Question about Whirlpool GU2400XTP Built-in Dishwasher
Build-up terribly on heating element
I have this thick build-up on my washers heating element. I've used vinegar which has some a LITTLE but still my dishes come out with chunks of dried black "dirt" particles on them.
Again, I've tried running vinegar through it MULTIPLE times and now am trying CLR.
Any advice would be greatly appreciated.
Thank you!
Mellen
Indianapolis, IN
  • Gary Davd
    Gary Davd May 11, 2010
    CLR IS MUCH SAFER >>IT IS A LIGHT ACID>>THIS IS ALL YOU NEED
  • Gary Davd
    Try a product called CLR is stands for caluicm /lime/rust remover you can get it at the grocery store. It comes in a little gray bottle
Get a gallon of muratic acid at the lumber yard, let the dishwasher fill with water and then add about 2 cups of acid then turn on the d/w and let it mix for a few seconds. then turn it off for about 15 minutes and then restart and let it complete the cycle. after a few days repeat the process. this should clean it up nicely. this is good for cleaning drains also. dont breath the fumes from the acid. dont pour into a stainless steel sink as it will cause discolorazition.
Posted on Feb 22, 2008
I have not used the machine for a while. When I did, a thick pasty substance emitted from the bottom steam vents onto the pas when steaming the floor. What does this mean and how do I correct?
Run a little vineagar and water solution through it. Then all you should run in the machine is distilled water so you dont get that residue and mineral build up on the heating element.
Jan 27, 2014 | Euroflex Monster Floor Steamer
Tip
How to clean the inside of your coffeemaker
When coffeemakers2_bing.gif make only a few cups of coffee instead of the whole pot, it's usually because the heating element is covered with hard water deposits. To fix it, you just need to run white vinegar through it. Put white vinegar in the same way you do water (but don't put any coffee grounds in the basket). Run it as many times as it takes to get all the vinegar out, and then run it again three or four times the same way. After it runs normally, run water through it until the vinegar smell is gone.
The cause of the slow brewing is that the water you normally use has some amount of hardness to it, and over time the hard water minerals build up on the heating element inside the machine. The buildup prevents the heating element from heating the water as fast as designed. The vinegar will dissolve the minerals and let the heater work at full capacity again.
If you want to avoid this in the future, just run the white vinegar through it once a month or so even if it's not running slow.
on Jan 31, 2010 | Cuisinart DCC-1200 Coffee Maker
Tip
What to do when your coffeemaker stops after just a few cups
When coffeemakers make only a few cups of coffee instead of the whole pot, it's usually because the heating element is covered with hard water deposits. To fix it, you just need to run white vinegar through it. Put white vinegar in the same way you do water (but don't put any coffee grounds in the basket). Run it as many times as it takes to get all the vinegar out, and then run it again three or four times the same way. After it runs normally, run water through it until the vinegar smell is gone.
on Jan 31, 2010 | Coffee Makers & Espresso Machines
Keurig b70 platinum motor runs but no water comes out
I have had the same issue with mine. If you fill it up with water and press brew. It only spits out a little to no water but you can hear it running. I found out later on that there was calcium build up on the heating element and through out the lines. I just ran straight vinegar through the machine a couple of times and then let it sit for a couple of hours with it still on. Even thought it is not coming out its still in the lines and it seemed to **** it up. After a while it seemed to be fine and work fine as well. Just have to rinse it out a couple of times with water to get the vinegar from making your coffee taste terrible.
Mar 18, 2013 | Keurig B60 Coffee Maker
Scale build up on heating element
Try white vinegar instead. The same type of scale builds up in drip coffee makers. Most recommend white vinegar to remove the scale that builds up over time. The added bonus is it costs less and is completely safe. If your unit is a water over paper media humidifier, you would be much easier to replace the paper media.
Sep 12, 2012 | Honeywell HM509DG115 120V TrueSTEAM...
Mineral or scale build-up on heating element
Why not try CLR? It is much more aggressive on scale and lime.
You could just use it during a normal wash cycle so it will clear out all the ick inside the unit.
Jul 02, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
My heating element has white scale and build up on it
Hello, You should buy some lime away from home depot ot Lowe's. Put 2 cups inside the dishwasher and run a pots and pans cycle. This should clear up the calcium deposit on the heater. You may have to repeat depending on how bad the build up is. Hope this helps. Mike
Nov 23, 2009 | Dishwashers
My GE washing machine has a foul odor after it has been used
Most likely caused by build up of soap scum. Fabric softeners are the major contributor to this. It causes a thick residue to build up on the outer drum.
Best to get a service technician to remove inner drum and scrape to clean it off.
Once clean Vinegar is good for disinfecting, and Descaler crystals are available, but neither of these will remove the soap sludge which would have built up over time.
Good luck
Ash
Oct 21, 2009 | GE WDSR2080D Top Load Washer
How do I clean the heating elements in my swan tea kettle. it looks like a mineral build up on the elements that comes off when the element is hot and the minerals fall into my tea water
IF THE BUILD UP OF SCALE IS BAD YOU MAY HAVE TO TREAT SEVERAL TIMES TO CLEAN. VINIGER IS A GOOD CHOICE, JUST FILL ABOVE THE COILS AND LET SIT AND DO THIS AS MANY TIMES AS IT TAKES TO CLEAN THE COILS. ANOTHER GOOD PRODUCT IS CALLED- CLR MOST HOME DEPOTS HANDLE THIS PRODUCT IT STANDS FOR C-CALSIUM / L- LIME / R- RUST
THIS IS A LITTLE STRONGER THEN VINIGER BUT DOES THE SAME THING. BOTH WILL TAKE SEVERAL CLEANINGS
Sep 05, 2009 | Swan Kitchen Appliances - Others
Build up or busted?
more and likely it is calcium build up on the unit. especially if your using tap water. even if you cleaned it before putting it away for the season the build up can happen. if it's on the heating coil you need to get like a toothbrush and some vinegar water and lightly scrub the coils. now as far as the tank. let the tank soak in vinegar and water for about a half hour and then wash thoroughly. the portions is one cap full of vinegar per gallon of water.
Aug 20, 2009 | Vicks V5100N Humidifier
Whirlpool GU2400XTP Built-in Dishwasher Logo
102 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
