Question about Epson Stylus CX5400 All-In-One InkJet Printer
Unable to print
Whenever I want to print something, my printer works, but no ink in put on the paper. Help would be gladly appreciated. clean heads--multi-times, align heads,checked nozzles cartridges each at 30%acc.,to readout removed cartridges and reinstalled--charged, called Epson--says refilling cartridges a no-no--done this for  about 3 years---no problem till now(?)
  • 1 more comment
  • CJ1981 Feb 23, 2008
    I have cleaned the heads, changed the cartriges, cleaned the nozzle, an still get blank sheets.
  • angel59 Mar 01, 2008
    I have exactly the same problem and I ran the Head alignment; the nozzle check andthe head cleaning changed the black in to brand new, the color inks are all at 60%. Please help
  • Cazzzmo May 11, 2010
    how do I access that hose to check?? also, please explain the soaking process or point me to a previous instruction/solution. thx!!
I have the same problem. Epson will only give me a discount on more junk through the SPECIAL Loyalty page with a password.
After googling all the printers reviews,
I have no reason to buy another Epson....EVER!!!
I found the following page which seems to have helped many people.I will tackle this chore this weekend.
Its seems easy to follow.
Good Luck I hope it helps.
applefritter.com/node/17681
Posted on Mar 28, 2008
Nozzles are clogged keep soakin and repeat make sure downtube ink hose is connected!Try a few solutions and hot water repeat
Posted on Feb 29, 2008
Will not print, gives error oxco5do281, ink problem
Paper jam would not be related to ink problem. printers sense ink via photo cells or magnetic sensers. paper path is mechanical. It sounds that your cartridge is not fully in position, for whatever reason. Hp Printers are better at accepting refill cartdriges than some. But has to be done correctly. But feed problems, are mechanical.
Dec 02, 2013 | HP Photosmart 3210 Printer
Unable to print or copy, see troubleshooting 51
The error means you have a paper jam or one of the sensors is incorrectly reading a paper jam. Unplug the unit and check all areas for a jam. Remove the back Jam Clear Cover and check inside there. Remove the Paper Tray and check that area and check if the PE actuator is in place behind the paper tray. Lift the scanner flatbed unit and check inside the print carriage area. Look for scraps of paper at the sides of the platen. These scraps that may be soaked with ink and difficult to see. You may need to move the print head to see both sides.
If the PE actuator is missing, contact Brother for a replacement. Put in the replacement if needed.
Close the scanner unit, replace the clear jam cover (put it on correctly) and replace the paper tray. Plug in and turn on the printer and see if the message clears. If it doesn't clear, access the Ink or Ink Management menu (either directly by a single key or through the menus). Do a test print for Print Quality (Color). If the quality is good, press 1, the up arrow or + key to select Yes. Then press the Stop/Exit button. If the print quality is poor, clean the print head.
If the jam message occurs again, check for more scraps of paper inside the unit as above. Make sure your paper meets the specifications for the printer and isn't getting excessively humid. (Paper will pick up moisture from the atmosphere so keep only the needed amount in open reams or the paper tray.) Fan the paper in the tray and then return it to the paper tray. Make sure the paper is flat in the tray and that the guides are just touching the edge of the paper.
If it still doesn't clear, the unit needs service.
I hope this helps.
Sep 14, 2010 | Brother MFC 240C All-In-One InkJet Printer
Unable to print
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 27, 2010 | Brother MFC 6490CW InkJet Printer
Paper jam error
Hello there
Apr 26, 2010 | Epson RX595 Photo All-In-One Printer
Unable to put printer "on"
First pull the cartridge out and check the comm strip on the cartridge and the printer, Ink could have split on the comm ports ,, try to clean the ink off with alcohol on a cotton swab, then let dry and replace cartridge, then turn on print and try to print it out.
Apr 20, 2009 | Computers & Internet
Samsung CLP 510 - won't print on photo paper.
Have you changeed the PAPER type to (specialty or card stock) this always work for me. Your printer will have these setting
Aug 31, 2008 | Samsung Office Equipment & Supplies
Clean unable 51
Ok Please follow this link and it has your answer.
Please rate me when it was a FIXYA
May 03, 2008 | Brother Multi-Function Center MFC-240C...
Unable to print.
NO-ONE REPLIED TO THIS THIS PROBLEM YET.Please someone should know something????
Jan 26, 2007 | Canon Selphy CP510 Thermal Photo Printer
Unable to print
The problems is not the cd for installed and my printer psc 1315 no instaled. Because the computer is repared.
Dec 21, 2006 | HP PSC 1315 All-in-One Printer
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
Epson Stylus CX5400 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
