Question about Refrigerators
Bought Samsung refrigerator in June 2009, model RB196ABRS. Working fine but there is a water leak behind the veg & fruit drawers. The water seeps from the rear wall at the back of the drawers. I can see where because it leaves a yellow stain. This water has to be cleared out every week in order to prevent it from going outside the fridge (in the freezer section). Is this an easy fix or should I call for service (under warranty).
  • treborsia Feb 10, 2010
    Yes. Because of the work involved, I'm calling a repair man. This fridge is on warranty.
  • 4,070 Answers
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the fridge. If this repeatedly happens with yours, you may can prevent it by taking a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Posted on Feb 10, 2010
The moisture has to be getting inside to pool. Check your door seals or leaving the doors open to long.
Aug 14, 2016 | Samsung RF265AA Bottom Freezer French Door...
Water in the fruit and vegetable draweres
You might have the frig. temperature set too low. Set it at 38 deg. check actual temp. with gage. What happens is ice builds up in the drain tube that runs down to the bottom when the fridge defrosts therefore causing water to run into the veg. drawers. Ice buildup is preventing the water from running out at the bottom where it should. Just raise your fridge temperature a little and the problem should go away. Hope this helps.
Feb 04, 2013 | Samsung RF265AA Bottom Freezer French Door...
WATER DISPENSER HAS STOPPED WORKING, HAD BEEN WORKING FINE THEN JUST STOPPED. WASNT SURE IF FILTER JUST NEEDED TO BE REPLACED OR IF MAYBE THE WATER LINE WAS CLOGGED. THE ICE MAKER IS WORKING FINE,
check your water tank in ref. it is behind veg. drawers.. if water tank is full. might check water soldnoid in b back of ref. there should be two one for ice maker and one for water..ok
Feb 13, 2011 | GE GSH25JFR Side by Side Refrigerator
Some fruits and vegs freeze in drawers, but not all
GE fidge it is a common problem...air dampers stuck wide open..too much cold air going to fresh food side from the freezer..you need to call repair man
!!! but if you still want to do repair by yourself, send me model number i send you some ideas and most important some images...so you can put everything back together after you done :)))
totalcarefl@yahoo.com
Aug 29, 2009 | GE Refrigerators
WHAT IS PLASTIC COIL OF TUBING IN REFRIGERATOR BEHIND VEG DRAWER?
that is the water line that goes out to your water dispenser. it is placed there so that the water that would come out is cold. as if it is the water reservoir.
tnx 4 using fixya,
drcool
Sep 13, 2008 | Frigidaire FRS6HR5JSB Side by Side...
Bottom vegetable/fruit drawer freezing fruit
to the left of the bottom drawer is a veg/meat slide switch.make sure it is all the way on veg.if it is on meat,it opens a small doorway to the freezer and lets the cold air in and will freeze the food in the bottom drawer.in some cases,you will need to remove the drawer and shelf and then take apart the doorway.ball up some putty and jam it it the hole to completely seal it off
Jan 11, 2008 | Amana ARS2661BS Side by Side Refrigerator
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
