Question about SMC Barricade 7004VWBR Wireless Router
No connection, cant install the software
I recently got my smc router from a friend, and when i try to install it onto my laptop, it wont work. and when i try to connect to the internet from the router, it connects, but says "with limited connectivity" and i cant use the internet.
  • 2,263 Answers
You said that when you connect the computer to the modem, you get limited or no connectivity. make sure that your computer will be able to go online when you connect it the modem directly.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Posted on Feb 08, 2010
Hi I have an SMC baracade g wireless router and want to connect my samsung galaxy 580 phone to it wirelessly. My computer connection is working. The phone detects it fine and can see that it has WPA/WPA2...
Hi
Try to unplug the power cable of your router for a minute or 2 to re-establish its connection to server. Then try reconnecting to your home network.
Hope this helps
Dec 09, 2010 | SMC Barricade 7004VWBR Wireless Router
Computer wont recognize cable hookup
You will have to start the configuration from the wired network rather than the wireless network. Connect the computer directly to the router. I am assuming you might be trying to configure the router from the wireless network. Then use the installation CD to configure the router
Nov 29, 2009 | Computers & Internet
Cant put a lcok on my smc router
Manual for WBR14-G2 router [6.2 MB] in pdf format:
http://www.smc.com/files/AG/MN_SMCWBR14-G2.pdf
Keeping others from connecting to your router:
1. Have an "wired only" router login access or for this router "change and disable your SSID". This way you avoid that others can login to
to the router changing your settings: See page 48 of the manual.
1.1 Wireless Network Name (SSID): change the default name SMC
to "any private name" ( and remember for later login )
1.2 Broadcast Wireless Network Name: change from default ENABLE
to DISABLE .
2. Make a secure wireless encryption key for your connection:
see page 87.
2.1 For most secure key select WPA / WPA2 only and SAVE SETTINGS .
2.2 See page 91 for entering and saving your secure key: the password
that must be entered to get access to the router.
Sep 18, 2009 | SMC (SMCWBR14-G2) Router
Cannot set up security on wireless router "wireless card nt found
Are you trying to configure the router wirelessly. Connect your computer to the router with a lan cable and then access the router and change its wireless settings. since you cannot change the wireless settings wirelessly as you will get disconnected.
Sep 03, 2009 | SMC Barricade g SMC2804WBR Wireless Router
I cant connect my new laptop to my Tew 432 brp trendnet router
Sounds like you may be having an issue with software already installed on the laptop to control the wireless connection. Many laptops have preinstalled software for their internal wireless devices. You should consult your manual about configuring and saving passwords for a network for that particular device. Typically you will need to enter the WEP key in the software itself.
Aug 23, 2009 | Trendware TEW-432BRP Wireless Router...
Cant connect my SMC to other home computer and have a netgear router, how do i connect my smc adapter
Most hardware like an Network Adaptor you install the software CD 1st. Then plug in the hardware.
Then if you configured wireless (wifi, 802.11) settings on your SMC - you should fine the network NAME when you try to connect. You will be asked for the security key for WEP or WPA or WPA2 that you used in the SMC.
SMC should... then assign IP Settings automatically. If the SMC has Internet, you should have Internet.
Jul 07, 2009 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Unable to get IP address on SMC2804WBRP-G
You need to setup security on the laptop/access point. Apparently it has been setup in the router.
Jan 25, 2009 | SMC Barricade g SMC2804WBRP-G Wireless...
SMC EZ Connect 2862W-G does not see Linksys network
It shows that your wireless router and wireless adapters are both working. One thing to try is changing your wireless channel. Since you are already using 11, try maybe 1 or 9. Check if your SMC adapter will pick up the wireless signal.
By the way, how far is your computer (using the SMC adapter) to your wireless router?
Oct 21, 2008 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Smc router
If you know the part number of your router, you can download needed utilities from this site.
Jul 29, 2008 | SMC Barricade g SMCWBR14-G (662698582192)...
Software malfunction
I assume they told you to uninstall the software, remove the adapter, then re install driver an re insert adapter, as this normally cures the driver fault. If they didn't try that, if the problem persists the adapter may be faulty although i think it's a software problem. Try not to use Windows to repair connection as it never works and resets your pc's ip address differently than your routers already given it.
Jan 24, 2007 | SMC EZ Connect g SMC2862W-G 802.11g/b...
SMC Barricade 7004VWBR Wireless Router Logo
163 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
