Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Water comes out the accessory hose but not the floor cleaner
I had the same problem and the heater ports were clogged. I took apart the top unit and cleaned the ports with miniature bottle brushes used to clean spray painting equipment (purchased at Harbor Freight for $4). Reassembled and the unit worked fine.
Posted on Feb 17, 2010
  • scorpion42 Jun 17, 2011
    If the hand unit sprays, and you have verified that the pump belt is intact, check the heater ports where the rubber tubing connects to it like delitoth mentioned. I had the port where the water comes in blocked by stuff. Clean it out with a tooth pick or paper clip and you should be good to go.
  • josephscdr Sep 21, 2011
    take apart the handel, heater element take scews out and clean inside and the tube ports that connect to it,no cost.good viedo on u tube shows how
  • 701 Answers
You need to replace the pump belt. Here is the belt you need and it includes printed instuctions:
Bissell 1699 Pump Belt
Posted on Feb 07, 2010
2 Suggested Answers
  • 60 Answers
SOURCE: My Bissell ProHeat steam cleaner won't spray water. The accessory
Under the plastic under the water tank (its a pain to pull apart to get to it) there is a solenoid that actuates the water between the floor and the tools. This is toast if its not spraying the floor, its simply not reacting to the signal to let it go through to the water side.
Seems to be a common problem with the Bissell Proheats. You can order a new one online for about $12 and try to get to it to replace it yourself (if you can open up the base its obvious which part it is if you just follow the hoses).
Posted on Oct 31, 2009
Need replacement gasket, what holds it in place
Vacuum Parts And Accessories ' Parts For Vacuums - Sears
www.sears.com/appliances-vacuums-floor-care-parts.../b-1020290
SearsSears has replacement parts for all of the top vacuum brands, so you'll be .... Hoover Canister Vacuum Cleaner Replacement Crevice Tool Attachment 38617017 .....vacuum bags and numerous attachments, your vacuum will have your floors ...
Amazon.com: Vacuum Parts & Accessories: Home & Kitchen ...
www.amazon.com > ... > Vacuums & Floor Care
Amazon.com, Inc.Results 1 - 24 of 219043 - Online shopping for Home & Kitchen from a great selection ofReplacement Batteries & Parts, Bags, Filters, Attachments & Brushes, ...
Vacuum Cleaner Parts & Accessories: Hoses ... - Hoover
Nov 29, 2015 | Vacuums
The water and shampoowon't come out but it cames
This model is famous for burning up the silinoid switch that allows the water to come out the bottom to clean the floors. That will need to be replaced, but my recommendations is to take this model back and bet your money back. It is engineered bad!
Nov 25, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Sep 22, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
No water spraying, suction still working
I have a Bissell as well, and found that your issue sounds like there is a blockage in the hosing to the main cleaner part of your machine, The siphon action of the suction that your machine is obviously working in that you state that your accessories tubing is working. There is a split though in your unit. probably under the hood of the machine which splits the pressure between the accessories and the main unit. I highly suggest you look there to seek your blockage.
This unit works like a "straw" in a soda pop.. the unit makes a suction draw and that draw is directed to the main unit area and the accessory area, splitting from the main suction line..
Another suggestion though might be to be sure your accessory line is not "open" when you are trying to use your main unit.. you can test this by seeing it it squirts when you run your main unti as well.
Summary then is to check that there is no blockage after the "T" where the pressure seperates to the main squirter and the accessories.. This should be fairly obvious to see and a little cleaning should resolve this right up for you.
Hope that helps!
Stan
Sep 19, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell Pro-heat 2x model 8920
There is probably a bad solenoid in the machine that controls the water out to the floor, you would be better off taking it to a repair place because it is a big mess of hoses and wires.
Jun 29, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Water comes out when trigger is squeeze but wont **** up dirty water
A. Is your floor/hose knob in the correct position?
B. Do you have suction at the hose end, when in that position?
C. If you answered yes, no in that order then either your motor (provides the suction) is going bad, or it simply is clogged and needs to be serviced.
Apr 15, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell proheat, not sure of model number no water will dispense
Ran in to similar issue except mine would not spray soap or solution through the floor cleaner but would work through the upolstry cleaner.
I found that there were 2 problems as follows:
1) The heater was clogged with mineral deposits and old soap that I had not cleaned out on a previous use.
2) The Valve that attached to the trigger sticks. (I am currently looking for a new valve)
Since you have soap and no water I your problem probably exists in the bottom of the unit. There are 6 screws to take off the cover.
You will see a hose that come from the soap despenser. It leads to the pump which is located in the front left corner of the unit. You can also trace the water hosed in and out of this pump. Since the hoses are clear you should be able to see any clogg. There is a hose that leads up the handle to the valve and then a hose that comes back down the handle (through the wheel opening) The hose that comes back down from the handel leads to a splitter which devides the output to the two jets.
Once it is apart it is pretty simple.
Hope this helps!!
Nov 22, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
334 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
