GE Profile Washer Agitator will not come off
We have a washer which we have tried to pull the agitator off, using a rope and a board as a fulcrum. The top off the washer is off. We cannot use enough force because the tub lifts up along with the agitator. Do you know of a better method, or tool that would make it easier? Or do we need to put the top back on?
  • LJeanGraph Feb 23, 2008
    Thanks for the Agi-Tamer suggestion. We gave another try (with the top on this time) using the rope and board method. It still did not pop off, but then I gipped the bottom and gave it a good pull (has to go straight up) and it popped off. The rope most likely loosen it, but there are clips that grip all around the bottom which work against each other if there is not equal force that pulling straight up gives. Glad it is now off, thanks for the tip though!
    President:
  • Washing Mach... Master
  • 2,651 Answers
There is a product called agitamer, a rubber bladder inserted under agitator and hooked to your cold water line, pressure popos it off quite nicely
Posted on Feb 22, 2008
How do I remove the agitator on my GE Spacemaker model GSLS1100?
Remove Pulsator (Blue) cap,Pulsator nut, Pulsator, and 2 washers and 1 nut. Pull up on the drum. But, 1st ask yourself WHY you want to remove the agitator!
Jul 02, 2014 | GE Spacemaker WSLP1100D Top Load Washer
Coin stuck in agitator. how is agitator removed
Normally you can take the top of the agitator off with the use of a screw driver or by turning couter clockwise. Once the top is off you should see a nut or bolt. Removing this will allow the agitator to be removed.
Nov 12, 2010 | GE Profile WPRE6100G Top Load Washer
Can't remove agitator
Get 2 2x2 pieces of wood or 2 oak handles, 20 inches long. lay on on top of the other on the top of the washer. Loop a rope or ******** both sides of the agitator over one of the pieces of wood and tie it to the top piece of wood. Twist the top piece of wood slowly. As the 2 loops tighten up under the agitator the bottom piece holds the rope firmly across the top of machine. This save you from getting socked in the face by the agitator when it come off. You can buy an agitator remover but why not make you one and have so much fun doing it See the pic below? just ease a stick above the 2x4 and start slowly twing till she jumps out. Note: I didn't make this design I found it on line. I would run the rope under the agitator instead of taking a chance on breaking the fins. But that's just me.The trick is to grab it by the neck instead of the base. So try that before concocting a agitator remover. The agitator just snaps on. The drive block under the agitator is stripped out Wh43X10009 91c45a0.jpgis the part number. Here it the manual3c3b88a.jpg
May 25, 2010 | GE Profile WPSR3100W
How to remove agitator from GE washer? Model WHDRR418G1WW.
how to remove agitator from GE hydrowave washer machine?
Feb 27, 2010 | GE WBSR3140DW Top Load Washer
How do you remove agitator off of a GE Prodigy
Hi. The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly, which is removable as well. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to preform a combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Jul 17, 2009 | GE Profile WPRE6100G Top Load Washer
GE model number wdsr2080daww, machine will not agitate. How do you remove agitator?
You should be able to just grab the agitator and hank it straight up and off. Sometimes you might have to slip a belt or rope under the agitator and fasten the rope to a 2x4 or similar and then hank up on the board. Remove the plastic part under where the agitator was (one 1/2 inch head bolt) . If it does not come off, break it off with a chisel. If the metal spline shaft under that turns freely by hand, you have a bad transmission. If it does not turn by hand, just install a new WH49X10042 air bell (agitator drive) and replace the agitator.
Mar 08, 2009 | GE WBSE2090A Top Load Washer
Top load washer. the agitator is not working
there could be a problem with the motor.check the following link for more causes for this problem
click here
check for the section "agitator does not move"
please do post further comments or if this does not give the answer, then comments regarding a detailed description of problem would help.thank you. and good luck.
Jan 11, 2009 | GE Profile WPRE6100G Top Load Washer
Getting the agitator out
there is no screw or bolt holding it in. its just a matter of getting enough upward force on it to get it out. you need to pull straight up from the bottom. some times a rope under the agitator helps.
Nov 26, 2007 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
322 people viewed this question
Top Washing Machines Experts
