by using a long 1/2 inch extension bar which fits into a square hole, once pulled back the tensioner can then be held by a nail etc, which is inserted into a hole which aligns with another hole,thus holding the tensioner back in a pre-loaded position to allow you to replace the belt,once replaced you can then pull back the extension bar to remove the nail again and then slowly let off the tension, IF replacing the tensioner, The new one comes pre-loaded with a pin in location to hold it ,hope this is of some help, Bill.
Feb 20, 2009 | 1999 Saab 9-5
RTO PasLode 900420 Impulse Framing Nailer  Logo
120 people viewed this question
Top RTO Air Tools & Compressors Experts
John Trevino
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
