Question about Car Audio & Video
Car engine signal light wont turn off
  • Anonymous Apr 21, 2009
    check engine light stays on
  • 24 Answers
Are you talking about your turn signals if so you probably have a bulb out
Posted on Mar 08, 2008
Harley sportster headlight and brake light work but not the turn signals. Engine lights does not come on and bike wont start
The soft click sounds like the starter relay. Check that out first and see that current is getting through when it soft clicks. ARE there any codes set??? What led up to this???
Apr 14, 2014 | 2004 Harley Davidson XL 883C Sportster...
I have a 1998 GMC Jimmy, put a different engine from a 1996 gmc jimmy in it, its been running great and here about 2 weeks ago it started giving me problems, I put the key into the ignition turn it to...
the signal flashing is a bad hazard switch. they all brake. if you hold the flasher buton just the right way the noise stops. sounds like your dash is shorted with the flasher
Mar 13, 2013 | 1998 GMC Blazer
Brake lights wont work. I have changed the bulb. Autozone says it the engine management & ignition. How do i change out the part?
CHECK BRAKE LIGHTS FUSE.IF OKAY BRAKE LIGHT SWITCH BAD OR TURN SIGNAL SWITCH FAULTY BECAUSE BRAKE LIGHT SWITCH AND TURN SIGNAL SWITCH SHARE THE SAME CIRCUIT.
Jul 06, 2010 | 1998 Chevrolet Cavalier
Engine cranks but wont start
Usually if no rpm signal, the vehicle won't start. Engine cranking, did you check for spark at the spark plugs? The fuel pressure you listed may have been the initial prime. It sounds like no injector pulse. The rpm signal comes from crank sensor. If your missing rpm signal, may thought is the crank sensor.
Were there any applicable trouble codes?
Apr 06, 2017 | 2001 Ford F150 Styleside SuperCrew
2004 Grand Prix turning Signal lights wont work.
YOU HAVE TO REPLACE THE TURN SIGNAL SWITCH.BECAUSE WHEN IT GOES OUT.SOME TIMES YOUR DIMMER SWITCH STOP WORKING.IF YOU GOING TO FIX IT YOUR SELF BESURE TO.DISARM AIR BAGS FIRST.
Aug 19, 2009 | 2004 Pontiac Grand Prix
My guages and turn signals wont work in my dodge 2000 caravan although the panel lights up
check all of your fuses inside car and in the engine bay and replace the signal globes.
Jun 23, 2009 | 1997 Dodge Caravan
Brake lights wont flash and turn signal wont flash
turn on the turn signals without turning on any other lights, first left, walk around the car, and see if there is a light that is not functioning, then right, and do the same. If there is a light that is not functioning, replace the bulb.
If all lights work, then its the unit flasher unit itself, and can be baught at a parts store, and is easy enough to replace in the fuse box of most cars.
Apr 14, 2009 | GMC Envoy Cars & Trucks
Left signal lights wont shut off all back running lights off
sounds like a turn signal switch on the column
Apr 04, 2009 | 1997 Eagle Talon
Turn signal wont work 1999 cadillac eldorado E.T.C
start with a fuse, then go on to a turn signal relay. turn the level left or right on the steering column with the inginition switch on, if the light in the dash lights up but won't flash, it is the turn signal relay.
Aug 10, 2008 | 1999 Cadillac Eldorado
Car Audio & Video Logo
89 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
