Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart dishwasher model LX30H displays -5 on
Hobart dishwasher model LX30H lights up completely o nstartup , shows the model number 30, then ,displays -5 , and that's it.
  • 110 Answers
By the way you're describing the problem, i would have to say there is something wrong with your control board. part#473173 can be bought @ any hobart office in your area. dont forget to vote
Posted on Feb 13, 2010
Testimonial: "Turns out it was mice eaten wiring."
Hobart lx30h leaking from bottom
This is a testing for the post on this web site, not a solution.
Mar 27, 2014 | Hobart Lx30h Commercial Dishwasher
LX30H THROWS A CODE EO after running awhile. I hit the high reset button under the flaps on the front for both the boost and reg elements . It will work for a couple cycles and then does the same thing....
Machine won't fill or won't fill high enough. site water pressure meets minimum flow pressures. (LX18, LX30 display shows working.
"E0," "E2," "E3," or "E4". LX40 display shows "DR1 PRBLM," "FILL1 PRBLM," FILL2 PRBLM," or "FILL3 PRBLM". Machine will not run.)
1. Low water pressure - check for clogged hose strainer; check that
2. Make sure probes are clean
3. No water pressure - main water supply valves may not be
4. Drain valve open - turn machine OFF to drain machine, then
ON. Repeat twice (this assists in clearing any drain valve
obstructions). Wait for machine to reach READY mode and
press WASH. Slowly open door several seconds later and note
water level. Close door; 30 seconds later, open door slowly and
check that water level is the same as it was. If not, repeat the
OFF-ON procedure. If problem persists, call your local Hobart
Service Office.
5. Delime machine.
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F18615%20Rev%20I.PDF
Dec 10, 2013 | Hobart Lx30h Commercial Dishwasher
Lx30h P2 ERROR CODE? WON'T DRAIN COMPLETELY - HELP
the p2 err. is on open or shorted rinse thermistor which is located on the back of the mach next to the vac. brkr. as for draining ck the drain valve for debris, and the end of the drain hose where it connects to the building drain
Dec 25, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Temperature Problem
Whats the model?lxih,lx30h,lx18,lx40?What temps are low,wash or rinse?Im a hobart tech and service these units.Let me know.
Jan 19, 2009 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Hobart dishwasher model LX30H; displays wrench and E4.
Water is not to top sensor in alotted time.
Top sensor is in right rear corner, and is the upper of the two. Check the connector to the probe on the outside at the back. (sometimes gets wet fro vacuum breaker leaking when dirty or low flow pressure. Machine needs 20 psi flow rate
Dec 11, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
UNDERCOUNTER DISHWASHER (HOBART)
Can you give me the model number thats on the data plate,it should be a lx18,lx30h,lxih.Im a hobart tech and repair these units alot,let me know.
Sep 03, 2008 | Dishwashers
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
544 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
