Question about Garden
Stihl 210C Chainsaw. Will not idle. what are three adjust holes on the side,which adjust idle and mixture?
    Sniper:
  • 82 Answers
As per previous solution - owners manual located at http://www.stihlusa.com/stihl_ownersmanuals/MS210230250_Manual.pdf
details carb adjustments page 46-48
If this helps please leave feedback
Posted on Feb 07, 2010
Could some help me with factory carb settings on this saw
Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
store.chainsawr.com/.../tuning.../1126042-adjustment-and-tuning-of-a-c...
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws ... These saws have what is called a "fixed jet" which is set from the factory.
Stihl Chainsaw Carburetor Adjustment - Tune-up Settings
tekindoor.com > MISC
Stihl chainsaw's have three carburetor adjustment screws (LA) Idle Speed screw - This ... When the engine is tested at the factory the carburetor is set to obtain a ...
How to Adjust the Air and Fuel on a Stihl Chainsaw ' Home ...
homeguides.sfgate.com > ... > Adjustable Mortgage Rates
The fuel/air mixture in any gasoline-powered engine is regulated by the carburetor, and the carburetor in a Stihl chainsaw is factory-adjusted to provide the best performance.... You'll find three adjustment screws for the carburetor, usually located under the air filter cover.
Factory carb setting on Craftsman 2.0 or Poulan Micro ' Firewood
Dec 04, 2015 | Garden
Stihl 015 chainsaw
Adjust the air/fuel mixture. Look at your owners manual or online because it gets a little tricky because of climate changes.
Aug 12, 2014 | Stihl Garden
Stihl chainsaw problems
Adjust the high speed screw on carb
Install a new spark plug
Use fresh fuel
Aug 05, 2014 | Stihl Garden
Esco chainsaw model 162
The adjuster screws on a chainsaw carb are fuel screws,not air screws, so by unscrewing them anti clockwise will richen the mixture, there are normally three screws, an engine idle screw, this will operate against the throttle spindle, a screw marked L, this will adjust the fuel mixture from idle to half throttle including acceleration, and a screw marked H, this will ajust the fuel mixture from half throttle to full revs, as this will increase the maximum revs it is very importent not to exceed the manufacturers no load speeds, so a engine tacometer should be used to check this, over speeding can seriously damage the engine.
May 06, 2013 | Garden
What do you mean by LA in the chainsaw?
Locate the adjustment screws near the carburetor labeled with an "H," an "L," and an "LA." The "H" screw adjusts the high speed fuel-air mixture; the "L" screw adjusts the low speed fuel-air mixture; and the "LA" screw adjusts the idle speed.
Jan 14, 2012 | Stihl Saws
Scorched pistons in a STIHL chainsaw - and its not the fuel mixture
What side of the piston is scored? If it's the exhaust side, it's running too lean, ergo, it's the mix ratio.
Nov 16, 2011 | Stihl Chainsaw 42mm Piston Rings 025 O25...
How do you adjust the idle on th poulan p3314 gas chainsaw and is there a special tool you need it just wont idle
Most poulan chain saw have three screws idle, high, and low.. if you look air filter cover you will usually see three holes and the high and low will usually have plastic covers on it.. adjust the low 1/4 of a turn and the idle screw in about 1/4 or until the idle picks up... On the plastic cover where the three holes are you will see H which is High L which is Low and I which is Idle... Let me know if you have any problems.. thanks
Jul 16, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
There are three adjustments to the carbureter of the stihl wipper snipper model F585AV. One being the idle adjustment. one of the other two is the mixture adjustment. Question is, which is the mixture...
Low idle speed is one and high speed screw is the other. The idle screw is usually the one located closest to the throttle plate (closer to engine)
Feb 08, 2010 | Home
The owners handbook located at http://www.stihlusa.com/stihl_ownersmanuals/MS210230250_Manual.pdf
has complete details on how to adjust the carb (see page 46-48)
Feb 07, 2010 | Standard Oregon Chainsaw Chain For Stihl...
Hard to start when hot --- ms210 stihl saw
Check the plugs for fouling, or whiting. Could need fuel air mixture re adjusting. Good Luck
Rich
Dec 01, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Garden Logo
282 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
