Question about Mountain Shimano Tourney 6/7 Rear Derailleur Direct Mount Bike
Gears slipping whilst pedaling - Mountain Shimano Tourney 6/7 Rear Derailleur Direct Mount Bike
  • 73 Answers
You need to adjust the tension on the derallieur, you can log onto shimano.com and follow instructions, it is simple enough the way they show it, if not then search derallieur adjustment
Posted on Mar 27, 2010
I just put a new slave cylinder and clutch master cylinder on a 2003 Honda accord 3.0 V6 six speed and you can shift the gears without the clutch pedal pushed in or the car started
that is normal if the gear synchro dogs ( teeth) are in line in the box
problems concerning a clutch are
slashing gears when trying to engage first or reverse with the pedal to the floor ---needs bleeding
slipping when the clutch pedal is released--- slipping clutch from the pressure not being released ---problem in master cylinder
reverse gear is the only gear not synchronised so even with the clutch depressed it is possible sometimes that it will not go into gear unless you let the clutch up to move the gears in the box then attempt to re-engage reverse
May 04, 2016 | Honda Cars & Trucks
2002 mini one wont go in gear whilst engine running, clutch seems perfect never slipped low bite, brutal force required to try engage and still wont go in
this indicates that the clutch plate is not properly disengaged with he foot on the pedal
If it is hydraulic I would be checking for air in the system of faulty master cylinder
More costly problems may be oil grease on the clutch linings causing it to stick or drag, spigot bearing in the rear of the crank shaft seizing up, rust or dry grease and dust on the splines of the input shaft preventing the clutch plate from moving
All or any of these require a box removal to fix
if clutch is cable operated then the cable may be failing and stretched resulting in the clutch not disengaging properly
Apr 01, 2015 | Mini One Cars & Trucks
What allows clutch to slip so much to not move car.
-Possibly time to replace new clutch.
Good luck
mai
Nov 10, 2014 | 1990 Toyota Camry
1998 GS manual Previa with 140k on clock. Has recently started slipping in 4th gear - if changing up from 3rd or down from 5th its asthough something isn't engaging and no further power from the car can...
Sounds like your transmission has come to the end of its life. You can try getting the transmission flushed , and an additive I.E. No Slip added. That might cure some of the problems but obviously if its slipping the clutchs inside are worn out and transmission needs an overhaul.
Mar 15, 2011 | 1996 Toyota Previa
Slipping gears
Your chain and drivetrain is probably worn out.
Read this...
http://www.sheldonbrown.com/chains.html
May 03, 2010 | Cycling
How do I know when to replace the clutch on my 1999 Mazda Protege ES. Currently, it works, but I have to press the pedal all the way to the floor, with some force, to start the car. No check engine has...
whilst it works leave well alone ,when its slipping thats when you will need to replace the clutch,check the inhibitor switch on the clutch pedal though
Apr 16, 2010 | 1999 Mazda Protege
1998/99 Dodge Dakota clutch and manual transmission problems
clutch needing replaced, very common on all manuals
pedal travel adjustment,yes
gear shift adjustment,no
May 12, 2009 | 1998 Dodge Dakota
Gears are slipping
The first thing you should try is to change the transmission fluid and filter.If this doesn't help let us know and we walk you through it. Good luck.
Jan 21, 2009 | 1988 Audi 80
Mountain Shimano Tourney 6/7 Rear Derailleur Direct Mount Bike Logo
593 people viewed this question
Top Mountain Cycling Experts
Michial Gueffroy
john h
Are you a Mountain Cycling Expert? Answer questions, earn points and help others
