Question about Euro-Pro 1260DX Mechanical Sewing Machine
How to thread I have no manuel - Euro-Pro 1260DX Mechanical Sewing Machine
How do you thread the machine?
Search the internet for a manual:
Manufacturer + Model + the word "Manual"
or search YouTube videos for a machine similar to yours and follow the threading example.
Nov 16, 2015 | Sewing Machines
With no manuel/thread tension solution?
tighten up the thread tension on the needle thread tension setting
what you describe is a result of the needle thread tension being too loose
to get manuals go google and type in -- workshop manual for ( make and model) sewing machine
there will be pdf version downloads if they are available
Oct 11, 2015 | Kenmore Sewing Machines
Upper thread keep breaking
http://www.brother-usa.com/VirData/Content/en-US/HAD/Consumer/UsersManual/UM_PC_6000_EN_2572.PDF manual is at the above web site
Jan 26, 2014 | Brother PC-6000 Pacesetter
I have a capital model 777 about 40 yrs old. The top thread keeps breaking when I try to use it and the manuel no longer can be found. Can anyone help?
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Jan 07, 2013 | Husqvarna Sewing Machines
Need beginners manuel for 1541-s Industrial Sewing Machine
Contact your seller or Juki and ask for a threading diagram.
Sep 01, 2012 | Juki Sewing Machines
I have a 1950's era New Home sewing machine. I do not have a manuel. I have had this machine about 35 yrs. I have always had a problem with the tension. Now, apparently, the thread is somehow...
Most common fault threading the machine without the presser foot being in the up position so the thread goes completely between the discs
Aug 27, 2011 | Sewing Machines
Need to thread machine-no manuel
most common machine have in threading process,I ve holding different brand sewing machine they only differ is in design but the process are commonly same,start bobbins winder to wind threads
  • pull thread from spool on top of machine insert bobbins winder disc then rotate on bobbins winder 4 to 6 times manualy put it on the shaft winder locate at top of machine near handwheel,push the latch against to bobbins winder to fit,then release clutch handwheel by pulling handwheel to disengage motio only winder will rotate when you press foot pedal and start winding thread on clockwise rotation.if this filled insert bobbins winder to bobbins case and pull the end of thread inserting to the slot of bobbins case observe should have tension on this.e5b8d97.jpgas shown and dirction of thread.inset this on the shuttle case.then start looping thread on top of machine as shown22d0eb9.jpgthen start adjusting tension on tension dial you can see in fig.Set dial at # 3 at start of set up ,Stich adjustment at #8 to 12 adjust gradually.
the hook up the lower thread bobbins from lower shuttle by threads on needle then insert cotton fabrics manualy rotate handwheel until needle the fabrics freely don't apply foot pedal let it shown if the neele sew freely w/o looping under bobbins let sew manualy until it appears stiches on fabrics,if ok continue now aply foot pedal
gradually until you familiarize again the sewing.
Mar 14, 2009 | Bernina Sewing Machines
Don't have manuel with instructions on how to thread a bobbin & thread machine. need diagram on how to thread.
http://pcmonkey.co.uk/jsm-download.com/manuals/English%20Maunals/pf2100%20english.pdf
found this in one of our other post.. hope it helps...
Mar 06, 2009 | Yamata FY900 Mechanical Sewing Machine
Manuel
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
May 26, 2008 | Janome L-344 Mechanical Sewing Machine
Shark Euro-Pro Sewing Machine
I had the same problem with my Shark Euro Pro 7133. My problem was in threading the upper thread. The manual does not quite explain so I had to figure this out the hard way.
In threading the upper thread . the thread first goes down from the spool througt a groove. When it comes up it must catch a silver lever that moves up and down before moving it down againPlease let me know whether this helps.
Jan 29, 2008 | Sewing Machines
Euro-Pro 1260DX Mechanical Sewing Machine Logo
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
