Dual DVD (Model#DDV9555) does not turn on.
Model#DDV9555 won't turn on after LED's flashing / unplugged / replugged.
  • gayle_don Mar 07, 2009
    My Panosonic DVD/VCR combo will not turn on - no power. The fuse is good and I have determined that power does come into the unit, but don't know what to do from here
    Genius:
  • 1,019 Answers
you could try checking the plug fuse.
or opening the casing, and seeing if theres an on board fuse located near to the mains power inlet. usually a small glass fuse. 0.5 to 1.5 Amp quick blow type.
Make sure you switch off and unplug before attempting this.
if the fuse blows again, when you switch it back on, unless it,s warranted. Bin It and buy a new One.
Mike @ Compurepair.
Posted on Feb 22, 2008
Flashing red led light at power; no tv. will not turn on just flashing red led
Try leaving it unplugged for a little while.. at least 15 minutes and then replug and try.
Jan 08, 2016 | Samsung LN32A330 32 in. LCD TV
Vizio sv41xvt flashing logo. won't power up
Sounds like either a power circuit board or mainboard failure. I'm going through same problems, mine is power board failure.
Jan 11, 2013 | Vizio SV471XVT 47 in. LCD TV
I have a ripspeed DVD 720 when I wired it in the power button just flashed red for a bit and that's it it won't turn on or do anything?
Sounds like the power supply in the dvd player has failed. It works just well enough to turn on the led infront but as soon as you go to do anything it shuts off. This is common in cheaper dvd players. Unless you can troubleshoot electronics. Or know someone that can. Your best bet is to unplug the unit and disassemly and retrieve your dvd.
Oct 06, 2012 | Televison & Video
I unplugged my dvd recorder. When I plugged it back in it won't power on.
Hello
Just look at the power chord, whether it has been pluged into the slot well. Check the wall power socket also for presence of power. Replug it to an other power plug point. Till the problem perists, surely there must be some fault with its power regulator board inside. Normally, if power regulator board gets power, the power indicator must light up. If not power regulator board [SMPS] board is faulty, and should be replaced with same type and number. OK.
Jun 27, 2011 | Philips Magnavox DVD/VCR Dual Player
The power went off and when it came back on the tv wouldnt come on but the timer light is lit
First thing is to unplug the TV for several minutes, replug, Power LED shouls flash for around 90 seconds then go off. Try to power up then.
If the power LED does not stop flashing , or the TV will not turn on still, it will need a repairman.
Oct 22, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Sharp 46 aquos model LC46E77UN tv turned off power button just flashes on and off tried unplugging and waited an hour and replugged same conclusion power light just flashes
Unplug it hold down the Channel Down button and the Volume Up button unplug it for 10 seconds then plug it back in and continue holding them down for another 10 seconds then release. I had the same issue and this fixed it now I have another though *~*
Oct 01, 2009 | Sharp Televison & Video
Hp desktop wont start
I think you have more than one problem there. Take it to a local PC repair shop and have them check it out. Five years is a good age for a computer though so you may want to think about buying a new one. Best of the Irish Luck to yer.
Sep 16, 2009 | HP Computers & Internet
I have had my projector for abourt 2 years and the projector indicated that the bulb life was almost up and had to be replaced. I bought the new bulb and installed it with no problem. when I turned on...
Please ADD the make and model of your projector on the comment page.
Without the model information,I can only give you few location to check on.
Check for an air filter or air clear.
Some unit has the smart to sense for filter change. In general you must do both at the same time.
(once again this is general info. Without the model #,I only can tell you to look for the filter)
The next item is check for safety switch/latch for open. The project has built-in safety.
Make sure all door/latch are close securely.
Do a quick cleaning and check for loose parts.
Please ADD the model number under comment page.
I will follow up later.
Jul 23, 2009 | Televison & Video
Unit won't turn on.
Is tape(s) in the unit? Are they "shuttling" when you try to power up?...accordianman
Feb 22, 2008 | Emerson EWD2204 DVD Player/VCR
Non responsive dvd600 by Oritron
Can you take led off, see if DVD stuck inside unit? Find the tray release button and manually open the tray and replug. and see if unit respond.
Aug 10, 2007 | Oritron DVD600 DVD Player
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
