Question about Estate TEDS740JQ Electric Dryer
It just stopped working all of a sudden. is there a fuse that could need replaced?
  • 3,741 Answers
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Feb 07, 2010
My directional (only) stopped working on my car. I need to replace the flasher, but do not know where it is
Older cars are in the under dash fuse panel or on a wire up by the steering column, close to the firewall. Newer cars are built into the hazard switch.
May 25, 2015 | Cars & Trucks
Can i change the fuse number 41 with the fuse 42 in the front fuse box
IF the fuse in 41 is the exact same size as 42.
You can NOT put a 20 amp fuse in a 15 amp fuse position safely. It will work, but may not pop if there is a problem.
Also, if you changed them and the vehicle started to work, than the fuse in one of them has broken. You need to replace it with a new fuse.
Replace it with the SAME SIZE. Not a larger one.
Jan 08, 2015 | Chevrolet TrailBlazer Cars & Trucks
What kind of fuse do I need on my 1999 Mercedes Benz ML320 for the power windows? All of them suddenly stopped working and I think the fuse may have blown?
So, if you think you blew the fuse, replacing it will likely find you with 2 blown fuses. Try benzworld.org. This site has a wealth of information and extremely knowledgeable people on their forums. I'm pretty sure your fuse box is under the hood on the drivers side though.
Dec 04, 2013 | Mercedes-Benz ML320 Cars & Trucks
32' lcd hdtv tv lost power all of sudden bought tv on 2/22/09 outlet works fine
if the tv al of a sudden stops working. the first thing you should inspect is the fuse. more than likelly it blew out on ya and replace with same fuse.
Nov 22, 2010 | Emerson Televison & Video
My windshield wipers suddenly stopped working on my '96 Jeep Cherokee. I replaced a fuse that was bad, but they still don't work. Help!
if the fuse failed then that means one of few things...
1.) motor has failed causing excessive current draw
2.) circuit has direct short to ground
3.) short to ground that caused fuse failure is now an open
you need to check for power and ground at the wiper motor
keep us posted
Apr 06, 2010 | 1996 Jeep Grand Cherokee
2002 Acura TL Type-S Radio Fuse Blown??
Passenger Side fuse box, fuse number 9 neets to be replaced
Dec 09, 2009 | 2005 Acura TL
My Altec lansing multi media ada 745 just stopped working all of a sudden. It doesn't work for all media ie. ipod, tv, computer. We can hardly hear it. I changed the fuse but it still doesn't work. Wh
unplug the power from the speakers, reseat the all the connections for the satellite speakers, ensure the power switch on both the subwoofer and the Right Front Speaker are in the ON position.
If that doesn't resolve the issue, then you are most likely going to need to replace the speakers, as the fuse is the only serviceable componet.
May 20, 2009 | Dell Computers & Internet
Door locks stopped working.
you maybe a short somewhere. if the fuses keep blowing then you have a positive cable somewhere touching ground
Apr 17, 2009 | Jeep Cherokee Cars & Trucks
HELP! 01 NISSAN SENTRA...lighter outlet suddenly stopped working?
The fuse had just cut-off because there was almost a problem. Look for the corresponding fuse and replace it.
Good luck.
Do rate this solution fixya.
Apr 11, 2009 | 1999 Nissan Sentra
Estate TEDS740JQ Electric Dryer Logo
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
