Problem with Prestige Appliances Audiovox Prestige Code Alarm Remote Alarm Protx6
how to deactivate a prestige car alarm
Posted by avatar on Feb 07, 2010
Solutions (1)
remove the fuse in the main harness going in to the alarm unit under the dash, if you have a starter kill feature you may need to bypass this. you will need to make up a jumper wire and place it in pin 30 and 87 on the relay
Suggested Solution (3)
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
MSB....
  • by Author image chocolatee Over a year ago
    • By avatarkarr550 Mar 28, 2011
    • yes it works d way it should.
      thanks
Source: Free programming instructions for Prestige remote
Was this solution helpful?
No
Yes
go to google and write this> audiovoxtechservices press enter,and in that website request a password to get the instalation manual
  • by Author image Ramiro Reynosa Over a year ago
Source: I need the diagram of alarm Prestige model: APS95BT3
No
Yes
ALRMM SHOULDN'T GO OFF IN STORMY WEATHER UNLESS U GOT A LEAK SOMEWHERE OR YOUR SENSOR IS TO SENSITIVE
  • by Author image clkautosound Over a year ago
Source: how to put the prestige aps25ch 1200 foot range in valet mode
No
Yes
Add Your Solution
See all Prestige Appliances Audiovox Prestige Code Alarm Problems
