Question about NAD C370 2-Channel Amplifier
Amplifier switches over to stand-by whilst using cd/disc channels
Low volume on radio, I replaced the amplifier with an used one, but the problem still present. All channels are Ok.
When you tried play a cd and you got low volume with amp, 1. Try find a original cd and plays it see if the sound loud or low if it's still low you need lenses disc cleaner, to clean your decks lense.
Oct 15, 2013 | 2004 Acura TL
I have a AV receiver RX-V440 Yamaha and........
The title of your question reads "I have a AV receiver RX-V440 Yamaha..." yet you say you are using the manual of an RX 1020L. I will try to provide a suitable answer for both receivers.
First, a "MON" connections on an amplifier or switching unit is normally used as a line level OUTPUT from the amplifier or switch. Line level outputs are sent to RCA connectors on other TVs or amplifiers (or switches).
"MON" should not be wired directly to the OUTPUT of anything trying to "playback". It should be connected only to things that can record or allow you to see or hear what the amplifier is outputing.
Now to answer your question:
The RX-V440 is a 6.1 channel Home Theater Receiver. If you stand behind the receiver and look at the left hand side, you will see 12 RCA connectors (2 L/R by 6 high). The top 2 connectors are labeled "CD". The next set of 2 connectors are labeled "IN/(PLAY)". The third set down from the top are labeled "OUT/(REC)".
You can connect the reel-to-reel output to either CD or IN. If the reel-to-reel has a selector switch, set it to "Output" and not "Monitor". If the reel-to-reel has volume controls, set them such that music causes can be heard when you select CD or IN on the RX-V440.
The RX 1020L is also a multi-channel receiver. If you stand behind the receiver and look at the left hand side near the center (top to bottom) of the receiver, you will see RCA connectors labeled "AUDIO 1" through "AUDIO 4".
You can connect the reel-to-reel output to either of these. The primary purpose for "AUDIO 3" and "AUDIO 4" is to allow you to hear component video input AV1 and AV2. If the reel-to-reel has a selector switch, set it to "Output" and not "Monitor". If the reel-to-reel has volume controls, set them such that music causes can be heard when you select one of the "AUDIO 1", "AUDIO 2" or whatever on the RX 1020L receiver.
Nov 21, 2017 | Audio Players & Recorders
When I insert disc into player its visible that disc is running on radio display, but no sound at all. Dont know where is the problem, any hint? Thank you
Is the sound working fine for the radio? If so, are you using an amplifier? If you are using an amplifier make sure you are using the blue/white wire (amplifier remote turn on) instead of the blue wire (power antenna remote turn on). The blue wire turns off when leaving tuner mode.
Jul 06, 2011 | JVC CH-X400 12-Disc CD Changer
What external speakers do I need for the RP8078? Where can I get them?
Hello
You cannot connect it diretly to speaker. It has only preamplifier output for left and right channels, and an optical output to connect it to digital input sources. You must have an amplifier and speaker system to connect it with. It can be any type and brand you like, according to your taste and finacial capacity. Amps can be of cheaper to high quality type. This device can be connected to a digital amplifier, with optical intput, frome which it will convert the signal upto 8 channels or more. But the cost will be sometimes 200 times to the cost of your present device you have revealed here. OK.
Mar 10, 2011 | RCA RP8078 5-Disc CD Changer
SUV500 2-Channel Amplifier: Hi! can I connect another technics cd-player,sl...
yes you can connect another cd player to the DAT input of your amp.
input connections like DAT, TUNER, CD, AUX etc (except phono) is just to differentiate between what sources are connected, the amp cannot tell what source is connected and will output the sound no problem.
as for the remote operation, if the 2 technics cd players are switched on at the same time they're going to do what you command from the remote together but you'll obviously be listening to 1 at a time.
May 17, 2010 | Technics SUV500 2-Channel Amplifier
How many watts is it
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/kac528.pdf
Page 7 of the manual gives you all the different configurations of this amp, and it's MAX power. FYI; Kenwood rates their amps at MAX power, not clean. Hope this helps.
Sep 30, 2009 | Kenwood KAC-628 Car Audio Amplifier
23HCV87 DVD problems
May be dirty lens get a cleaning disc for cd player and insert to clean then try player again. If you can take cover off insert disc see if disc spins,if not spinning you need a motor drive.
Nov 24, 2007 | NAD C320 2-Channel Amplifier
NAD C340
Hi There,
In a sound system there is an input selector switch which just connects the input socket you want to use to the "common" amplifier electronics inside...You say that the CD is fine so in this case it must be a faulty selector switch or broken copper tracks or wires inside the chassis electronics which connect those inputs.. through the selector switch to the amplifier circuitry.
The fault lies between the selector switch and the input sockets that dont work.....Not the CD one of course... thats fine..
Cheers From YUBEUT
Oct 13, 2007 | NAD C350 2-Channel Amplifier
NAD C370 2-Channel Amplifier Logo
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
