Question about AEG Washing Machines
How to reset a AEG 76850
Machine is locked for the second time.
First time repairman just did reset for 105 euro.
How to reset this machine myself?
5 Suggested Answers
  • 1294 Answers
SOURCE: aeg washing machine
Click on 'washing machines' (below FIXYA) on this website, & search witrh your model number. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is..
Posted on May 30, 2008
Lumpy816
  • 246 Answers
SOURCE: Fisher paykel washing machine GWL15
Without your model number I can't answer for sure, but for most models of f/p washers, this is the easiest way. First lift the lid and once it is straight up, pull it towards the cealing, it should slide straight up. On the right and left hand sides there are generally 2 "half moon" shaped peices of rubber. Pry these up with a small flat head screw driver. Underneath are phillips screws. Once these are out, the top of the washer should lift up from the front and let you get to the tub (and springs) underneath. If you are still having trouble. Drop me a note back.
Posted on Jul 11, 2008
  • 1462 Answers
SOURCE: AEG WASHING MACHINE
fit hoses at random. put on a rinse cycle. if cold water comes in then hoses are correct. if hot water comes in, then reverse hoses
Posted on Sep 07, 2008
rickead1
  • 1998 Answers
SOURCE: hello i am repair man
when it stops do you still have power to the front panel if there is no power to the panel then you would have a bad connection to one of the control boards. are there any error codes showing when the unit does stop such as flashing lights or an exact er code have you checked the door switch? if the door switch does not work the unit will start then stop immediatley message me back with your finds thanks Rick
Posted on Apr 24, 2011
AEG Lavamat washing machine model 76850, shows a blinking key and makes clicks and after that shows E40. Thanks John
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and any of the option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensing circuit faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
Aug 02, 2014 | AEG Washing Machines
Cycle takes forever and water not heating
FIRST OFF CHECK WITH A MULTI MTER FOR CONTINUITY. THE WATER TEMPERATURE CONTROL SWITCH, THE INLET VALVE, AND UR SO CALLED ELEMENT WHICH I FIND ODD AS HAVENT SEEN A WASHING MACHINE WITH A HEATING ELEMENT B4.
Feb 28, 2014 | Asko W6021 Front Load Washer
Turned off mid cycle. Tried putting back onfor drain, also rinse and restart. Each time get error E40.
Hi.
With AEG washers E40 means defective door lock. Since a faulty door lock switch may go out with vibration you often do not get the error all the time. The door lock switch must be tested and eventually replaced. Call the AEG number listed in the user manual if you want to get in touch with an authorized technician or if you need replacement parts for your washing machine.
Regards.
Ginko
Sep 18, 2011 | AEG Washing Machines
I bought the 385X machine and haven't used it more than three times. Unsuccesful attempts each time. I took it to a local repairman hoping he could do a quick fix (since I can't find my receipt to go thru...
I would call Euro-pro at 1-800-798-7395 and ask them. I have a feeling that it is not your timing at all, I would also go online to euro-pro.com and see their frequently asked questions for your model on left side bottom box, and then look to the right column, it gives all kinds of tips for free. I think it has to do with your threading, are you reading your manual carefully for the threading? Slow down and actually read it. Good luck.
Sep 17, 2010 | Euro-Pro Easy Sewlution 385 Mechanical...
In which way can i reset my dw AEG favorit F 86050 vi?
There are 6 program buttons on the right side of the On/Off button.
Press and hold button 1 2 ( 70
Sep 04, 2010 | AEG 24 in. Favorit 86050Vi Built-in...
Anti-flooding system has activated.
Tip washing machine towards you, water in bottom of machine will pour out, so be ready! Should work after that, mine did!
Aug 23, 2009 | AEG Washing Machines
16820 dryer not working
I suggest checking the moister sensor and or cycling thermostat. the hi limit thermostat as well, with a meter for continuity. other wise you may have a bad timer
Mar 20, 2017 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG OKO LAVAMAT 86741 UPDATE. WASHING MACHINE
I have washing machine AEG 62800 model.
When I tried to start a washing the error E60 was displayed on screen.
The following actions were done:
1. Turning knob to right to first position "COTTON LINES 95"
2. Pressing on all 5 functions except START button (Rinse Hold, Rinse+, Time Saver, Pre Wash, Stain).
Red lights will flash .
3. Pressing on Start button and simultaneously starting to turn clockwise till OFF position.
It will reset error and will release machine.
I'm hoping it will help.
Boris.
Feb 25, 2008 | Washing Machines
Aeg 76669 oko lavamat machine not starting all six lights [pre wash, main wash, rinse, rinse , spin, and end] flashing machine three years old just successfully completed wash cycle, loaded up for next...
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Jan 10, 2008 | AEG Washing Machines
Washing Machines Logo
903 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
