Question about Belkin Computers & Internet
IP conflicts using the Belkin Model 570230-4 router and I do not have the belkin utility CD.
  • 4,281 Answers
For that you need to enable dhcp on router.
Then set in your computer network adapter property to ip get automatic.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then enable dhcp and save settings and restart router.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Feb 07, 2010
My laptop wont log on to belkin
Sir,
Check your IP Address, Maybe its conflict with other device.
My advice to turn it automatically.
Or
Installing your Belkin router is still possible even without using its Setup CD. You can set up your router manually through the web-based setup page of the router.
Perform the steps below to set up your Belkin router through the web-based setup page.
NOTE: images may vary depending on the router model or computer you are using.
Power cycling the modem and router
Step 1:
Unplug the modem and router from the power source.
Step 2:
Connect the modem to the WAN or Internet port of the router.
Step 3:
Power ON your modem first, then your router by plugging them back to the power source.
Manually setting up your router
Step 1:
Connect the computer to one (1) of the Ethernet ports of the router.
Step 2:
Launch a web browser and enter "192.168.2.1" in the address bar.
Step 3:
Click Login.
Step 4:
Leave the Password field blank and click Submit.
Step 5:
Under Internet WAN, click Connection Type.
Step 6:
Select your Connection Type, then click Next.
NOTE: If you don't know your Connection Type, contact your Internet Service Provider (ISP). To know how to set up your router according your ISP, refer to the links below:
Cable Internet Service
PPPoE / DSL
Static IP Account
Step 7:
Enter the details provided by your ISP and click Image.
You should now be able to connect to the Internet. To verify, Internet Status on the upper right corner should read Connected.
You can also launch a web browser and go to your favorite website or try visiting the Belkin Site for more information and support on your devices.
as mention On official Belkin website vedio for Belking Online Support:
Setting up the Belkin router using an iOS device Video
Belkin
Or
In case you still need assistance then follow us for Belkin Tech Support on:Belkin Support
Mar 07, 2014 | Belkin N Wireless Modem-Router F5D8633au4A
Cannot connect to my belkin n150 model f9k1001v1 router
Yes. You need to modify the IP and DHCP scope on the second, so there are no IP conflicts.
Plus this setups a second LAN, and obviously a second network configuration if you are trying to use the same computer.
Nov 09, 2012 | Belkin Computers & Internet
How to resolve Belkin N150 conflicting with Linksys WRT54G
Both the routers are having the same default IP addresses that's why they are conflicting.
Put only one router in the switch connected the a PC on the same LAN.
Open your browser and put the default IP address (like for most of the routers 192.168.1.1 or 192.168.0.1), hit enter and give the login ID and password (in most of the cases, admin/password orv admin/admin), go t configuration> IP settings> Static IP Mode> Change the IP from 192.168.x.1 to 192.168.x.2 (or any other other number except 1 and <254).
Save and reboot.
Now enjoy both routers plugged in simultaneously in the same LAN. :)
Sep 03, 2012 | Belkin Basic Wireless Router
I have two Panansonic KX-HCM130 cameras. I have them installed on a Belkin F5D7234-4 V5.5 Belkin router. They can be seen locally on the network with local IP address 192.168.2.253 and 192.168.2.254...
Download and install Webcam 1-2-3 >
http://www.webcamsoft.com/en/dnload123.html
or Direct link
To set-up /configure webcam 1-2-3 software for live streaming refer to:
http://www.webcamsoft.com/en/onhelp.html
Then follow the instructions from this page ->http://www.webcamsoft.com/en/faq/belkin.html on how to configure Belkin router for Webcam 1-2-3 . Important! You must have a static IP address .To avoid port conflict, use a port other than 80 for HTTP streaming
And the manual for your Belkin F5D7234-4 router can be found on the link below:
http://www.belkin.com/support/article/...
Please let me know if you need further assistance on this issue .
Nov 09, 2011 | Panasonic KX-HCM10 Network Camera
In the Belkin wireless manual it says to use the Belkin utility rather than Windows to avoid conflict between internall and Belkin wireless. Need instructions for VISTA. Manual is no help.
Usually when you get a new wireless card you should pop in the cd they provided and install the driver and utility from the disc. It should put an icon on your desktop and in your Program Files list. If you don't see a Belkin entry in your Program Files list then you should put the cd in and reinstall everything, which should give you the utility. I actually don't use any utilities besides the built-in Windows Wireless Zero configuration tool, which is the normal Windows wireless window that you are probably used to. So it isn't necessary to install the Belkin utility if you don't want to.
Aug 10, 2010 | Computers & Internet
I AM USING A BELKIN G WIRELESS ROUTER MODEL F5D72...
Either you have not configure the Wireless SSID or your router is faulty. You can use the easy setup using the CD or configure the router by going to the default IP address. Do read the setup manual first.
May 20, 2010 | Belkin (F5D7230-4) Router (587009)
Home computer on same network can't be online at same time.
If you set static IP in your computer change the last number of your static IP address in your TCP/IP setting of your LAN. The two unit shouldn't have the same IP address say 192.168.1.5 the other shall be 192.168.1.25 or don't use the router's default utility page IP address.
Jun 11, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin Wireless N router/Embarq 660 modem/No internet
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
Apr 15, 2009 | Belkin (F5D8231-4) Wireless Router...
Comment: There is an IP conflict with another computer on this ne
Use either computer to login to the router eg 192.168.0.1 or just type www.routerlogin.com into the internet browser URL bar. Under LAN Setup, click LAN settings, and from the menu that comes up, turn DHCP Server 'on'. This will assign IP addresses for your computers automatically.
Hope this helps
Chris (ziraffa)
PS Your router's 192.168... number might be different from my setup.. try 0.1 or 1.1 or 2.1 etc at the end, or just try that routerlogin method.
Jan 03, 2009 | Belkin (F5D6230-3) Wireless Router
Belkin F5D7230-4 cd
Hi!
I believe that you can get all the software that was on the disk via download at the Belkin website (www.belkin.com). You can burn it back to CD or use it as is. I believe that most Belkin products are configurable from their IP address as well, perhaps relegating the disc virtually obsolete. I'm not sure of the IP address for this particular model; I have found Belkin to use 192.168.2.1 as well as 192.168.1.1; I'm sure there are others. You can get that info on the Belkin site. Another good resource is the Belkin area of www.dslreports.com.
Good luck and let me know if this helps!
Bob
Oct 05, 2008 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Computers & Internet Logo
63 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
