Question about Clarion DRB2475
Trying to install clarion drb2475 into my car I have a installation wire adapter the speaker wires are a no brainer but the other wires are making me wonder. The radio harness have left a black(ground), Red(switched), yellow(fulltime for memory), and brown and a black ground. The aftermarket harness has- 2 yellow, red, brown, and an orange marked dimmer. the 2 yellow connect to the 1 one the radio side, the red to the red the brown to the brown, and the 2 blacks to the black on the radio side?
    Sergeant:
  • 306 Answers
The brown is a mute wire. i dont recomend hooking this wire up
Posted on Feb 08, 2010
I have a 99 Pontiac GrandAm I want to install the Clarion DRB2475...there is 12 wires with the radio and 13 on my adapter...Can you help
the 13th wire on your kit is usually blue (this wire is used for installing after market aplifires, cd/dvd,hdd,recever devices) some cars have this wire in there stalk wireing for there stalk woffers, cd changers, other things this wire is used for telling these devices when to trun on or shut off, volume, other funtions depending on the device
Aug 06, 2010 | Car Audio & Video
Need to know wire color for memory function on clarion car stereo
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
pls rate people arnt rating hope this helps
Jun 23, 2010 | Clarion DRB2475
I need a wiring diagram for a clarion drb2475 car cd player
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
May 02, 2010 | Clarion DRB2475
Clarion DRB2475 mutes when I turn up the volume
Sound like one of your car speakers is faulty, try using the fader and see if it still happens when all sound is to the front or rear and try left and right.
Nov 16, 2009 | Clarion DRB2475
Clarion rdb465d display reads TEL after install, what does it mea
Hello rhowell2,
It sounds like the head unit has a ground on the "telephone" lead.
Make sure that all unused leads are taped off or otherwise insulated against touching other leads or the vehicle frame.
Hope this helps.
Aug 22, 2009 | Clarion DRB2475
Clarion 3475 speakers wired, player wont turn on
The RED from the clarion wire must be hooked up to a switched power source ... that was wired to your old radio, then press the reset switch, and it should then turn on.
May 05, 2009 | Clarion DRB2475
No volume
The Bose system in the Z is wired to control the entire car's speakers. Each speaker has its own amplifier, and the OEM head unit puts out a line-level signal to each amp. Your Clarion unit puts out speaker-level signal (in effect, an amplified signal), into the Bose amps, and it's probably overdriving them and putting them into shutdown.
Your best bet is to replace the Bose speakers with aftermarket speakers meant for a speaker-level drive (which is what I did in my Z, and never once regretted it). If you do so, you'll need to run new wires to the speakers, or if you use the OEM wiring, you'll need to unplug the amps and run the wires from the amp harnesses directly to the new speakers. I think there is an adapter harness you can use that will tap into the line-out jacks on your Clarion, so that a line-level signal can be sent to the Bose speakers - I'd do a google search for "Metra harness 300zx" or something along those lines (Metra makes the lineout harness adapters - I use one in my Audi).
Sep 16, 2008 | Clarion DXZ755MC CD Player
Automatic Antenna
sounds like a new aerial is needed, if noone has messed with the wiring...
get someone to turn on the radio while you listen near the aerial...
if it sounds like it is making an effort to work then it could be the nylon runner...
if it doesnt make a sound check the power & earth connections at both ends, behind the stereo & at the antenna.
some have 3 wires power,earth & switched.
some only a switched & earth.
Dec 27, 2007 | Clarion DRB2475
Manual
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Jun 20, 2007 | Clarion DRB2475
Car Audio & Video Logo
519 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
