Question about Sony KP-46WT510 46" Rear Projection HDTV
SONY KP-46WT510 WITH 6 BLINKS
Hello,i have a sony kp-46wt510 when ever you turn it on it blinks 6 times then goes to standby.can anyone help
  • 1 more comment
  • faceface Feb 22, 2008
    where can i find it
  • faceface Feb 24, 2008
    I CAN'T LOCATE THE THRMOSTAT
  • faceface Feb 26, 2008
    i found the problem for the kp-46wt610 with 6 blinks.Q714 on the A board was open
Sorry i couldnt have been more help. glad you figured it out.
Posted on Feb 27, 2008
IT IS USUALLY UNDER THE LAMP HOUSING YOU MAY HAVE TO TAKE OUT THE ENTIRE OPTICAL BLOCK TO GET AT IT JUST LOOK FOR THE ONLY TWO SMALL WIRES GOING TO THE UNDER SIDE OF THE LAMP HOUSING FROM THE REAR (NOT THE THICK RED ONE GOING INTO THE LAMP FROM THE BALLAST) THE THERMO. WILL BE LESS THAN AN 1'' LONG VERY SMALL BLACK CYLINDER
HOPE THAT HELPS
P.S. THERE ARE OTHER MORE COMPLICATED POSSIBILITIES BUT THIS IS THE MOST COMMON
Posted on Feb 23, 2008
  • 92 Answers
IF I REMEMBER CORRECTLY THAT IS A LAMP THRMOSTAT
Posted on Feb 22, 2008
Hello, I have a Sony Projection Television Model number KP-46WT510. The problem I am having is when I turn it on it turns back off. The standby /timer light blinks six times. What could be possible...
Low B over voltage or over current shutdown its usually related to either the A board or the B board. You can get the replacement A board which includes the B board from www.tvrepairworld.com
Apr 26, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
When i turn the TV on, a red light on the front of the set just flashes (standby light)
Let me know model and brand of TV if its other then Sony KP-46WT510 and also count red standby light flashes as there would be long pause between blinks.
These info will help me to find out possible solution.
Jul 27, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
My Sony KP-51WS520 wont turn on
There is a small diode in the power supply that is bad. Do you have the capability to replace this yourself? (can you solder?) If so I can help you through it.
Jul 07, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-51WS520 won't turn on
Something bad in power supply or horiz output.Possible bad gun.Needs a repair shop unless you know electronics.
Sony KP-57WS520 57 in. Rear Projection TV standby light blinks
Please mention how many times standby light blinks on your KP-57WS520
There would be bit long pause between blinks so count the blinks and let me know to help you.
Dec 05, 2008 | Sony KP-57WS520 57" Rear Projection...
6 bliks on sony kp-46wt510
KP46WT510 Shutdown 6 Blinks. 6 Blinks = Low B+ OCP/OVP
SOLUTION: Replaced Flyback transformer. It had no rings on the ringer test.
HQ
Comments: Any load on the B+ line can cause 6 Blinks.
Example: If the 200v line is loaded down will cause a drop in B+ due to bright picture current demand.
Click Here! to download the Sony Kp-46wt510 full service manual.
Nov 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sont kp-46wt510 blinks 4 times
IC1509 8-759-593-33 IC LA78045 35.98
Q1505 8-729-423-33 TRANSISTOR 2SC3311A-QRSTA
Replacement part
8-729-119-79 TRANSISTOR 2SC2785-FEK-HFE 1.02
these ic locations are different than yours but same part number.
is there a 2sc3311 near by LA78045?
Jan 10, 2008 | Sony Grand WEGA KDP-51WS655 51" Rear...
Four blinks is a "vertical stop error" I have a pdf file of the service manual and troubleshooting guide. If you want it,let me know where to send it.
Sep 27, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Sony kp-46wt510
I can't directly suggest a solution to this problem. but here is a link URL may be useful to you. http://getmanual.ru/tv/sb/sonyus.htm all the best
Sep 27, 2007 | Compaq iPAQ H3130
Blinking 8x's
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some newer models of Sony TV sets, this code means that T8005 is defective on the D board. If your not a tech and have no solid state repair experience, play it safe and call out a pro to assist you in this type of repair.
Jun 29, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
404 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
