Question about Whirlpool Duet GHW9150P Front Load Washer
On the display it says f11 - Whirlpool Duet GHW9150P Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F11 is a Serial Communication Error which means that the communication between the Central Control Unit (CCU) and the Motor Control Unit
(MCU) cannot be sent correctly. You’ll need to:
• Check Wire Harness connections to the MCU, the motor, and Central Control
Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 07, 2010
After a power outage, what is causing my Frigidaire stove to beep and display an F11 code?
Thank you for your inquiry, Katherine!
Based off the information you have provided your Frigidaire range is displaying an error code of "F11". An "F11" error code stands for a shorted keypad I would recommend performing a reset on your range. You can do that by flipping off the household circuit breaker for at least ten minutes. If that does not correct your issue it could be a possible problem with your EOC (Electronic Oven Control) or wiring harness. Hopefully this information is helpful for you. -Matt
Apr 23, 2015 | Frigidaire Kitchen Ranges
F11 error code
I appreciate the post, dan moore!
From the information you have provided your Frigidaire range is displaying an "F11" error code. Typically, the "F11" error code stands for a shorted keypad. This could be a false error code and the best way to clear any false error codes is to disconnect power from the range for at least ten minutes. If you continue to get an "F11" error code you may need to replace your EOC (Electronic Oven Control), I would recommend having a professional technician come out to properly replace any electrical component to avoid personal injury. Hope this information is helpful to some degree. -Matt
Dec 14, 2014 | Frigidaire Kitchen Ranges
Instructions to reset a nordictrack cardio track watch
You may have started wearing a Polar F11 Fitness heart rate monitor to help you keep track of your pulse during cardiovascular exercise. The monitor consists of a strap with electrodes that you attach to your chest, which transmit heart rate data to a receiver worn on your wrist like a watch. The wrist unit stores data and settings that you can customize, such as your weight, height and target heart rates. However, you may wish to reset the unit and start over with new settings. You can reset your Polar F11 by following a few easy steps.
Instructions:
    • Press any button to activate the Polar F11 Fitness heart monitor unit.
    • 2 Press all buttons on the Polar F11 Fitness heart monitor simultaneously, except the "Light" button. There are five buttons and the "Light" button is at the top left side of the unit. Continue to hold the buttons until the display fills with digits.
    • 3 Press the "OK" button, which is located on the right side of the unit in the middle of the up and down buttons. The Polar F11 Fitness heart monitor will reset.
  • Oct 02, 2011 | Nordic Track NordicTrack Treadmill, A2550
    INSTALLED ILLEGAL WINDOWS 7 AND WANT TO GET A LEGAL VERSION OF XP BACK ON MY E-MACHINES EZ1601
    a hard drive recovery
    Restart your computer.
    Press F11 repeatedly when the message "Press F11 to start recovery" is displayed.
    The recovery will load and display a menu of options
    I hope this helps
    Jun 19, 2011 | eMachines EZ1601-01 PC Desktop
    We are geting a F 11 code on this Model number plgfmz96ecc
    Your F11 error code is displayed below. It would be best to have the unit serviced by a professional for this type of fix as if not performed properly, the fix could end up costing over $500.00.
    F11
    Shorted Keypad.
    1. (F11, 12 & 13) Disconnect power, wait 30 seconds and reapply power.
    2. (F11, 12 & 13) If fault returns upon power-up, replace EOC.
    EOC = Electric Oven Controller
    Jun 13, 2011 | Frigidaire PLES399EC Electric Kitchen...
    Card full displayed on Fujifilm F11
    try to format the card from the camera itself then it will be ok.
    Dec 09, 2009 | Fuji FinePix F11 Digital Camera
    Fading LCD display on Polar F11
    I have this problem as well! I was just googling this problem when I found your post. I have the exact same watch and have had it for 2 years. I don't expose it to the sun or heat though.
    Jun 13, 2009 | Polar F11 Heart Rate Monitor
    Polar F11 ''Scrambled/Smudged'' Display
    You have to replace the battery with the new one. In most cases underpowered battery causes faded or even disappearing digits on LCD unless your watch has been damaged by water. Find your nearest watch repair shop or do it yourself. Do not forget to rate, please.
    Jan 21, 2009 | Polar F11 Heart Rate Monitor
    Polar F11 blank display
    Sounds to me as the integrated circuit has been damaged.
    In this case you will not be able to repair it yourself as watchmakers skills needed.
    Dec 13, 2008 | Polar F11 Heart Rate Monitor
    Whirlpool duet wahsher
    The following list of codes indicates an electronics communication problem with the washer:
    Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
    Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
    Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
    PLACEHOLDER FOR ART
    To remove the error display, press Pause/Cancel twice.
    If Pause/Cancel does not work:
    1. Unplug washer or disconnect power for one minute.
    2. Plug in washer or reconnect power.
    3. Re-select the cycle and press Start.
    NOTE: If the error remains on the display, then call for service.
    please do not forget to rate and comment about your experience with fixya today.
    Aug 18, 2008 | Whirlpool Washing Machines
    Whirlpool Duet GHW9150P Front Load Washer Logo
    12 people viewed this question
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
