Question about Motorola Mobility RAZR V3
Phone will charge in the house but will not charge on car charger.
My phone will not charge in the car on two separate chargers. But it will charge with the house charger.
    Scholar:
  • 121 Answers
I would test the car charger with a different phone charger in the lighter slot to make sure the lighter slot works.. if it does then it looks like you'll need to order a new charger or i call the manufacturer... double check to make sure there aren't any updates your phone may need too...d
Posted on Feb 22, 2008
Lost power charger will a telephone charger with the right dc voltage work? jazz hdv188 also its a usb jack in camera instead of the little round holed one
Some phones charge the battery in the camera like a phone, but many do not. The USB connection is meant to be used to transfer photos from the camera to a computer. If your (now lost) charger was plugged into the camera to charge it, and it plugged into the USB connector, then you can charge the camera with any lead that will fit the USB connector, as this will have a standard voltage. You can even charge it from the computer, without buying a separate charger.
However, if your charger charged the batteries outside the phone, by removing them from the phone and placing them in the charger, then it is very unlikely that they will charge in the phone, whatever you connect to it. I have a camera just like this, that requires an external charger.
Oct 29, 2010 | Cameras
My battery wont charge on my motorola rival i bought a new battery and it still wont charge.
If your phone does not seem to charge. It is as a result of either the charger or the charging port.
To test if it is the charger;
Try to use a tested okay charger on your phone.
Try your charger on another phone to see if it would charge the phone.
If it does not work,then it is the charger.
All you have to do is to replace the charger.
Test if it is the charging port;
Try to use a tested okay charger on your phone,
If it does not charge the phone,
Then it is the charging port that has a fault.
To fix the charging port;
  1. get the appropriate screwdriver,
  2. remove the back cover, the battery and the sim,
  3. Then you will remove the stickers, you will find some screws at the angles of the phone, unscrew them,
  4. Run an object like a credit card around the line across the phone and apply a little force to separate the stainless part of the phone,
  5. You will have access to the panel of the phone,
  6. Try to locate the charging port of the phone,
  7. Disconnect it and replace it with the new you got for it,
  8. Reverse the process to reassemble the phone.
Take care
Jun 21, 2010 | Cell Phones
Charging problem
Buy a new charger. If your computer charger works, and either your house or car charger are not working it is whichever is not charging the phone that is the issue. .
May 06, 2010 | Motorola Mobility SLVR L7 Cellular Phone
MY PHONE DOES NOT CHARGE ON THE WALL CHARGER ONLY VIA USB ON THE PC. WHATS WRONG
If it uses a separate connection for the charger, try cleaning the contacts (a toothbrush works well for this) on the phone and the charger plug. If the charger plugs into the USB port on the phone, I's suspect a bad charger.
Nov 26, 2009 | Sony Ericsson XPERIA X1 Smartphone
Samsung Memoir not charging when Charger plugged in.
Why is'nt my phone charging ? when i plugged it in ,it says battery temperature is too low or two high. I replaced the battery and it tells me the same thing. please help. It is a
Samsung Memoir
Aug 21, 2009 | Cell Phones
My phone samsung d900 is charging up witout charger installed
The charging port on your D900 may be broken. Have you tried a different charger first?
You have 3 options when the charge port breaks.
1. get it repaired, under warranty if possible
2. Get a new D900
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on Ebay.
For more information and links to the parts check the following link below.
Fix for Broken Charge port on Samsung SGH-D900
Jun 03, 2009 | Samsung SGH-D900 Cellular Phone
LG shine wont charge
Zoe-
The charger port is going bad. It happens over time The symptom of this is you have to hold it into place.
The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.Youcan get an external battery charger to charger the battery separate fromphone. An extra battery is a good idea as well so you canhave one charging at all times. The best and cheapest place to buy a new charger for yourshine is ebay. They run about 5 dollars shipped. Check out thefollowing link for the selection.
LG Shine Battery Charger
I hope that helps
Jan 31, 2009 | LG Shine CU720 Cellular Phone
Samsung D900i
It is probably the charging port. It seems to be a common issue with this model of phone.
If it is the charger port on th eD900, You have 3 options.
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay
Samsung SGH-D900 will not charge problem
Aug 29, 2008 | Samsung D900i Cell Phone
Car charger lights up but phone does not take charge
try charging your fon in your house outlet. if it works then your car charger is defective. if still your fon wont charge in your house then your fon has a prob in its charging section.
Oct 08, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
108 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
