Question about Whirlpool LER5636P Electric Dryer
Whirlpool Supreme dryer (model: LER7646EQ2) won't start.
Checked the house circuit breaker, it was fine. Replaced the Thermal Fuse and that didn't help. Any suggestions?
  • esmrandall May 11, 2010
    Be careful mine would not start then I opened the door and it was on and I could not shut off. It is now outside the firement took it out. all the wires were hot.
jsrock516
  • 5911 Answers
SOURCE: Whirlpool dryer LER5636JQ0 won't turn on
The thermal fuse for your dryer is located behind the rear panel. With the rear panel removed, you can locate the thermal fuse as a small white plastic device located on the blower fan housing on the lower left-hand side (facing from the rear). A resistance reading should indicate close to a short (0 ohms). If the thermal fuse IS defective, the replacement part number is 3392519. You can find all this information at searspartsdirect.com. Just type in your model number and look under the "Bulkhead" heading on the next page. The thermal fuse is listed as item number 7. There's also helpful part locator diagrams to assist in troubleshooting. I hope you find this information helpful. If you need further assistance, please post back and let me know.
Posted on Jun 06, 2008
  • 9 Answers
SOURCE: my Whirlpool dryer(supreme) does not start. The
the thermal fuse may be faulty. Remove the outer back of the dryer. the thermal fuse is located on the blower assy with 2 wires connected to it. It is white plastic. connect the wires together, then try to start the unit again. If the unit starts, clean the exhaust duct after replacing the thermal fuse.
Posted on Jul 21, 2010
Oceti
  • 51 Answers
SOURCE: DRYER
The thermal cut-out is located on the side of the heater housing assm. To gain access you need to use a putty knife to depress the two spring clips between the top and the front panel and raise the top. The heater is on the back wall. The part number for the t-stat and thermal cut-out kit is LA-1053 and is about $20.00. Don't forget to clean your vent, and check your blower assm. Either one could have caused the problem.
Posted on Jan 10, 2008
Jimster
  • 240 Answers
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Posted on Feb 02, 2008
SOURCE: Whirlpool Supreme Dryer will Not Start
I have a whirpool heavy duty dryer that is not working. When I push the button to start the dryer it only roars, and the drum will not move.
Posted on Jan 27, 2009
Dryer runs but there is not heat, heating coil has been checked and it is fine. What is the next troubleshooting step to check it out?
hello zack... Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. I know you indicated that the Heating element was checked but here is how you do it. Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Apr 24, 2011 | Whirlpool TEDX640PQ Dryer
I have a kenmore dryermofel 110.62212101 and the other day i put a load of was in and set timer closed door and pressed start button and nothing happened. i have since checked all plug connections and the...
This is a common problem caused by the thermal fuse blown. The thermal fuse is wired in series with the motor and will cause the motor not running if it blows. It is located on the blower housing at the rear of the dryer. Remove the rear panel to access the thermal fuse.
Once the rear panel is off, refer to the diagram and locate the thermal fuse on the blower housing. Disconnect the thermal fuse wires and tape them together or jump a wire between them. Insulate them properly then plug the dryer in and start the dryer.
The thermal fuse (part number 3392519) is indeed blown and needs to be replaced including the cycling thermostat, (part number 3387134) also on the blower housing if the dryer start starts and works fine with the thermal fuse bypassed. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Feel free to update us about the result and development of the troubleshooting. Let us know of you need further assistance regarding the issue with your dryer. Rate the solution if you find it helpful.
Sep 22, 2010 | Dryers
My Whirlpool dryer(supreme) does not start. The timer switch, door switch, start switch can all be heard to electronically switch on and off when I turn the timer around and open and close the door....
Jul 20, 2010 | Whirlpool LEQ8000JQ Electric Dryer
KENMORE GAS DRYER NOT HEATING UP
Hi
Thanks for using FixYa. No Heat issue in dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which ismounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If thats fine then the Heating Element should be checked. Please do revert for further assistance.
Thanks
Rylee
Apr 17, 2010 | Zanussi TC180W Electric Portable Dryer
Why won't my dryer start? I checked the door switch, the plug for electricity, & the circut breaker.
Newer dryers have a thermal fuse on the neutral side of the motor circuit by the exit air of the blower housing(it is temperature sensitive) Meaning your venting probably needs cleaning because your thermal fuse opened, and the dryer wont work...On most whirlpool dryers you can take off the back panel and look for a short white plastic piece with two wires on it.(or pull the schematic out of the back of the control panel and look for it)
Some models have another thermal fuse located on the outside of the heating element on the upper left side that stops a dryer if it opens.
The operating and high limit thermostats work at lower temps than thermal fuses........(again check your venting)
This is general information, it varies with all the models, you may have a different problem..... Have unplugged, and find cause of fuse opening.(or call appliance store)
Good luck.
Mar 08, 2010 | Whirlpool Dryers
Dryer stopped heating. Runs fine but no heat all of a sudden.
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to
Jan 05, 2010 | Whirlpool Dryers
My Whirlpool Ultimate Care II dryer does not heat up, however it does tumble. Any help would be greatly appreciated. Thanks.
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 02, 2010 | Whirlpool Dryers
No heat in electric dryer model LER7646Eq2
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Unplug unit and turn off gas if gas model. Check to be sure you have 240 Volts at wall outlet.
Most parts likely to fail in your dryer are inside the rear cover. Heater is on right inside can, safety thermostat on lower left of can, High limit thermostat (non-resettable) higher left of can. On the blower housing to the left are the operating thermostat and a thermal fuse (white plastic). ALL can be continuity checked easily. Always disconnect wire on one side of what you are testing. One will likely be open.
Aug 25, 2009 | Whirlpool Dryers
Kenmore dryer
Hi!
Heating element
Thermal fuse
Wiring
Heating element
Thermal fuse
Wiring
Do rate the solution as FIxya if you find this solution helpful.
Thanks
Rylee
Mar 15, 2009 | Kenmore Dryers
Whirlpool LER5636P Electric Dryer Logo
503 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
