Question about AEG 24 in. Favorit 40850 Free-standing Dishwasher
My dishwasher is a AEG 40850, will not heat and dry the disches?
I had this problem too, and was able to fix it. There is a generic problem with AEG dishwashers of this type, caused by the bad solder joint of a relay on a circuit board. Solution:
1. Disconnect mains power then open dishwasher and remove the 8 or 10 screws that hold the inox plate onto the door.
2. Gently peel away the inox plate and you'll have access to a white plastic box at the top of the door where the pushbuttons are located.
3. Undo the 4 plastic clips on the sides of the white plastic box and you'll have access to an electronic circuit board. Note the order of the 6 or 7 wire connectors along the edge of the circuit board and then unplug them. The circuit board is now only held by a flat plexi connector. Leave it attached.
4. Gently turn the circuit board over and look at the solder joints. You should see one or more dodgy solder joints. Use a soldering iron and some extra solder to redo the joints.
5. Put it all back together in reverse order to above.
This is a known problem (that no one knows about).
David.
Posted on Mar 27, 2010
The door on my aeg 40850 dishwasher is jammed shut. How do I release the latch or remove the door?
remove the top two screws at back, lift up about 5 degrees pull back, then you wll see the latch pins remove bolt/s,lift up trim{if it has some} and the door will open then remove inner door screws to get the front panel off to get at the latch
Jun 30, 2012 | AEG 24 in. Favorit 40850 Free-standing...
My dishwasher has stopped heating the water and is washing cold with obvious poor results. Is it a heater matrix problem or something like that? It is a Tricity BendixDH200
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 07, 2010 | AEG 24 in. Favorit 40850 Free-standing...
Water not heating on AEG Favorit 40850.have replaced heater but still not heating.any suggestions
I too have had this problem. I switched to the hottest setting from the economy one and it heated again. Once I switched back it was OK for sometime but has started to do this again.
Jan 30, 2010 | AEG 24 in. Favorit 40850 Free-standing...
AEG Favorite Compact 525. The pump runs continuously even when the on/off button is pressed. Tho only way to stop it is to turn the power off at the socket/plug. any ideas
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak)
Mar 10, 2009 | AEG 24 in. Favorit 40850 Free-standing...
AEG Favorit 40850
yes its the flood sytem control underneath you might have a leek like i did it was the heater leaking
replaced it and now its running ok its a eay job to replace
Jul 02, 2007 | AEG 24 in. Favorit 40850 Free-standing...
AEG 24 in. Favorit 40850 Free-standing Dishwasher Logo
829 people viewed this question
Top AEG Dishwashers Experts
paul
paul
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
