Question about Panasonic DVD-S53
Panasonic DVD S53 error display
My DVD player is still new and has been working fine, but suddenly it just won't play anything and is showing two different codes on the display. H02, and FOCO. Can someone tell me what this means?.
  • donkn8r Mar 20, 2008
    My DVD player is still new and has been working fine, but suddenly it just won't play anything and is showing two different codes on the display. H02, and FOCO. Can someone tell me what this means?. I don't know why I keep buying panasonic, they all **** out on me!
SOURCE: Error Message H02
I have had this problem on numerous times. Once while in warranty. Discussed with technician and he reported that the gears get dirty and stick and need cleaning. Since last year, I get this message every 3-4 months. I take out all the screws from the bottom, open the cast carefully, and use some canned air, clear all the gears, gently rotate all of them. Put everything back together and should work fine.
Posted on Sep 28, 2006
  • 82 Answers
SOURCE: panasonic dvd sa-dp1
The Spindle motor is defective.
Posted on Mar 22, 2008
  • 1463 Answers
can you post more info so some one can help more ?
Posted on Mar 25, 2008
SOURCE: HO2 error code at screen
In line with the other Panansonic DVD players, the error seems to relate to the internal drive machanism getting stuck.
To fix you just need to carefully take the back off (disconnect power source first!), locate the drive cogs for the lens machanism and give the a couple of turns. Also a blast from a air can will help get rid of any dust build up. Pop the back cover back on and you should be working.
Looking at the other Panasonic threads on the site, this may happen on a regular basis especially as the unit gets older (and the crud builds up).
Posted on Jan 04, 2009
  • 6784 Answers
SOURCE: Panasonic DVD-S35 Player H02 problem
Hi, this is an unfortunate error. this is referring to the lens assembly. it is unable to scan and read at this moment. it could be because the lens is dead or, it could be that the lens is simply dirty and will need to be cleaned. i would try cleaning it with a non brush type cleaning process. Once cleaned and you still have the same issue, i recommend replacing the lens assembly.
Posted on Mar 11, 2009
Which type of AC power cord does it use?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Mar 06, 2016 | Panasonic Dvd-S53 Component Dvd Players
Blue ray disc player suddenly will not play blue ray disc?
If you can't get a menu picture from blu ray, check output jacks going from player to tv. if you a picture from blu ray menu, then you may need to clean the lazer eye in blu ray player.
Aug 03, 2015 | Panasonic DMP-BDT300 DVD Player
My dvd player won't play dvd
likely if cannot read disc, or no disc or error, that unit has either dirty or bad optical pickup.
May 14, 2012 | Televison & Video
No sound in DVD player
i have no sound when the dvd is playing
Jan 17, 2010 | Panasonic DVD-S53
I have a go video vcr/dvd player. The vcr works dvd doesn't
if this happens to all discs needs to be panasonic was playing up and not very old,and cost me $350.00 for a new driver.
Jan 03, 2010 | GoVideo Go Video DVD/VCR Combo
Panasonic dvd player won't show video (or anything) on tv
On the tv r/control press the av button until you see the dvd you are playing.You would be better connecting the dvd with a scart lead.
Aug 26, 2009 | Panasonic DVD-S54K DVD Player
Technics sc-dv290
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
Oct 26, 2008 | Technics SC-DV290 System
U11 Error and Clicking
hi i try to this,but nothing still the same!!!!
Oct 28, 2007 | Panasonic DMR-E30 DVD Recorder
Panasonic DVD-S53 Logo
275 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
