Question about Provo Craft Cricut Disney Font Cartridge
Side popped off Cuttle bug now no pressure
I was putting a nestabilities die with and embossing mat throught the Cuttlebug. It was a bit tight then the side popped off.I cant see any broken bits, but when the side was put back there was no pressure. Can you help Please.
Mine has just done the same, have you found a solution?
Posted on May 20, 2010
  • Barbara Wild
    Barbara Wild Nov 21, 2014
    I have the same problem.think it is a bin job
Why is my Cricut saying it can't read sensor marks?
http://us.cricut.com/forum/cricut-community_postst171705_Can-t-read-cutting-marks.aspx
Jun 19, 2015 | Crafts & Hobbies
I want to personalise my grand daughters school bag and lunch box etc with minecraft pictures. Can you tell me how would I go about this
Google search for pictures of Minecraft characters. Popular ones are the 'Creepers', and the main character 'Steve'. You could also add the diamond tools used in the game. Search for 'Diamond Pickaxe' or 'Diamond Sword'.
Dec 02, 2013 | Provo Craft Cuttle Bug V2 Embossing & Die...
The blade on my cricut expression won't stay down and cut the entire image, only part of it. how do i fix this?
you have something under the mat or the mat is bent. If you are using Expression which I assume you are if it is cutting on the right then make sure you haven't got your mat kinked. It should line up with the side on the left and the little bar on the base of the machine on the right. Try putting it in portrait made and doing some cuts to see if the same things happen.
Flo
Apr 21, 2013 | Provo Craft Provocraft Cricut Expression...
What exactly is die cutting?
Die cutting is manufacturing a lot of the same shape from a material. You can do it with fabric or wood, plastic, etc. The shapes you create are called blanks and are usually used decorated before they are sold.
Feb 27, 2013 | Crafts & Hobbies
I find it very difficult to remove the paper pattern once the item has been cut out,I use 3M Repositionable Spray Mount.Can any one help
This may help: If your mat is too sticky, you need to prep your mat, sort of like "curring" your cast iron skillet when it is new. (I guess I just aged myself.)
Remove the clear plastic film from the mat. Pat both hands all over mat for several minutes. Next place a piece of cardstock (same size as mat) and remove, repeat 8-10 X. This should also reduce the "confetti" or leftover tiny paper pieces on messy mats.
Hope this helps!!
Dancing Bear
Sep 01, 2010 | Provo Craft Cricut Disney Font Cartridge
Cannot use die cuts
No I don't think your machine is defective. Here are some "sandwich" ideas to help you. I know you asked just for Cuttlebug dies; I included other "sandwiches" that you can do with your Cuttlebug. If you need further assistance feel free to contact me.
Cardstock
Chipboard
Magnetic/ Metal Sheets & Thin cork (Media)
Cuttlebug Dies
Plate “A”, Plate “B”, Die (cutting side up), Cardstock, Plate “B”
Plate “A”, Plate “B”, Die (cutting side up), Chipboard, Plate “B”
Plate “A”, Plate “B”, die (cutting side up), Media, Plate “B”
Cuttlebug Embossing Folders
Plate “A”, Plate “B”, Folder (with cardstock inside), Plate “B”
Plate “A”, Plate “B”, Folder (with chipboard inside), Plate “B”
Plate “A”, Plate “B”, Folder (with metal sheet inside), Plate “B”
Nestabilities
You will need Spellbinders Tan Embossing Mat to emboss in
Cuttlebug™ machine (or a plumbers gasket cut to size, or some use a mouse pad)
Cutting Sandwich - (Stack from bottom up)
1. A plate
2. C plate
3. Spellbinders Die (cutting side up) that means the side with the
ridges
4. paper or cardstock
5. B plate
6. Run through Cuttlebug™ machine.
Embossing Sandwich- (Stack from bottom up)
*Remove C Plate for embossing sandwich
1. Place A plate on bottom
2. Leave die face up on A plate with die cut still in the die.
3. Place one Spellbinders Tan Embossing Mat on top of the die.
4. Use 2 or 3 pieces of cardstock to shim.
*Cautionary Note: Using more than 3 pieces of cardstock to
shim Cuttlebug Embossing sandwich will result in B Plate
breakage. When using Spellbinders Edgeabilities card making
dies, shim with only 2 pieces of card stock.
5. Place two acrylic B plates on top of sandwich and run thru
Cuttlebug machine to emboss Spellbinders die cuts.
6. Turn die over and use like a stencil with inks and chalks for
added detail.
BigShot Embossing Folders
Plate “A”, Plate “B”, Folder (with cardstock inside), Plate “B”, Cardstock shim
BigShot Large Dies
Plate “B”, Cardstock, Die (cutting side down), Plate “B”
Revolution Dies
Plate “A”, Plate “C”, Die, Cardstock, Plate “B”
Sizzlit Dies
Note: Provocraft suggests using Plate” C” instead of the second Plate “B”, however, CB owners have cracked plates, so try with two “B” plates first.
Sizzix Original Dies & other Steel Rule Dies
Plate “B”, Chipboard, Die (cutting side down), Plate “B”
Sizzix CutNFold Dies
Plate “A”, Die, Cardstock, Plate “B”, Chipboard shim
Also try:
Plate “B”, Cardstock, Die, Chipboard shim (maybe 6 layers)
Sizzix Embossing Folders aka Simple Impressions
Also try:
Plate “A”, Chipboard shims, Folder (with cardstock inside), Plate “B”
QuicKuts Dies (Regular)
Plate “A”, Plate “B”, Die, Cardstock, Plate “C”
Plate “A”, Plate “C”, Die (cutting side up), Chipboard, Cardstock shim, Plate “B”
QuicKuts Dies (Grand)
Brass Embossing Stencils
Plate “A”, Plate “B”, , Brass stencil ,paper/cardstock,mouse pad (cut to size, rubber side down), Plate “B”
Sandwich may need to pass through several times based on cardstock thickness
Or use plumber’s black rubber plus red rubber gasket, instead of mouse, then add last plate B.
Big Impressions Texture Plates
Plate “A”, BI texture Plate, Cardstock, Silicone Rubber pad (from BISK), Impressions Pad (from BISK)
*BISK-Big Impressions Starter Kit
Fiskars Texture Plates
Plate “A”, Fiskars texture Plate, Cardstock, tan Wizard pad, black or tan Wizard pad, (possible Cardstock shim,) Plate “B”
Also try:
Plate “A”, Fiskars texture Plate, Cardstock (lightly misted with water), 2 layers Fun Foam, Chipboard Shim, Plate “C”
Also try:
Plate “A”, Fiskars texture Plate, Cardstock (right side towards TP), Rubber Plate (made from Plumber’s rubber gasket), Plate “C”
Plastic thin stencils
Here too- may try
Plate “A”, Plate “B”, , plastic stencil, cardstock, black rubber, red rubber, plate B
Jan 28, 2010 | Provo Craft Cricut Disney Font Cartridge
Cuttlebug breaks apart when a cutter is put throught can anyone have sujestions thks ray
The reason this is happening is because the metal casting (inside the green plastic casing)  on one side (where the driving cogs are) has cracked due to trying to force through something that was too thick..
Unfortunately there is nothing that can be done with it apart from complain to the manufacturer
Apr 27, 2009 | Provo Craft Cricut Disney Font Cartridge
Provo Craft Cricut Disney Font Cartridge Logo
1,308 people viewed this question
Top Provo Craft Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Provo Craft Craft and Hobby Expert? Answer questions, earn points and help others
