Question about Refrigerators
Crisper has humidity
Fruit crisper has humidity on inner top shelf of crisper. Has humidity control but still has humidy how do I get rid of the humidity
  • 4,793 Answers
Wipe with dry cloth ,this is normal.......or veg would freeze........
Posted on Feb 08, 2010
I have a westinghouse fridge freezer and it has a humidity drawer/crisper for the fruit and veges
then turn the dial at the top of the unit to a lower number . READ your manual
Sep 25, 2015 | Westinghouse Refrigerators
Why is my top shelf freezing up so easily
When opening the freezer door on a hot humid day, you allow this hot humid air inside that freezes on very cold surfaces. Cool your home with AC, it will get rid of the excessive humidity to reduce your freezer problem. The less time the freezer door is opened also helps to reduce the ice buildup.
Sep 06, 2015 | Freezers
There is water collecting continuously at the bottom of my fridge under the crispers. Do you know how I can fix?
Most frost free refrigerators take water from the freezer so you do not have to defrost the freezer. That being said there should be a drain under the crisper. Check to see if it is clogged.
you may need to put something under the refrigerator to collect the water..
Jan 03, 2015 | Refrigerators
Shttered crisper glass shelf- where to find replacement Model #CBT1521ARW. Please help
crisper shelf removed for cleaning but will not fit when trying to replace the shelf
Sep 07, 2010 | Magic Chef CTB1521 Top Freezer...
Items in refrig are freezing when they're not supposed to.
thermostat has failed i'd say..its not turning off at the requested temp.
Jul 24, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
Vegetable or fruit do not remain fresh they decay within a week
whats is the refrigerator temperature that you are running, it should be around 34-36 degrees inside of the refrigerator. also wqhat is the humidity levelthat you are running in the vegetable crisper? that shoupld be on highest setting for humidity.
Jan 13, 2009 | Freezers
Kenmore bottom freezer model freezes veggies in the crisper
i never go by that / just hold my finger over the air port and move it till i feel move air or less to set it the way i need it ,,, less air puts less air into crisper to cut down on freezing
Nov 26, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Bracket holding glass over fruit / veg compartment broke
http://www.partselect.com/Schematics/Maytag/54436.gif Maybe this diagram will help you. www.partselect.com I just replaced the Crisper Shelf Frame. I received it very quickly. I am now looking for some sort of support for the whole shelf, because it still seems to be sagging. I may have to invent something. If anyone out there has a solution, please post it.
Aug 26, 2008 | Amana ARB2217CSR Bottom Freezer...
Refrigerators Logo
127 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
