Question about Microwave Ovens
Sharp microwave R-1450 made buzz sound and shut down, no powere at all.
  • lovemylattes Feb 07, 2010
    thank you. If the microwave is 16 years old, would you bother to do this or replace it?
    Quick response!!!
  • 11,896 Answers
First thing to do would be to remove the screws and pull off outter shell of the microwave. Then look inside to see if you fuse has blown. If the fuse is blown, replace it. If the fuse is still good, then you will want to get a multi-tester that has both volt and ohm settings. Then put tester on the voltage setting, find the power supply/high-voltage transformer (the box that has the power cord connected to it) Test the voltage from the supply/transformer to where it connects to the main circuit board. Write down the reading. Then look around the microwave to see if there is a sticker or label that says the DC Voltage Output rating. Make sure the number you wrote down matches this number. If it's not even close, then the supply/transformer is bad. If the numbers match or are very close, then you will want to use the tester in the ohm setting and test all the capacitors and see which one is not in range f4om the other ones.
Posted on Feb 07, 2010
  • Nate Stansfield
    Nate Stansfield Feb 07, 2010
    If it's just the fuse, then that's is a very cheap and easy fix, if it's anything else, just junk it and buy another.
RE: Samsung microwave SMH7187STG mfg'd 5/08. I heated cup of tea 2 min.Then I closed micro's door & micro emitted a continuous electrical buzzing sound.I opened door & buzzing stopped.
The cook relay on your control board is shorted, and the unit is cooking whenever you close the door.
When the magnetron overheats, its thermostat opens, shutting power down until the unit cools to a safe level, then power is restored.
I regularly repair these with my $54.95 service, which includes insured return shipping.
Details are here, or for full information and instructions, please e-mail me here at pupista@gmail.com and remind me of your full model number and symptoms.
Dec 20, 2016 | Samsung Microwave Ovens
FMV152KWA microwave buzzes when not running
Missy Uhland Bauman,
I understand that you are hearing a buzzing noise from your microwave, even though the door is shut and and it is not running. I would suggest to give the appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back. If you are still hearing a buzzing sound, I suggest either contacting the manufacturer or your local authorized technician.
-Best Regards-
Jan 10, 2014 | Frigidaire FMT118E1B Microwave Oven
Sharp microwave kb-6002ls making buzzing noise
Someone would have to open the unit to "hear" where it is coming from, possible fan issue or even the power unit inside.
Dec 03, 2012 | Sharp KB-6002LS 1000 Watts Convection /...
Sharp R-1870F Microwave Won't turn on
Could be just a fuse but probably the diode pack or magnetron.
May 24, 2017 | Sharp R-1870 Convection/Microwave Oven
What is the wattage of model R-9H84B
That model had 900 watts of microwave power output, and the convection outpout was 1450 watts.
Jun 18, 2011 | Sharp R-9H84B Microwave Oven
Sharp R-150 microwave made a buzz sound and shut off, no power to microwave
When the microwave won't heat, but you hear a loud buzz, you usually have a defective power diode, high-voltage capacitor, or magnetron. Also usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Feb 07, 2010 | Sharp Microwave Ovens
My 1450 blew the in-line 20amp fuse, just
sounds like the H.V. diode,capacitor,or mag is shorted first 2 items are cheap, the mag gets pricey, call "Appliance Parts Pro's" they can help you on parts great prices and fast shipping
Jul 27, 2009 | Sharp Microwave Ovens
No Power at all after loud short buzzing sound
sounds Like an electrical fault in the Micro, Sorry but this is broken.... If this is within warranty (do check as some warrantys are for 3 yrs or more) get the manufacturer to replace/repair it for free. you could get it serviced, but it is probably cheaper to buy a new one.
Aug 24, 2007 | Sharp R-1460 Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
