Hoover 1200 performa dosnt seem to be getting hot? the drum feels cold when washing, any ideas?
  • Washing Mach... Master
  • 3,463 Answers
Morethqan likely a faulty heater element, this is located a t the bottom rear of drum, remove rearr panel of washer to access, you will need a meter to test it.
Posted on Feb 07, 2010
Hoover performa 1100 ac110 not emptying
After syphoning water out of drum, remove and clean filter located at bottom front left of washer, if there is a screw in the filter cover, unscrew this first.
Remove filter by unscrewing anti-clockwise.
Feb 06, 2010 | Hoover Washing Machines
Not enough Water in Washing machine
i think the problem came from a rins water is little
1- you will check the pressur of water inlet it is easy throuw the soap drawer
2-try to clean the inlet water filter by teeth brush
good work thanks
Jun 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hoover performa 1200 bangs when spinning.
it sounds like you spider as broke you will need a new drum as they are not bolted on
Jun 21, 2009 | Kenmore 24872 Top Load Washer
Maytag performa washer hot/cold now reversed
Try moving hot hose to the cold side and c old hose to hot side on supply side. this should correct your problem
Feb 26, 2018 | Maytag Performa PAV2200
User guide for hoover performa eco 1200
http://service.hoover.co.uk/manuals/Manuals.aspx?Section=10
go to that website to get an online manual for any hoover machine. the performa eco is a WB120.
Mar 26, 2009 | Washing Machines
Washing machine will not fill with water maytap performa - will not fill w/ water - keeps running. Solutions?
water valve on back bad?try it on cold then cold warn then hot and see if you get anytihing,let me know more-mike
Sep 27, 2008 | Maytag Performa PAV2200
Cold Water 25-May-08
I know this may seem a little silly of me to ask but have you checked the filters in the back of water valves to see if they are blocked??
May 24, 2008 | Hoover AL120 Front Load Washer
Washing machine problem
I have a performa 1100. No 4 is the 40 degree is the normal cottons cycle which is the one I use. Tip- only fill the drum 3/4 full otherwise it struggles to drain and spin- I know!
Jan 21, 2008 | Hoover PE235 Front Load Washer
Maytag performa washer hot water runs continuously
dudett, uplug the washer and turn the water valves on. If the washer is filling with the washer unplugged the valve is bad. Part number 22001196. Not a hard job. If you need help installing, just e-mail the cat here at catriver1@gmail.com Catriver..post back.
Feb 19, 2007 | Maytag Performa PAV2200
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
