Disc tray does not stay in machine when closed but cycles back to open position.
  • joc999 Feb 07, 2010
    It's a Sony model CDP-C5F.
  • 2,335 Answers
What is the make and model number of your CD player?
The more information you provide, the more accurate our advice can be.
Posted on Feb 08, 2010
  • 3,230 Answers
Well first of all you can tell us the brand and the model number of your cd player, so we can help you in details...... anyway it's a tray mechanical problem and it you need to replace the tray assembly parts.... please reply to get more help or information........
Thanks
Posted on Feb 07, 2010
Model fw-c555-01 problems opening
You get the tray out by releasing the retainers. Then cycle the unit so it is in the eject mode position and with the power off on the unit insert the tray so that all the gear mesh and the tray can go all the way in. If it goes partially in then the mechanism must be adjusted so that the tray can make it all the way in. Turn on power after than and check in and out before using a disc. If the unit does good with no disc then use a test disc just in case there is still a problem.
Dec 26, 2012 | Philips Audio Players & Recorders
LG DRT389H will switch on OK but the disc draw will close when a disc is loaded, but comes straight out again and will not play.
Hello
There is a loading motor and a belt associated with it, connected to a gear wheel assembly that pulls in the disc tray as well as gets it out. If the loading belt, said above, will get loose, the disc loading tray wont get into it properly. There is a sensor switch fitted inside the loading mechanism, which senses the proper tray in action, as this tray will touch it when it ahs been fullly loaded. Due to any reason, the switch said above does not engaged properly, the main system control IC will detect the loader position to be improper, and will give command to eject the tray. That is now happening to your DVD player.
If you have knledge and experience, just open your DVD player. locate the loading belt, and repalce it with a new one. You can buy this belt from most of the electronic sparepart selling shops at your town. Just keep the old belt in hand as a sample, when you go to buy a new one. OK
WISH YOU A HAPPY PROSPEROUS 2012
Gopakumar G, Trivandrum City, Kerala State, South India.
Dec 27, 2011 | Televison & Video
I insert a movie from the video store in the dvd player Zenith DVC2550.It got stuck in back and turn table was rotating without picking up the disc. I had open cover to remove the disc. I manage to close...
It sounds like you jammed the door gear which must be closed prior to playback. You can try to take the cover off again and cycle the insert mechanism but if you put much force on it the machine may be destroyed...
May 05, 2011 | Zenith Televison & Video
Hi i have pyle pltsn74 is slip in a dvd disc an it was working when i ejected the disc it stayed in side an tray error came up on the screen i push the reset button an it did not work i carefully open it...
Disconnect the power to the unit; perhaps pulling the radio fuse out - in the fusebox. Then put the fuse back in because you've got to reset the error.
Nov 12, 2017 | Pyle PLTSN74 Car Video Player
Disc tray won't stay closed.
I fixed this by jerking the tray gently. Someone jammed my tray and it skipped a few gear teeth. It seemed like the machine couldn't pull it in far enough to reach its preset position. So I let it close and when it was almost closed, I gently jerked it out to skip the gear teeth back into alignment. It is kind of tricky because the motor will just reverse instead of skipping teeth (you'll hear the plastic clicking when it skips). Perhaps unplug it and slowly push it in manually then **** it back out softly. Just be gentle. Good luck.
May 16, 2009 | Pioneer Televison & Video
Jammed tray
Hi there, had a similar problem.
This unit is easy to open. the four screws on the sides and two i think on the back. When it is open you will have access to the discs in the machine. the last disc will probably be jammed between the facia and the caddy and will be impeding the carousel mechanism, once removed you should check the functions starting with eject, and again to cycle, load disc position 1 insert disc and check. this player i think rotated the disc on loading to a set position, would have to open one to check. hopefully the carousel is not out of sync and all is well.
May 01, 2009 | Sony CDP-C265 CD Player
Disc will not close
TAPE THE THING THERE LOL JK WELL IF YOU WANT YOU CAN ROFL
Jun 01, 2008 | Microsoft Xbox 360 Console
Disc tray
The best way, my brother found out is to turn the console into a different position like if it's laying flat flip it up or vise-virsa.
Mar 23, 2008 | Microsoft Xbox 360 Console
Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Dec 03, 2007 | Sony DVP-NC650V Multi-disc DVD Player
Sanyo 6100 dvd player-disc tray automatically opens whenever power is on.
you should try inspecting & servicing the tray transport mech first and then the tray sense swt.
Dec 08, 2006 | Sanyo DVW-6100 DVD Player/VCR
109 people viewed this question
 Grubhead
Grubhead
