Question about Frigidaire Affinity ATF7000E Front Load Washer
Where is the rear bearing located so i can grease it
  • 39 Answers
The rear bearing is not accessible to grease. If you have a noisey spin that sounds like it is coming from the bearing it will have to be replaced. Most tub bearings on front loaders are preinstalled with the outer tub assembly. It is a major job to overhaul a front loading machine, requiring outer tub assembly, water seal kit and possibly tub gaskets. If not under a warranty it is not economical to repair.
Posted on Feb 07, 2010
How do I replace the linear ball bearing on a c8fb2 Hitachi miter saw
Its not too difficult:
1) There are 2 retainer pins located on the rear slide support (#4 on breakdown) - carefully drive these out with a punch - be careful to support the bracket so you don't break it.
2) remove the rear support and slide the saw head and arms out of the bearing.
3) Remove the 2 covers (front and rear) over the bearing
4) loosen the allen head set screw on the housing that holds the bearing in place
5) using a large socket and a plastic hammer - gently tap out the old bearing.
Reverse process to replace.
Do not use grease or oil on the bearing or slides - use a pure, clear silicone spray that dries completely - grease & oil attract & hold dirt and debris and will cause bearing failure.
Hitachi C8FB2 8 1 2 Twin Rail Sliding Compound Miter Saw Parts
Feb 14, 2015 | Hitachi Power Tools 8-1/2" SLIDE COMPOUND...
I have a Frigidaire front load dryer that is squeaking. How do I locate the rear bearing so I can grease it and what do I grease it with?
Thank you for your inquiry, Tiffany Garrison Gerling!
I understand you would like to access the rear bearing of your Frigidaire dryer in order to apply grease to it. The grease you would need to use is high temperature grease you would use it because it can withstand the temperature your dryer can get to. I would recommend seeking assistance from a professional technician for proper disassembly of your dryer. Incorrect disassembly could cause personal harm or future issues within the dryer. Best of luck! -OOS
Jan 05, 2015 | Frigidaire AEQ6700FE Affinity Electric...
How do you remove a rear hub on a 04 kia sedona?
Call Kia with your VIN to make sure yours wasn't affected by the recall. You may be able to have that rear bearing replaced for free at Kia.
HUBCAP & OUTER BEARING REPLACEMENT PROCEDURE: 1. Remove the two (2) cross-tip locating screws on the brake drum.
2. Remove the brake drum.
3. Remove cotter pin and cover set.
4. Remove nut, claw washer, outer bearing and hub assembly.
5. Inspect inner bearing area in both hubs for any sign of moisture, corrosion, grease discoloration or contamination. If "yes" discard entire hub and replace with new assembly. If "no" proceed with outer bearing replacement below: 6. Carefully remove the outer bearing race from the hub. If the hub assembly is damaged then replace the hub assembly as a complete unit. (If inner seal is damaged while removing the outer race replace with new seal.)
7. Clean all contaminated grease from outer bearing cavity of the hub.
8. Install a new outer race into the hub using an appropriate race installation tool.
9. Apply grease MS511-33 WBG2 or equivalent to the hub assembly and the new bearing(s) especially to the shaded areas.
10. Install hub assembly, new pre-greased outer bearing and new claw washer on spindle. (Or alternatively, install entire new hub assembly, as supplied). Ensure bearings are properly seated then tighten hub/spindle nut, torque nut to 20-25 lb-ft (27-33 Nm.) Verify hub spins freely without signs of binding or excessive play.
11. Install new cover set and cotter pin; never reuse the old cotter pin.
12. Install new hub cap with Loctite # 5910(TM) or equivalent sealant to prevent moisture intrusion.
13. Install the rear brake drum using tapered locating screws.
14. Install rear wheels and torque lug nuts to proper specification. (65-79 lb-ft) (88-108 Nm, 9-11 kgm)
15. Lower vehicle.
Dec 30, 2014 | Cars & Trucks
Grease plug locatiom snapper rider
if it's a rear engine rider with a 28 or 30 inch deck the grease fitting is underneath the deck... If it is a rear engine rider, close the fuel off and stand the mower on end but for a short period of time only. This applies to ALL rear engine riders from Snapper up until about 2 years ago when they made a SERIOUS mistake and redesigned them
Sep 11, 2014 | Snapper Garden
How to replace front wheel bearing
pull wheel remove grease cap undo carter key remove nut pull off rest of hub take bearings frt and rear out of hub clean old grease from bearings check bearing for defect install in revers order remender to install new grease in new bearings lots of grease and u will need new seals for same front and rear
Jun 14, 2014 | 2006 Suzuki Verona
96 chevy blazer rear axle bearing/seal r/r
No. Did you run some emery cloth along the race (bearing surface) to make sure it was smooth and clean? If you leave any part of the old seal or debris on the hub surface, damage the seal when installing it, not liberally packing the bearing with grease or the seal did not seat right you can have issues like yours. Make sure the seal is installed flush and if everything looked good as far as the axle and surfaces, pack more grease in the bearing. When you think there is enough grease in it, put more in. Put the grease in the palm of your hand and with the bearing held flat in the other hand repeatedly tap the bearing on your palm until grease comes out both sides. Then put more on it when you seat it.
May 28, 2010 | 1989 Chevrolet S-10 Blazer
How to replace rear wheel hub
Sodium based grease is not compatible with lithium based grease. Do not lubricate the wheel bearings without first thoroughly cleaning all old grease from the bearing. Use of incompatible bearing lubricants could result in premature lubricant breakdown.
  1. Raise and support the vehicle safely.
  2. Remove the wheels.
  3. Remove the brake drum or brake disc.
  4. Remove the hub grease cap.
  5. Remove the cotter pin retainer, adjusting nut and flatwasher from the rear wheel spindle. Discard the cotter pin.
  6. Remove the outer bearing and cone assembly.
  7. Remove the rear hub from rear wheel spindle.
  8. Using Seal Remover (TOOL-1175-AC) or equivalent, remove and discard the oil seal.
  9. Remove the inner bearing cone and roller assembly.
  10. Clean the inner and outer bearing cups with solvent. Inspect the bearing cups for scratches, pits, excessive wear and other damage. If the bearing cups are worn or damaged, remove them using a Bearing Cup Puller (T77F-1102A) or equivalent.
To install:
  1. Throughly clean old grease from the surrounding surfaces. If a new hub assembly is being installed, remove the protective coating using degreaser.
  2. If the inner or outer bearing cups were removed, install replacement cups using Bearing Cup Replacer (T73-1202-A) or equivalent. Seat the cups properly in the hub.
If a bearing packer is not available, work as much grease as possible between the rollers and cages. Grease the cone surfaces.
  1. Using a bearing packer, pack the bearing cone and roller assemblies with a premium bearing grease.
  2. Place inner bearing cone and roller assembly in the inner cup. A light film of grease should be included between the lips of the new grease retainer.
  3. Install the retainer with Hub Seal Replacer (T83T-1175-B) or equivalent. Be sure the retainer is properly seated.
Keep the hub centered on the spindle to prevent damage to the retainer and spindle threads.
  1. Install the hub assembly on the spindle.
  2. Install the outer bearing cone and roller assembly on the spindle.
  3. Install the flat washer and nut. Tighten the nut to 18-23 ft. lbs. (24-31 Nm) while rotating the hub to set the end-play. Back off the nut and retighten to 18 inch lbs. (2 Nm).
  4. Install the new cotter pin.
  5. Install hub grease cap.
  6. Install brake drum or disc.
  7. Install the wheels.
  8. Lower the vehicle.
May 04, 2010 | 1998 Ford Windstar
Loose rear wheel, believe it is the bearing. How do I repair it?
drum brakes you remove rear wheel- speed sensor-grease cap-flange nut-outer bearing-brake drum-inner grease seal-inner bearing-drive the bearing races out of the drum hub.to install -install the inner and outer bearing races.apply grease to the bearings and hub cavity.then you install the inner bearing -inner grease seal-brake drum-outer bearing-flange nut torque it to 159 to 192 ft lbs. THE REAR DISC BRAKE WHEEL BEARINGS-you have to remove rear wheel -wheel speed sensor-brake caliper and rotor-rear axle hub bolts-tone the wheel with tool 09445-21000-carrier assembly-nut after unstaking it-press out the rear axle hub-remove the bearing inner race with tool 09445-21000-remove the bushings from the carrier with tools 09453-33000b and 09545-21100.to install -press in the bushings to the carrier with tools 09453-33000b and 09545-21100- press in the bearings to the hub with tool 09221-21000.tighten the flange nut to meet the concave portion of the spindle-press in the tone wheel with tool 09221-21000-torque the nut to 191 ft lbs -install the hub and bearing assembly to the backing plate and torque the bolts to 88 ft lbs-install the brake caliper and rotor.install the wheel speed sensor if equipped.install the rear wheel.TO BUY THE TOOLS TO DO THE JOB.LOOK UP KENT MOORE TOOLS ON INTERNET.
May 30, 2009 | 1999 Hyundai Sonata
My front load stackable dryer is making very load squeaking noises when it starts up for about 15 minutes
The rear bearing for the drum needs to be greased. If you don't grease it and ignore it, eventually the dryer will stop working because you will be overloading the motor, and the motor will start drawing additional current that it will trip the breaker. Greasing the rear bearing is a 15 minute job. You need to purchase high tempo grease. Frigidaire sellsthe high trmp grease that is required.
May 24, 2009 | Frigidaire Affinity ATF7000E Front Load...
I AM REPLACING THE BASKET ASSEMBLY ON MY KENMORE FRONT LOAD WASHE
The shaft on the spin basket assembly is not lubricated. The shaft is inserted through the sealed bearings located in the rear outer tub shell. Placing any grease on the shaft would end up in your wash and damage your clothes.
Apr 03, 2009 | Kenmore 42822 Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
206 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
