Question about M-Audio US85100 Keyboard
It doesn't turn on!
Idk why it's not turning on. I have it connected to my computer and there are still no blue lights that turn on. I think it died :(
  • Anonymous Jan 25, 2009
    LIke the original poster, I too am having problems with my keyboard.  The computer is working fine.  The keyboard just won't turn on.
    Problem Solver:
  • 10 Answers
Sounds like the main flex cable that connects everything may have become disconnected. My A1226 does this periodically. The fix for it is to take out the case screws so you can access the logic board. The heat resistant tape (amber tape is probably not sticking anymore. Reconnect the flex cable at the logic board and put a new piece of heat resistant tape on it to hold it. Then replace all the case screws.
Posted on Oct 19, 2014
    Scholar:
  • 148 Answers
If your Macintosh computer won't turn on, here's how to troubleshoot it. Please keep in mind that although your computer may display similar symptoms that prevent it from showing video, this article discusses what to do if the computer won't turn on, meaning that when you press the power button:
  • You don't hear a startup chime
  • You don't hear any fan or drive noise
  • The power button or power indicator doesn't light up at all
If your computer doesn't display any video, it may display one or more of these similar symptoms when you press the power button:
  • You may hear a startup chime
  • You may hear fan or drive noise
  • You may see the power button or power indicator light up
If any of these conditions occurs, see the Troubleshooting: My computer has no video article instead. If your computer won't turn on, try each of these steps:
  1. Make sure that the power cord is plugged into a working wall outlet, and that it's properly connected to the power adapter. (To check if the wall socket is working, plug in a lamp or other electrical device.)
  2. Make sure that the power adapter is properly connected to the power port on the back of the computer.
  3. Disconnect all accessories that are plugged into the computer, such as a printer, hub, or iPod.
  4. Reset the computer's PMU or PRAM.
    • For a portable (iBook or PowerBook), click here for instructions.
    • For a Mac mini, click here.
    • For an iMac, click here.
    • For a Power Mac, click here.
    • For a Mac Pro click here.
    • For a MacBook or MacBook Pro, click here.
    • For any other computer, click here for instructions on resetting the PRAM.
  5. Try plugging a different power cord into the computer (if you have a working one available). If the computer starts up, replace the old power cord. You can get a replacement cord for some models here.
  6. If the computer uses a power adapter, try connecting a different power adapter to the computer (if you have a working one available). If the computer starts up, replace the old power adapter. (Computers that use a power adapter include MacBook, MacBook Pro, iBooks, PowerBooks, Power Mac G4 Cube, and Mac mini.)
  7. If you tried all of the steps above and the computer still won't turn on, contact Apple technical support (1-800-APL-CARE in the U.S.) or take your computer to your local Apple Store or Apple Authorized Service Provider (AASP) for diagnosis.
Posted on Feb 22, 2008
Camcorder wont turn on at all
Are the batteries fully charged ?
Jun 17, 2017 | Mitsuba DV777 Camcorder
My car doesn't have any power, it starts and drives but will not go over 25mph any suggestions of what it could be? I was thinking maybe a vacuum leak or the mass air flow sensor ??? IDK please help....
Check Engine Light? When a 'check engine light' (MIL=Malfunction Indicator Lamp) is turned on, there is a DTC (Diagnostic Trouble Code) set/stored in the ECM/PCM (Engine Control Module/Powertrain Control Module). This code identifies which engine management system component/function experienced a malfunction. Once you pull/read this code, you may begin diagnosis.
Aug 24, 2011 | 2002 Hyundai Accent
I dont have data cable of nokia 1209 then, how i connect my mobile to my pc ?
you could connect using your bluetooth, just turn on your bluetooth and connect.
Jul 15, 2011 | Cell Phones
1998 GMC Savana conversion van - It starts right up and immediately dies, repeatedly and randomly. Sometimes it won't start for days. Then poof, starts right up. It turns over fine, it starts fine. The...
It won't die when pulling the relay because it has another power path to the fuel pump through the oil pressure switch . Fuel Pump Electrical Circuits Description and Operation watch this video on fuel pump control , shows chrysler first , ford ,then gm . wait for gm an he explains the oil pressure switch . Plus when it won't start ,don't guess or theorize ! Test what's missing ? check for spark , no spark check ignition system , coil's , ignition module , crank sensor etc... has spark ,do a fuel pressure test etc... don't think computer , when it won't start does the check engine light come on with the key on run not start . If light is lit ,nothing wrong with the cumputer . If want to fix cars you really should take some automotive classes . Test don't guess .Watch some other videos crank no start videos etc...
Mar 02, 2017 | 1998 GMC Savana
I have a problems with my Viewsonic vx2235wm, the On/Off button does not always make a good connection in turning off the monitor. I will push it and it will go off and then come back on immediately. The...
press it several times very very quickly, if it doesn`t start functioning the front panel must be opened in a service and the contact cleaned...i don`t think it needs replacement
Oct 28, 2009 | ViewSonic VX2235wm LCD Monitor
Dell computer won't come on...only get yellow light, no blue
If the Tower has a blue light, then it appears to be working, I'd check the cable connection to the video port on the tower and the INPUT Select Button of the Monitor (I've seen people change the input select to DVI when connected analog for example)
Sep 14, 2009 | Dell E176FP 17" LCD Monitor
Monitor doesn´t work
1 MAKE SURE THE DATA CABLE IS CONNECTED TO THE CPU.
2 MAKE SURE TO TURN THE MONITOR ON.
Aug 05, 2009 | Samsung SYNCMASTER 943B 19" LCD Monitor
Hi: My acer56c is eight years old and humms while turned on as well as getting the horizontally linear blue occasional flash across screen.The colors when turned on are not 'initially' accurate(Orange...
if its a CRT monitor then you wont have a problem, the all get decrepid and loose color flicker then eventualy die.
i say use it till it dies then get a new one or get a new one befor it dose damage to your eyes, a nice TFT screen will do.
Jul 03, 2009 | AcerView 56C (White) 15 in.CRT...
Nothing but the blue ring lights up
ok..idk if this will work but it might...first turn off the sansa...then turn the hold switch on (it should turn red). hold down the record button on the side of the player..then while still holding that hold the power button down...but keep holding them untill a screen shows up saying something about recovory mode..itll say to plug in the usb..u could do that..idk it that will work..it it doesnt instead of plugging in tthe usb in the computer..wait about 15 seconds after the recovory mode screen shows up and then hold down the power button for about 15-20 sec...then itll go all black (including the blue light) press the power button again like u would to turn it on...and everything should be back to normal..hope this helps...:)
May 04, 2009 | SanDisk Sansa e250 MP3 Player
Hpzd 8000 does not turn on...it is getting as soon as i turn it on....
My Zd800 did the same thing and I figured out that the power adapter connection was flakey. I move it around in the back and finally the blue light stays on. I actually replaced one power adapter thinking it was out...turned out to be the connection to the back of the computer. I have tried other power adapters and same results. Considering taking the thing apart and soldering the wires. This computer has been a royal pain the a$$ since I bought it. I will try another laptop manufacturer on my next one. Any suggestions?
Aug 16, 2008 | HP Pavilion zd8000 Notebook
Open Questions:
See all M-Audio US85100 Keyboard Questions
M-Audio US85100 Keyboard Logo
857 people viewed this question
Top M-Audio Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
