Question about HP Office Equipment & Supplies
Hp Deskjet F4480 continually reads out of paper even though its not and will not print. This problem occured only after I refilled the cartridges and put them back in.
Ok, I had this problem too and it started after I replaced the ink cartrtidges. The printer had a flashing light and the software read "out of paper". I can't be exactly sure what fixed it but here's what I did: I unplugged the printer while it was still on and left it unplugged for several hours (several minutes should have the same effect of clearing the device's memory, I just had to go to a meeting). I then plugged it back in and the printer fed the paper, but was feeding it sideways. I removed that paper and put a single piece of 4x6 photo paper in it and it fed that paper sideways also, crinkling it up. I tried a few more times by hitting the 'Cancel' button which would cause it to try to refeed the paper. I then checked the back of the printer and discovered the back panel had come loose at some point. I replaced it and the printer then fed a sheet correctly and printed the alignment page. I think the thing that fixed the issue was leaving the machine unplugged for awhile.
Posted on Jun 29, 2010
SOURCE: I can't reset ink level indicator for HP Deskjet F4280
AFTER REFILL PRINTER STAY IN ERROR CARTRIDGE BLINKING
Posted on Jan 28, 2010
  • 4 Answers
SOURCE: How to reset ink cartridges after refilling them
Go to the following website and download the freeware InkMonitor 2.1.2: http://www.pokluda.cz/. You have to add data about new cartridge. HP60 ink cartridge information, 200 pages per cartridge. This works great for me. It gives you a history of everything printed. This way you can gauge when its time to refill your cartridges. You must refill before they run out of ink or you will burn out the print heads and have to replace them.
Posted on Jun 06, 2010
SOURCE: How can I fix my HP Deskjet F4280 cartridge error message?
hi..i have similar problem with anjulyn80..i bought a new cartridge but still got a cartridge error in it..
Posted on Jul 22, 2010
SOURCE: How to refill hp 818 inkjet cartridge
First Hole light cyan, scond hole cyan, third hole megenta, fourth hole yellow, fifth hole light megenta. now check. it will support Photo quality.
Posted on Sep 03, 2010
puertobori
  • 7733 Answers
SOURCE: what does the yellow blinking
Need service!
Posted on Oct 28, 2010
Can you remove the battery from an hp F4480 printer to make it ignore incompatible cartridge message
Unfortunately, this does not work.
With respect to the HP 60 cartridge error message ("Incompatible Print Cartridges") and inability to print with your HP Deskjet F4480 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (which is typical of the 'incompatible error' alert). These same failures can (and randomly do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to A. and B), this will identify which ink cartridge is causing the issue:
Please first verify the age of the ink cartridge(s)....look at imprinted date on front of ink cartridge. If this 'warranty expiration date' has expired, then potential internal electrical cartridge failures can occur due to internal corrosion, etc.
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
            NOTE: To our team's knowledge there is no 'cartridge error bypass' method available for the HP Deskjet printer model. The cartridge will mostly likely need to be replaced with a new one.
            Please note that we provide professional ink cartridge refilling services in multiple countries:
            Costco USA Ink Refill Service (453+ stores): http://www.costcoinkjetrefill.com
            Costco Canada Ink Refill Service (52+ stores): http://www.ca.costcoinkjetrefill.com
            Costco Mexico Ink Refill Service (38+ stores): http://es.costcoinkjetrefill.com/
            Costco United Kingdom (select stores): http://uk.costcoinkjetrefill.com/
            Fry's Electronics USA Ink Refill Service (34 stores): http://www.frys.com/ads/page51
            Best Buy Canada (4 stores) Refill Service: Downsview, Sherway, Toronto, & Vancouver (additional Toronto Best Buy stores opening in Fall 2014).
            Micro Center USA Refill Service (8+ stores): http://www.microcenter.com/site/content/refill-service.aspx
            We also have ink refilling centers in many University bookstores across the USA & Canada:
            Brigham Young University, Brigham Young University Bookstore - Idaho (BYU-I),
            Cornell University (CU), Kansas University (KU), New York University (NYU), San Diego State University (SDSU), University of San Diego (USD), University of Wisconsin - Madison,
            University of Virginia (UVA): http://www.cavaliercomputers.com/inkjetrefill.asp?
            Queens University (Kingston, Ontario, Canada) & University of Calgary (Calgary, Alberta, Canada)
            Refill Store Map Locator: http://www.go2ris.com/#findstore
            Our network of retailers stand behind the product and performance - guaranteed. Customers who have questions regarding the use of refilled ink cartridges can visit http://www.inkjet411.com or contact us directly at INKJET411HELP@GMAIL.COM
            -Thank you
Jun 02, 2014 | HP F4480 All-In-One Printer
My printed output is still streak even though i run a "Clean the catridge" process.. it occured when i refill the black ink cartridge.. what should i do?
Hi
Well you can try to clean the nozzles manually with Warm water
If not try to blow little air from the top of the cartridge so that you can find the ink coming from nozzles not the tiny bubbles.
Once done try to clean it with a news paper or a tissue paper and try to print now it will sure work.
DO RATE MY SOLUTION
Jul 04, 2011 | HP DeskJet F4280 All In One Printer InkJet
How do i remove ink cartridge hp deskjet F4480
Here is a short tutorial about hp deskjet F4480:
http://www.inkjet-laser.com/hp-deskjet-f4480-error-print-cartridge-is-missing-incorrectly-installed.html
Feb 17, 2011 | Computers & Internet
I have a f4480 hp deskjet. How do you reset settings when you refill the ink (black) cartridge? Because even after injecting the ink, I still get the exclamation mark and orange light. And when even...
Some Hp printers, like Epson, require the cartridge to be reset. There is a chip on the cartridge that needs resetting.
This might work;
Place the HP 60 cartridge on a covered surface so that the metal contacts on the cartridge are facing you. Put tape over the top metal contact in the second column from the left-hand side, making sure the other contacts do not get covered. Put the HP 60 cartridge back into the HP printer. Print a test page when prompted. Take the cartridge out of the printer. Leave the tape on the contact that is already covered and also cover the top contact in the column at the far right, making sure no other contact gets covered in the process. Return the cartridge to the printer again. Print a test page. Remove the cartridge from the printer again, remove the tape from the metal contacts, and return the cartridge to the printer. Print the test page and the printer should read the cartridge as full.
Jun 18, 2017 | HP F4480 All-In-One Printer
I refilled HP 88 cartridge but printer (Officejet Pro L7590) still thinks cartridge is empty. How do I reset ink level?
Under the cartridge is a black like pump - on a new cartridge this is hard and rests firmly on an area inside your printer. As you print, the pump becomes softer - this is how the printer determines it is empty. Once refilled, the pump does not get back to the original state. Open the bottom of the cartridge and put a firm solid piece of folded paper in there - make sure it is steady and re-close cartridge. It will now read as full but may also show full - judge ink levels by the quality of print. Also make sure chip has not expired.
Nov 05, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
I have a hp deskjet 3320 printer and i refilled the black and colored ink and it still prints the words out mulitcolored like it is running out when i want it to print out in black
Sounds like your black cartridge has a clogged print head. If you bought a refill from a store or on-line you should take it back and either have them clean it (if they know how) or return it. If you refilled this yourself at home this is a problem that occurs when you let your cartridge dry out before you refill it. You can try and rehydrate the print head by placing it on a warm moist paper towel until you see ink soaking into the towel (ink stains most surfaces so be careful where you do this). Otherwise, I recommend Cartridge World for refills because they go through cleaning and print testing steps to make sure this doesn't happen.
Oct 20, 2009 | HP DeskJet 3320 InkJet Printer
HP Deskjet F4180 Color changes and lines in photo printing
HP always recommend that ink cartridge should be replace by original ink.
As this kind of scenario will occur if the ink will just be replace by a refill ink.
Sep 21, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
Jul 06, 2008 | HP DeskJet 5150 InkJet Printer
1,670 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
