Question about HP PSC 2355 All-In-One InkJet Printer
Error message, "scanner failure" "turn power off and on" I have tried this ,but message still appears. cannot scan.
  • 164 Answers
REMOVE THE POWER CORD AND ALL CONNECTION CABLES. lET STAND FOR 2 - 3 MINUTES AND RECONNECT CABLES THEN POWER CORD. tHIS WHOULD ALLOW YOUR PRINTER TO CLEAR ITSELF AND RESET.
Posted on Feb 07, 2010
5 Suggested Answers
hemantraj
  • 638 Answers
SOURCE: Scanner Failure
this is very common problem many users of this type of printer are getting the same problem.final solution for this problem is change the scanner unit.it will cost you between 50$ to 60$ exact. rate this solution as fixya and give respect to our technical experince that saved your precious time.thank u for using fixya.
Posted on Jun 14, 2008
SOURCE: Scanner failure
scanner failure, turn unit off and back on, does not help
Posted on Oct 11, 2008
  • 2692 Answers
I don't want to know anything. I want, (wanted) you to attempt what I had suggested. I am not positive it will work and I did not want you to score me low but would rather have no score at all.
1. Disconnect the Printer/scanner  2. Uninstall the software. START- CONTROL PANEL -either  ADD AND REMOVE PROGRAMS or PRINTER AND FAXS  _ Highlight printer and tell it to REMOVE PRINTER. 3. Hook the printer back up. Run the install software that has the correct driver for the version of windows that you are using.
The HP link for your model that I provided to you is to download the software to install , if you ether have the wrong driver or have lost the install disk ,if you ever had one.      Look at what version of windows you are using and see if the disk states that it is for that version of windows, like Xp, VISTA, 98, etc. If it does not you must download the correct software.      I was attempting to avoid asking all of the needed questions such as; Is this a new problem or have never had the scanner work correctly? New computer or same one? Computer Make and model?  Version of windows that you are using? All of these things enter into a problem such as yours.   I hope this helps. |:)
Posted on Feb 08, 2009
seeker5211
  • 1089 Answers
SOURCE: Scanner error 5
The only fix that I know is to get the scanner/copier assembly(that's the assembly at the very top where the copier is) replaced.
I don't imagine that it is cheap. Get an estimate 1st.
Posted on Nov 14, 2011
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
Cannot scan documents
go to device manager look for imaging device (scanner) right click and uninstall. / click scan for hardware changes tab, found new hardware must be appeared and click next / select don't search, i will choose the driver to install / click show compatible hardware and choose scanner driver found and click next. and finish.
Feb 11, 2010 | Fujitsu M3091DC Path-Through Scanner
HP Officejet 6310 scans once but then says scanner failure
hi,
that error message is nothing to do with the software part, it actaully hardware issue try the following,
1) unplug the machine and connect it to wall outlet directly,
2) unplug the power cord from the printer and press and hold ON for 1 min and release the ON button and plug it back..
3) Disconnect the power cord from the product.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons and if printer turns off, turn it back ON and wait until it cmopletes its instialization and if still persists, it a hardware failure...............
regards,  raj_p5983
Jan 19, 2009 | HP Officejet 6310 All-In-One InkJet...
Hp officejet 6110 all-in-one
maybe you could try to reinstall the driver?
Oct 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanner failure hp 6110 - Noise and stuck head
the error message refers to the hardware issue of the printer. Below is the document that i need you to follow to somehow resolve your issue.
CLICK HERE==>> DOCUMENT
Please let me know if the document that i gave to you resolves your issue.
thank you so much.
adonscott
Jul 19, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanner FailureTurn power off then on again Message Window pops up continuously
Below is the document that i want you to follow.
CLICK HERE ===>> DOCUMENT
Pleae let me know the result after performing the steps.
thank you so much.
adonscott
Jun 26, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Hello, I have an HP OfficeJet 7310 all-in-one print/scanner/fax etc. I purchased about two years ago but don't use very often. Yesterday while I was trying to send a fax I received a loud winding-up...
I have same problem! The copy/scan function would feed the orginal from the ADF halfway and instead of making a normal loud feeding noise it made a horriable alarming sound and displayed an error message. To fix it: I waited a day or two and bang the top of the feeder cover with normal force while the original is feeding. It appeared the problem is resolved. I have no idea what the problem is, however I think if this work for few months at a time is fine by me.
Apr 12, 2008 | Office Equipment & Supplies
Scanner failure
Oct 01, 2007 | HP OfficeJet d145 InkJet Printer
When scan job is sent a start failure error comes on the display
Don't worry about the clean roller message. It is just a reminder much like your scheduled maintenance light that appears in your car.
Start Failure can occur for a number of reasons. When you get a start failure message close your scanning software and reopen it. Sometimes your connection may degrade if left idle. If that doesn't work shut down the scanner and pc. Turn on the scanner and wait until it is fully initialized before turning on the PC. These steps have resolved that problem for me. Lacking a manual, I just try things. Good Luck
May 07, 2007 | Kodak Digital Science 2500D Path-Through...
Getting error code Code[ffff:0024]while scanning
while i am trying to scan the images .. i am getting the error code like Code[ffff:0024] while warming up the scanner, besides a sound from the scanner making it power off (light inside the scanner goes off ) so that i could not get scanned anything ... what will be the reason ? please suggest me the trouble shoot kaarthik
Apr 14, 2007 | Acer Scan to Web 3300U Flatbed Scanner
HP PSC 2355 All-In-One InkJet Printer Logo
149 people viewed this question
Seeker5211
Seeker5211
