Question about Carrier Heating & Cooling
We have an infinity 96, about 5 years old, has always run well. In the past month, it has shut off overnight twice. The LED indicator flashes code 25, set up error. a simple power off resets it to run normally. Any ideas?
  • 1,420 Answers
This unit stores up to 9 error codes. Follow the directions to retrieve the other 8 to see what is registering. If you are getting a set up error, have the gas pressure re calibrated. There are two or three pressures that need to be set.
Posted on Feb 07, 2010
My 99 infiniti may be an early version? Can't find power steering hose for it.
Hello Bill,
Try looking up parts a year younger according to the manufacturers sticker usually located on the drivers side door or frame. Use the month of June as the dividing line between the two years! If your car was made lets say in March of 1999 it may actually be considered an 1998 model. I hope this helps!
Good Luck!
Rich Lilja
Mar 26, 2015 | Infiniti Cars & Trucks
Sharp aquos LC-60LE640U flashing error code 2-5.
Dont buy a Sharp. Buy a Sony, Panasonic, JVC, Visio, ANYTHING but sharp!
Jan 27, 2013 | Sharp LC-60LE640U 60 Inch 1080p 120Hz LED...
Change the combination on a DHo74E
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777).
You should set the lock to your own unique master & manager code immediately.
Please keep your codes in a secure location. You may also register your codes on our website at www.sentrysafe.com.
A single signal (LED flashes and beeps once) response from the lock indicates valid entry.
A double signal (LED flashes and beeps twice) response from the lock indicates an invalid entry.
• If three incorrect entries are entered in a row, the keypad will shut down for a period of five minutes. During this shut down period you will not get a response from the keypad.
Changing the Master Code
(Code length: 1 to 10 digit code) Always perform this operation with the door open.
1. Enter: # - Existing Master Code - #
2. The set light will stay orange for ten (10) seconds.
3. Enter: 1 - * - New Master Code - # - New Master Code - #, before the orange light disappears.
If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3.
Test the new code several times before closing the door: Enter: * - Code - #
• The lock will indicate a valid code change with a single signal.
• The lock will indicate an invalid code change with a double signal and the old code is still valid.
Changing the Manager Code
1. Enter: # - Master Code or Manager Code - #
3. Enter: 2 - * - New Manger Code - # - New Manager Code - #, before the orange light disappears.
Activate user codes
3. Enter: User ID Number (3-7) - * - New User Code - # - New User Code - #, before the orange light disappears.
If a mistake is made during the activation, wait thirty (30) seconds and repeat steps 1 thru 3.
• The lock will indicate a valid code entry with a single signal.
• The lock will indicate an invalid code entry with a double signal and the old code is still valid.
Example: # - Master Code or Manger Code - # - 5 - * - New User Code - # - New User Code - #. This will activate User Five (5).
Changing the user code
1. Enter: # - User Code - #
3. Enter: New User Code - # - New User Code - #, before the orange light disappears.
The Master and Manager can also change the user codes by following the "Activate user codes" section steps 1 thru 3.
Deleting user codesAlways perform this operation with the door open.
3. Enter: User ID Number (3-7) - * - # - #
Programming your lock codes
Dec 17, 2012 | Sentry Safe Dh-074e Solid Steel Depository...
I want to change the combonation
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777). You should set the lock to your own unique master & manager code immediately.
Activate user codes
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
Philips 37PF7320A/37 won't turn on
That blinking led is an error code for the audio standby board in the set. It should not go out this soon and yes it should last longer.
Aug 21, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Vivitek tv
I have a 56" model that I have had a similar problem. My bulb burned out in <90 days. Warranty was 90 days on the bulb itself. When the TV picture goes out, the indicator LEDS blink on and off.
Here is what you have to determine:
1) First cover the left LED with a piece of paper so that you can't see it blinking. I don't know if your layout is the same as my TV. You may have to switch the paper blocking the LED.
2) Pay attention to the other LED and READ its' flashing code. In my case, the code was 2-3. It would flash 2 times, pause briefly, then flash 3 times. This meant code 23. That indicated the bulb was burned out.
3) If you look in the manual, It does have a code list of some sorts to tell you of the codes and their meanings. Hope this helps.
Nov 20, 2007 | Vivitek V37835 46 in. LCD Television
Optoma hd72 bulb turning off
This is NOT a bulb problem unless your "lamp" LED is lit, which you say it is not. Many people have reported this problem with the Optoma 72. You can send it in for warranty service (it has a 2-year warranty) to get the lamp controller chip replaced, but the problem may recur. Optoma does not appear to have a permanent solution to this problem. My projector has broken exactly like yours TWICE in a year. I haven't even needed to replace the original bulb yet. :(
Nov 05, 2006 | Optoma HD72 Multimedia Projector
Heating & Cooling Logo
197 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
