Samsung HC-P4752W rear projection television
We were watching television and the screen started acting up. The brightness did not change, but it's like the screen "split" into two seperate pictures on top of each other that aren't aligned. For example, bad weather map has green map on top with red map under it offset a bit to the side.
I have used the self focus feature with no results. I tried the DVD and the picture is the same.
Please help!
The convergance amps have failed you need to have them replaced there are 2 of them and some resistors may be affected. the cost of this repair can reach $350.00 depending on the tech you get. this is the most common failure in rear projection TVs. the convergance amps work very hard and are bound to fail. they also have very large heat sinks to keep them cool. heat is the biggest enemy of transistorized ICs.
