Question about Mitsubishi WD-52631 52" Projection HDTV
Hi, I have WD-52631 model Mitsubishi projector tv. I recently bought a replacament lamp for it but it came without its housing. What can I do with this now? Can you just take out the old lamp from its housing and try to place this one in that one's housing? Would you need special tools for this? Thanks
  • rhan78 Feb 07, 2010
    Yes the old housing is welded closed, there is no opening on it. I can force open it but I am not sure if that's a good idea. I tried calling Mitsubishi help but nobody's picking up the phone. The last option is to buy a lamp already assembled but that would mean I just wasted 150dollars on this lamp. What do you think?
    President:
  • 2,923 Answers
If the part number of the replacement lamp that you've got is the same with the part number of the old one, yes, you could use the housing of the old lamp. You need to use a flat screw driver to open the housing.
If you couldn't find any opening to replace the bulb, contact the vendor and see on how you can open the housing. I'm sure they know how to open it.
Good luck and have a great day!
Posted on Feb 07, 2010
  • Melvin Ramos
    Melvin Ramos Feb 07, 2010
    I see. I think that the lamp that you've got is different from the old lamp. The new lamp that you've got is designed to fit with housing that you could open up to replace the lamp.
    But the old lamp appears to have a disposable housing. Try to contact again the store where you bought the lamp so that you could return the lamp or replace it with another lamp that has its housing.
    Thank you!
Outer screen scratch
Mitsubishi is currently offering the following parts
Model Number Model Description Part Number Part Description Price Available WD-52631 52" DLP TV I/B WD52631 OWNERS GUIDE $15.00 YES WD-52631 52" DLP TV I/QR WD52631 QUICK/REF WD52631/57731/65731 'G' $3.50 YES WD-52631 52" DLP TV 915P049010 LAMP (150W) (V33/V33Y/V33+) 'G' $249.00 YES WD-52631 52" DLP TV 290P137010 REMOTE 'G' $33.10 YES
Mar 27, 2008 | Mitsubishi WD-52631 52" Projection HDTV
How can you diagnose a failed lamp in a Mitsubishi DLP WD 52631
Remove the lamp and do a visual inspection.
If this is a DLP you may have a bad color wheel! whistling sound is a sign of color wheel.
Good luck to you
www.aaatvservice.com
May 08, 2012 | Mitsubishi TV Lamp 915P049010 for WD-52631...
Misubishi wd-52631 DLP TV, it shuts off suddeny. when turn it on again, the green power light is flashing, then steady green, then shut off again. the lamp light is NOT falshing or red. the status light...
Hi, have you replaced the lamp after 2-3 yrs of usage? The lamps used by mitsubishi tend to last around 4000 hrs 1-3 yrs.It is common for the green light to light up.Other common failures are the ballast which is the board that powers the lamp.Also check if its not overheatin, dust out the fans.Heres where u can get the lamp or ballast http://www.discount-merchant.com/SearchResults.asp?Search=wd-52631
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
I have a Mitsubishi WD-52631. Picture will not come on. You hear the fan kick on and a whistling sound for a few seconds and then it powers off. After it shut down I pressed the INPUT and MENU buttons...
You need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 11, 2010 | Mitsubishi WD-52631 52" Projection HDTV
WD-52631 Audio works, but no picture
Probably a bad lamp. This is the first thing I would try....especially if the lamp has not been re[placed in awhile.
Oct 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi tv solid yellow light how to fix
willshar2, by the way... nice tv, your tv chassis is a v33 chassis try the lamp sensor pt#299p313010a it's on the lamp housing,but again i wish you would let your favorite tv guy do the work.
Jun 11, 2009 | Mitsubishi WD-52631 52" Projection HDTV
Smell from mitsubishi wd-52631
Hi...maybe I can help. Go back in and make sure your lamp is connected to the ballast. If it is not all the way in, it will smell like it is burning. Sometime it will even burn out you lamp and or ballast too. Good luck
Mar 28, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Mitsubishi WD-52631 52" Projection HDTV Logo
76 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
