I just purchased a durabrand modle sts96 home theater system. The speaker wires for the rear speakers are to short to reach my back wall. Do you make speaker wire extextions for this system?
    Sergeant:
  • 280 Answers
If it has spring clip connectors you can buy any 12 gage speaker wire any length you need and run it from your amp to the speakers. Do not try to splice the wire or you could put the speakers out of phase or short out the Amp.
Posted on Feb 22, 2008
How to hook up cable box, dvd player, and tv, to the home theatre system
Instructions things you'll need:
  • Composite video cable
  • TV
    • 1 Place the front left and right speakers on each side of the TV with the speaker labeled "Center" either above or below the TV screen. Set the rear speakers behind the seating area at head level and place the subwoofer on the floor a few inches away from the wall, which can absorb bass sounds if the sub is pressed against it.
    • 2 Connect the plug on the end of each speaker to the jack labeled for that speaker on the back of the Durabrand receiver. The cables are permanently attached to the speakers, so each may need to be moved closer to the receiver. For example, the left front speaker connects to the jack on the receiver labeled "LF."
    • 3 Plug the video cable from the Video OUT jack on the back of the receiver to a Video Input jack on the back of the TV.
    • 4 Plug in the Durabrand receiver and TV to the electricity and switch on both components.
    • 5 Press the "Input" button on the TV remote several times until the Durabrand signal displays on the screen.
Mar 25, 2011 | Durabrand STS98RW Theater System
I can't find a code to program a comcast remote to a durabrand home theater system modle # STS96
Look on the back or bottom of the Durabrand Home Theater system and look for the UL code. Google that code and it will tell you the orginal manufacture of the unit. You can then look up the code, and more than likely you will see that Durabrand is not the orignal maker. Hope this helps>
Feb 21, 2010 | Durabrand STS92 System
Just purchased system. Our home was wired for
There is no absolute phasing for a given speaker. It's more important that they all have the same relative phasing.
Assuming the installer was consistent with his phasing of the speaker wires, you decide which one you would like to be red (positive or +) and black (negative or -). Kepp that convention throughout all of your speakers.
Dec 27, 2009 | Audio Players & Recorders
Lengthen speaker cable
i had same problem. yeah, there's not much wire included. i just purchased a spool of speaker wire and got the length i needed. since the wires are usually color-coded, i tagged each new wire with 2 stick-on-spots, with sticky side back to back over the wire, and wrote RR & LR to make it easier for locating them in a jumble. you can also just splice and tape extra wire on but i feel every cut cuts back on quality of sound.
May 27, 2009 | Montgomery Ward Audiovox DV1201 Theater...
Philips Home Theater Speaker Wire (can it be cut?)
Sure you can, Joel.
Put the speakers wherever they will go, and cut the wire from the speaker to whatever length you need to reach your wall terminals. Leave some slack so you can move the speakers if needed. Strip off whatever length of insulation you need to make the terminal connection. Note that the speaker wire will have some kind of polarity marking. There will be a colored stripe or other mark on the insulation, or the conductors themselves may be different colors (usually one wire is copper, and the other tinned so it's silver colored). It doesn't matter which you use for positive as long as you're consistent and use the same one for each speaker.
At the other end where the prewiring comes out for your home-theater system, splice the connector ends you cut off onto the installed wires, following the same polarity. I recommend using an appropriate size insulated **** splice to make the connection. The crimper and splices can be found at auto parts stores, Radio Shack or most hardware stores. It's quick, reliable and makes sure there are no bare wires to short out.
Plug the speakers into the system and you should be good to go. Whip up some popcorn and enjoy the show!
Jan 28, 2009 | Philips HTS-3565 Theater System
Home Theater System
if u r in warrenty then company give u replacemant
Sep 01, 2008 | Durabrand STS92 System
Desire Audio for Theater System when watching Tv.
Have you checked all the channels connected correctly refer to the user manual once.
Jun 25, 2008 | Durabrand STS92 System
Speaker wires too short
ya you can but you should be very carefull while you are extending the wire because the wire of the spreaker will have very thin copper wires if you are not carefull it will be damaged so be carefull will extending wire
May 15, 2008 | Durabrand STS92 System
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
