Question about Canon PIXMA MP160 All-In-One InkJet Printer
How do I change the settings so that the printer doesn't cut off the left side ( 2-3 letters) every time I print . It just started doing this! Canon Pixma MP 160
    Problem Solver:
  • 9 Answers
You need to set margins in your "Page Setup"...
Posted on Feb 08, 2010
Canon mg5200 printer is cutting off print from the left margin. How to fix?
You need to check the settings in the program you are using to print from. Check that paper size is set for the paper you are actually using. The usual culprit is A4 on program to Letter in the printer. Also check that Margins are set to Default.
Nov 04, 2016 | Canon Office Equipment & Supplies
Left margin cuts off text
If text is cutted of, this is a problem of the settings of your paper size. It can be different according the software you are using (Do you print from MS Word or some other application?) You have to control the paper size settings in your driver. In your pop-up screen of the printersettings, you'll see an example on the right side. It shows the printing area. You can change it on the left size. Sometimes the numbers doesn't change, than you need to push the button 'properties' and look for the papersize in here. If that also doesn't work, make a pdf of your document and try to print it again, and hit the button 'paper size based on pdf' in your driver.
Nov 30, 2011 | Canon PIXMA MX860 All-In-One InkJet...
I just replaced the ink cartridge in my canon printer and tried to print something. A box came up saying the alignment may be off and I need to print an alignment page. How do I do that?
Hello. To do a head alignment follow the steps below.
  1. Click Start - Control Panel - printers and faxes
  2. RIGHT CLICK on the canon printer and select printing preferences
  3. Select Maintenance from the top right tab (see image below)
  4. Select print head alignment and follow the steps on screen.
I hope this helps, If so please rate this answer below. Thank You for supporting the FixYa Community
Regards GM
Apr 24, 2011 | Canon Pixma iP2600 Photo InkJet Printer
A few letters are cut off on left side
it could be a software problem. Please make sure that in the software where your printing originated, the paper size is set exactly as compared to the actual paper you use for printing. Example, if you are printing using an A4 paper, make sure that the document is laid out using the A4 setup with correct margins not exceeding the paper's printable area.
Nov 10, 2009 | Canon PIXMA MP470 All-in-One Printer
Left side of page cut off printing from Outlook 2003
Have you try to Copy paste the content of Outlook to Word and then try to print.
As Outlook have lesser option to set for printing. And may not possess all the features to print it correctly.
Let me know if I can assist you further.
Regards
Ellin
Sep 24, 2008 | Canon PIXMA iP90 Mobile Printer
PRINTER CUTS OFF RIGHT SIDE OF PAPER
First, on your computer desktop. left click on START. Next, left click on CONTROL PANEL, and left click on PRINTERS. Find your printer on the PRINTERS window, and RIGHT CLICK on the icon. From the drop-down menu, left click on PRINTING PREFERENCES. Use the settings to set up the printer for the paper size and orientation you want to use.Click APPLY , then OK buttons to apply any changes you make. If that does not help,check the side paper guides in the paper source you are using. If they are not against the paper on both sides, the paper will not align properly with the image. Move the guides snug but not tight against the paper. If the guides are too tight, paper may not feed. If moving the guides does not solve the problem, try loosening the guides and reposition the paper until the image is properly aligned. Then see in your owners manual if there is an adjustment called SIDE-TO-SIDE REGISTRATION, and follow the proceedure to adjust the side-to side paper alignment.
Jul 16, 2008 | Dell 3100cn Laser Printer
Paper tray selection
Go to Paper Menu > Paper Size > Tray 1 - note what the Auto setting states (Letter, A4, Legal, etc.) Pull the tray out to set what it is configured for. Then reinsert it & pull it out a few times, noting what the display show the Auto size show. It should match the tray's settings.
If the Display indicates otherwise, it means one of two things:
1) The "auto size sensing" board on the left may be defective. The left side of the tray has a matrix of 3 plastic tabs that stick out in certain order depending on the tray setting. If this board fails, it may show Executive or A4 when the tray is set for letter.
2) The tray may be in-between two settings. Try to readjust the tray length setting between sizes. (You will notice the plastic tabs will change order.) The last time you loaded paper it may have pushed it just enough so that it is no longer seen as letter by the auto sensing board.
I hope this helps...
Nov 28, 2007 | Lexmark Optra T610 Laser Printer
Printer switching orientation
Make sure that manual feed is set to letter, on the printer front panel. This is a tabloid printer, so letter size sheets are fed long edge. The cassette will print okay because the media size info for the cassette is read by the printer from the cassette cams.
Dec 21, 2006 | Xante 4G Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
120 people viewed this question
old marine
old marine
