Question about Compaq Presario CQ60-220US PC Laptop
Not loading disc but appears to try to initiate auto start set
    Scholar:
  • 106 Answers
This exact thing happened to me, only when it did actually auto start it was reading every disc as blank, I had to replace the dvd drive I found a suitable replacement on craigslist. and installed it myself it wasn't too difficult I found this TUTORIAL on YouTube However you may not need to remove all the screws just the one holding the drive in place.
Posted on Feb 07, 2010
Won't load to default
Hi Lloyd,
The introduction in the manual warns that you should ask your dealer or store in order to change the batteries. I'd suggest seeing if they have any advice.
That said, how are you trying to default the settings? I've copied the two ways below. Maybe try whichever one you haven't yet. I hope this helps.
Manual: http://hammondorganco.com/wp-content/uploads/2011/03/XK-1manual.pdf
Default #1:
In this mode, you can return entirely or partially to the default setting as set at the factory.
To locate this mode:
Touch the [MENU/EXIT] button for the MENU display, select PAGE D by the [PAGE] button, and then touch the [3] DEFAULT button. To initialize each parameter, touch the button and then [4] OK
1. ADJUST PRESET
  • Initializes the content of the Preset Key [B].
  • If the Drawbar Control mode is at "UPPER A#/B", the content of [A#] is also initialized.
  • If you do this operation before you start a new setting, you can start from the factory
  • setting.
2. PRESET
  • Initializes the content of all Combination Presets.
3. GLOBAL
  • Initializes the Global Parameters such as Master tune or assignment of the Foot Switch.
4. LESLIE
  • Initializes the content of all Cabinets.
5. ALL
  • Initializes all parameters of this keyboard.
  • If anything caused an unstable trouble on this keyboard system, the trouble would be cleared.
Default #2
Please perform the following steps to reset the XK-1 to the initial default setting.
1. Switch off the power of the XK-1.
2. Hold the [REC/JUMP] Button, and switch on the power.
3. Continue to hold down / Keep pressing the [REC/JUMP] Button until "Loading Default..." appears on the Display.
4. After 5 seconds if everything is in order, PLAY Mode appears on the Display. (Completed)
Dec 20, 2013 | Hammond XK1 Pro Drawbar Organ
Brought acer travel mate back to factory using recovery discs now it wont reboot.I put discs back through with no result
Check the bios settings, in boot settings you must set CD unit as first boot device, then you start PC with recovery disk 1 inside.
Sep 05, 2008 | Acer Computers & Internet
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
The game doesn't start.
Check your settings to see if the auto start feature is turned on or not. Also, how long have you let the player continue to attempt to read the disc, maybe try waiting a little longer if you haven't already. Sometimes the Playstation takes a while to load and read disc's. Hope you find this of some help, I hope that it's not an issue where you need to replace the disc drive itself. Try setting it to auto start the disc and see if that helps first. If this doesn't help right me back and I will try to assist you further.
Feb 16, 2010 | Sony Playstation 3 (PS3) Console
Webroot 6.1 Antivirus/SpySweeper won't open after install
Dear User,
Though Webroot 6.1 Antivirus works fine on Windows 7, but its Spyweeper (anti spywear), is not seems to be compatible with Windows 7.
You can look for the version of webrrot that is fully compatible with windows 7.
OR
You can go to the free versions of Antivirus availables for Windows 7 (as AVG Free).
Thanks
Jan 24, 2010 | Webroot Spy Sweeper (spysweeper) for PC
Describe your Sony FD Trinitron WEGA This started
I have the exact same problem. If you get anywhere (I can't) please contact me at tbiasi@hotmail.com. If I figure it out, I'll get back to you.
Good Luck.
T
Sep 09, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Input not supported
You may have a video resolution selected on your computer that the screen doesn't support.
The reason you see the the initial startup message is because that is loaded from the bios, prior to the settings for the graphic card output being loaded.
Try booting the computer in safe mode and adjusting the display resolution.
Dec 29, 2007 | Acer AL1916W 19" LCD Monitor
Games initial load before Play Starts receive error 'cannot read disk see instruction manual'
If this happens for only some games, you should try cleaning the discs with a disc cleaner. Otherwise, you could try asking around at stores like circuit city, radioshack, best buy, etc. for what you could use to clean the lens, the part that reads the disc in your gamecube. If that doesn't work, chances are that the lens is damaged and your only hope is to send it in for repairs or get a new gamecube (or Wii).
Oct 13, 2007 | Nintendo GameCube Console
Compaq Presario CQ60-220US PC Laptop Logo
59 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
